Question about Whirlpool Duet 4.0 Cu. Ft. Steam Washer
Whirlpool Duet 3.5-cu ft High-Efficiency Front-Load Washer errors
Door is locked. wont drain. full of water. makes a strange noise
SOURCE: Duet washer door locked
Pull the front panel off, look for a plastic piece , it has a filter that you need to pull out. turn it to the left pull it out and clean it. This solved the problem for me. had the same issues.
Posted on Apr 18, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Whirlpool duet front load washer flashes F35 shortly after start
Sud= The unit has sensed there is too many suds in the unit it will flush and pump out for 5 min and restart on its own..This is caused by too much soap use..
From the book :
SUD Code=
If too much detergent was used:
—Run the unit through a Rinse/Spin cycle.
—Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump,
pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic test or any
cycle.
Posted on Feb 13, 2009
  • 34 Answers
SOURCE: washer won't drain or spin, get F2 error
Hello hernandez160,
The "F2" error is referring to excessive drain time. Unplug machine before working on it. Remove screws on bottom of lower panel and remove panel. The drain pump is behind the panel, It has a large round door on it, turn counter clock wise by hand to access pump clean out. Have lots of towels ready. Remove anything from pump (usually kids socks or small clothing articles). If nothing in pump clean out remove suction boot from drain pump and check there. If nothing there blow through the drain hose from the pump side to check if anything is stuck in the hose. If that's clear check the electrical connection on the pump, make sure nothing is loose or broken at the connection. If all this checks out good and it still wont work you probably have a bad pump and it will need to be replaced. If you do find something was blocked or clogged due to small clothing articles I would recommend a garment/lingerie bag to keep all the small stuff together during the wash cycle. Hope this helps to fix your problem. Please remember to rate this and every solution you get.
Thanks,
edgin96
Posted on May 20, 2009
  • 662 Answers
SOURCE: it wont spin nor will it drain
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the hose you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Pl rate me nice for the free help, thanks
Posted on Jun 04, 2010
  • 17 Answers
SOURCE: What is the cu. ft of my Whirlpool duet washing ma...
3.7 CUFT
Posted on Aug 11, 2010
Door won't open on front load washer
How to Unlock a Whirlpool Duet Washing Machine ' Home ...
homeguides.sfgate.com > Mortgages > Mortgage Options
If you must manually unlock the washer door after each wash cycle your drain ... to Change a Water Inlet Valve for a Whirlpool Duet Front-Loading Washing Machine ...Causes and Repair for a Whirlpool Washing Machine That Won't Spin or ...
How to open a washing machine door that won't ... - YouTube
? 3:57
https://www.youtube.com/watch?v=-65_eoT6zuk
Aug 22, 2013 - Uploaded by how-2-repair.com
Your washing machine door won't open this video will show you a technique ..... Front Load Washer Repair - Not Draining or Spinning - How to Unclog ... Washing Machine Repair - Replacing the Door Bellow (Whirlpool Part
Nov 05, 2015 | Whirlpool WFW70HEBW Duet 4.1 Cu. Ft. Front...
Why will the washing machine door not unlock?
Sounds like you have a broken door lock, or a wire harness is loose or disconnected. Also make sure the door seal is not out of place.
May 01, 2014 | Whirlpool Duet Steam 4.1 Cu. Ft. Front...
My whirlpool front load washing machine is making a loud knocking noise when in the spine cycle.
Bad tub baring or hopefully a cloged drain pump. If it is a tub baring it is going to cost a lot of money.
Good luck,
Marty
Jul 24, 2012 | Whirlpool WFW9550WW Duet Steam 4.4 cu. ft....
Duet GHW9150P Front Load Washer: Whirlpool Duet Washer - Error F21 (What is this) ...
First check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out. Door locked? Press "end of cycle" for 3 seconds, wait for 2 minutes & try the door. F-21 filter blocked.
How abt a nice rating for the free help? Thnks
May 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool door lock error
turn off all water to your washer run the washer empty for a full cycle when the cycle ends the door will release
spray a lubricant such a WD40 into/onto the door lock
the door kit will not fix the problem
Jun 01, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Whirlpool washer
hi there,
if you can supply me with the full model #, i will send you the exploded view diagram to make this easier.
Oct 11, 2008 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool Duet 4.0 Cu. Ft. Steam Washer Logo
21 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
