Question about Dell Computers & Internet
Memory compare error
Cannot login to account, and i ran diagnostics and it told me there was a memory compare error
    Sergeant:
  • 249 Answers
Sounds like an issue with incompatible, mismatched or bad RAM sticks (SIMMs). Even if ram sticks say they will operate at lower clock speeds, this does not always happen. You need to find the RAM in your computer and check the SIMMS. If they are different, you will need to find one that is the same as the higher speed (better performance) or the lower speed (less money). If they are identical then one of them may be faulty.
If your laptop is still under warranty, have Dell look at it. If not then you should be able to do this yourself using internet help videos or find a reasonably priced repair shop.
You may also try the following, remove the memory SIMMS and clean the edges. Use something like an airduster to remove any particles in the case and then re-insert the RAM.
Posted on Apr 14, 2014
3 Suggested Answers
symbiano45
SOURCE: Hp mini notebook ran out of memory and i cant access the internet
create a usb boot pen with your orduring boot time press F8 and choose security mode, reach to your hard disk and delete all trash you know you don't need, then shutdown the system and restart usual way.
Posted on Apr 14, 2009
cabanagj43
  • 225 Answers
SOURCE: I ran diagnostics on my Dell Inspiron 1525.
1. reseat the ram
2. at the buttom part of the laptop you will see a window covered which will allow you to remove and have the ram be reseated.
3. take out 1 ram firs then run test then run again the test using the other slot. please test each ram on each slot. check if the faulty if the ram or either of the rams of one of the slots. if both ram passed on one of the slots means that ram is ok and slot is not, so then replace the motherboard. if one ram errors on a slot which the ram passed then that ram might be faulty and needs replacement.
Posted on Oct 15, 2009
How do I restart my dell- oxo error has now reset user and I don't know password?
You must login in with the administrators account to change other users passwords or retrieve them. If you don't know the administrators password you may have to start from scratch and re-install the O/S.
May 15, 2014 | Computers & Internet
I can't logiin
Try again later. A system error occurred that wasn't your fault.
Apr 23, 2017 | GPS
I have a Dell Inspirion 530, dual core quad processor. It's about 3 years old. I just recently started occasionally getting blue screen error. When I ran the memory test off of the bootable partion, I...
It sounds like you are having memory issues with your computer. The best thing you can do is just replace the memory the computer sounds just fine you just need new memory. If you go to this link http://www.newegg.com/Product/Product.aspx?Item=N82E16820134117&cm_re=DDR2-800-_-20-134-117-_-Product on newegg.com. Order these sticks of memory you would be fine. All you need to do is just open up the dell case. Remove the old memory sticks from the main motherboard. Then install the new sticks and you will be able to reboot your system and should run just fine.
Apr 25, 2011 | Dell Computers & Internet
I have an ASUS K8V-VM motherboard. I recently upgraded the memory to 2GB of DDR400 (2 1GB sticks) It ran fine for the first 3 or 4 days then started having problems booting. After changing the memory back...
One bad lead will cause your computer to shut down or continue in a cycle
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to your hard drive
hope this helps
Oct 24, 2010 | ASUS K8V-VM (K8V-VM GREEN) Motherboard
Ran hp diagnostics and got error code biome-1 It also said test memory 8192 mb. What does this mean and how do I fix it
The error simply means that you have a defective memory modules. If you have more than one memory module, remove all then install one at a time, this is to isolate the defective module.
Good day and good luck.
TedMac
Sep 14, 2010 | Computers & Internet
I now my password but my orkut account in not signin plz help me
for login to orkut account.firstly you change the password of gmail account and then login the orkut account.afterall this method if you unable to login the orkut account then it may be another problem.
May 22, 2010 | Google Computers & Internet
I ran diagnostics on my Dell Inspiron 1525. Results: Data Bus stress test failed. Memory compare error, DIMM-B. Suggestion: try to reseat the memory. How should I do? Please help! Thanks T.Doan
1. reseat the ram
Oct 15, 2009 | Dell Inspiron 1525 Notebook
Memory write/read & address line failures on Dell Inspiron 1525
you may need to format that memory because it may be corupted.
Jul 17, 2009 | Dell Inspiron 1525 Notebook
Apr 14, 2009 | HP Pavilion dv9000z Notebook
Computers & Internet Logo
14 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
