Question about Whirlpool Duet GHW9150P Front Load Washer
Owners manual Whirlpool Duet 3.5-cu ft High-Efficiency Front-Load Washer
SOURCE: washer won't drain Whirlpool Duet GHW9150P Front Load Washer
I recently had the same problem.. There is usually a panel on the lower front of the washer. I flipped open the panel door and removed the screw out plug. Make sure you have a floor drain at this point, as the water will come out when the plug is removed. This plug also contains a filter. It was plugged up with all sorts of debris... Lint, dryer sheets, rubber bands, a stick ect ect. I just cleaned the filter and plugged it back in. The washer worked normally after this. This is a simple thing to try before removing the back panel and drain hose to check for obstructions. The solution by jsrock516 would be the next logical solution. After that I would think that a faulty drain pump would be the problem
Posted on Sep 20, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Whirlpool duet front load washer flashes F35 shortly after start
Sud= The unit has sensed there is too many suds in the unit it will flush and pump out for 5 min and restart on its own..This is caused by too much soap use..
From the book :
SUD Code=
If too much detergent was used:
—Run the unit through a Rinse/Spin cycle.
—Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump,
pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic test or any
cycle.
Posted on Feb 13, 2009
  • 7 Answers
SOURCE: Front load washer fills up with water
Jamesbestor,
The water fill selenoid had junk in it holding the valve open or the seat in the valve is damaged.
Turn off the power and water, remove two screws on the back of the machine and remove the lid.
On the back left top corner are the water fill selenoids. Remove these and disassemble by undoing the 6 or 8 screws ( depending upon model ) holding the unit together. Clean and reassemble, it should take care of the problem. If not, replace the selenoid.
Posted on Feb 15, 2009
SOURCE: Help with Model #GHW9400SU0 Whirlpool Duet Front Load Washer
To unlock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds until the
CONTROL LOCKED status light turns off.
Posted on May 17, 2010
  • 662 Answers
SOURCE: Duet GHW9150P Front Load Washer: whirlpool washer says control locked, how can we f...
Press and hold "end of cycle" button for 3 seconds, on the right side of panel. This is the child lock feature, do it again & it locks.
If helped, pl rate me good!!
Posted on May 19, 2010
How do i get door to unlock?
Unplug the washer, wait for 15 seconds or so, plug back in and hit power button the cancel. this should unlock the door as it should reset. Do you have any fault code on your display? Is there a dryer stacked on the unit? Good Luck
Apr 17, 2016 | Whirlpool WFW72HEDW WFW72HEDW 4.2 Cu. Ft....
Door won't open on front load washer
How to Unlock a Whirlpool Duet Washing Machine ' Home ...
homeguides.sfgate.com > Mortgages > Mortgage Options
If you must manually unlock the washer door after each wash cycle your drain ... to Change a Water Inlet Valve for a Whirlpool Duet Front-Loading Washing Machine ...Causes and Repair for a Whirlpool Washing Machine That Won't Spin or ...
How to open a washing machine door that won't ... - YouTube
? 3:57
https://www.youtube.com/watch?v=-65_eoT6zuk
Aug 22, 2013 - Uploaded by how-2-repair.com
Your washing machine door won't open this video will show you a technique ..... Front Load Washer Repair - Not Draining or Spinning - How to Unclog ... Washing Machine Repair - Replacing the Door Bellow (Whirlpool Part
Nov 05, 2015 | Whirlpool WFW70HEBW Duet 4.1 Cu. Ft. Front...
We have a whirpool stackable..washer isn't getting much water
Make sure hoses to washer are not trapped and that isolator valves are fully open. Isolators are located normmaly at the end of the copper pipe before the flexi hose to washer, they are often a small red or blue plastic tab that must be in line with the pipes to let water through
Mar 14, 2015 | Whirlpool WFW72HEDW WFW72HEDW 4.2 Cu. Ft....
Samsung vrt front load washer
You should be getting error codes. Here's a link to Samsung's online help (it also provides a list of error codes and what they mean): http://www.samsung.com/us/support/owners/product/WF331ANW/XAA
Hope this helps.
Aug 16, 2014 | Samsung 3.5 cu. ft. High Efficiency VRT...
Whirlpool washer
hi there,
if you can supply me with the full model #, i will send you the exploded view diagram to make this easier.
Oct 11, 2008 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
