Hi am using ONIDA colour TV In which am getting a problem like the TV automatically switches to AV mode What is d problem Please advise
    Top Expert:
  • Televison & ... Master
  • 75,417 Answers
The problem is with its input selection circuit itself. This section circuit comes to its main system control section. It will be best to contact any service technician in this case. The troubleshooting is somewhat skilled work.
Gopakumar Gopalan Google
Posted on Apr 15, 2014
Onida ky surround not funtioning av2
Main IC fault. Replace it. Av selection section inside it is not working. Damaged. http://electronicshelponline.blogspot.com/
Jul 30, 2015 | Televison & Video
Onida 32" LCD TV
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
May 14, 2017 | Televison & Video
HOW CAN I ENTER INTO SERVICE MODE IN ONIDA COILOUR TV OXYGEN 21''DVMC (KY INSIDE) ?
with onida orginal remote we can open service menu(press vsm at the same time on remote control)and check the values, first write down the values before changing the values.
Apr 08, 2011 | Televison & Video
Hi i have an alba tv , im trying to connect a dvd player. I have connected the scart leads etc.I can not get onto the av channel so i can watch a dvd. Please help
Firstly, please make sure you have connected the SCART cable correctly. This should be connected to a SCART OUT socket on the DVD player to one of the SCART IN or EXT sockets on the rear of the TV.
If you have correctly connected the SCART cable the TV should automatically switch to the AV channel when you switch the DVD player power on or insert a disc.
Switch your TV on, then switch the DVD player off and then on again. If the TV does not change to the AV channel you may have the SCART cable connected incorrectly.
Not all TVs automatically switch to the AV channel when the AV device is switched on. On some TVs the AV input is on channel 0 or 99. On other TVs the AV input is not assigned to a specific channel. On these TVs you need to look for a button marked "AV", "INPUT" or "SOURCE" - either on the TV remote or on the buttons on the front of the TV. The easiest way to do this is to insert a disk into the DVD player and start it playing. Then press the "AV" "INPUT" or "SOURCE" button (whichever one you have) repeatedly until you find the signal from the DVD player.
Please check your connections and try using the "AV" "INPUT" or "SOURCE" buttons. If you are still unable to watch your DVD player, please post back with the following information:
1. Model number of the Bush TV
2. Brand and model number of the DVD player
3. If you are using any remote other than the ones supplied with the TV or DVD player, the brand and model number of the remote.
I will then be able to tell you exactly how it should be connected and which buttons (if any) you need to press to access the AV channel.
Hope this helps. Happy New Year!
Regards,
BElectric
Jan 01, 2011 | Televison & Video
My onida 21 FGL Tv has get blue sceen, some time picture is comming but agin goes to blue sceen, soud is comming. please help
its the problem due to the blue-back mode. check for any loose contacts of AV cables, it could also be due to dry solder
Jul 29, 2010 | Televison & Video
AV Jacks....
Hi! Try connecting the wires to the same colour jacks and also chekc for AV button on the remote which is sue to switch the TV between AV 1 or AV 2 mode.
Thanks
Rylee
Jan 12, 2009 | Recoton Advent Advent TS2066A TV
Onida stand by problem
sir my onida tv 21'' ineed un lock
Nov 07, 2008 | NEC PlasmaSync 42MP3 42 in. Television
Standard tv jvc av-28wfr1eks switches on then off
What happens when you try to turn the TV on from the button on the TV?
Feb 07, 2008 | Televison & Video
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
