I have an Orion tv model TV2710 and I had to get an universal remote and it works with butI hooked a DVD player to it and I push input on the universal remote and it does nothing What do I need to do
    Sergeant:
  • 249 Answers
The universal remote needs to be set up for each device that it can control. If there are multiple devices like TV DVD and SAT (satellite), then you need to use your owner manual to program the remote control to be able to operate the other devices. Make sure you have a note of the code you used for your TV. If you follow the instructions for programming correctly, the TV settings will be kept. Make a note of the codes you use for each of your devices. It makes it much easier to reprogram it if the batteries run out and it 'forgets' the codes.
Posted on Apr 14, 2014
SOURCE: No remote for small Orion TV - Input mode?
If u cant get to the aux screen try holding down or pressing one of the channel buttons very quickly.
Good Luck!
Posted on Nov 30, 2008
  • 104 Answers
SOURCE: Can't find the input/video channel for my Emerson TV
universal remotes are tricky, if you have the pamphlet, often times there are several codes for each brand. you have to try all the emerson codes for your universal even tho the power, volume and channel functions may work with several emerson codes, some of these specialized buttons (like input) may only work on your TV with one specific code.
also, if there are any unlabeled buttons on the universal try them with each new emerson code.
Posted on Feb 12, 2009
SOURCE: Need universal remote code for ge remote and Orion tv
The code that worked for me was 135.
Other Orion codes are 035, 121
Four digit codes for newer remote models might be one of the folling.
0236, 0179, 0463
Good Luck!
Posted on Feb 20, 2009
ronaldo_ross
  • 1056 Answers
SOURCE: Orion model TV1934a - I do not have the original
Try doing a auto channel search while a dvd is on and connected to the TV. An av input is usually reached to the bottom of all the channels. for example pushing the channel below channel two the next one would be AV input.
Posted on Jun 28, 2009
stonephoenix
  • 563 Answers
SOURCE: I have an Orion TV Mod TV1933b
Unfortunately, with most TVs this function is located only on the remote. If you could do it without the remote there would be a button on the panel of the TV labeled accordingly.
To purchase a replacement remote (a universal remote won't work with that model TV) call Fox International at 800-321-6993. They are the largest Orion parts distributor that I know. Orion doesn't sell parts directly to the public.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Posted on Jul 11, 2009
How do i connect Orion DVD Player to LG Television with out a remote control.
The best option would be the HDMI-to-HDMI connection between your player and your TV. But because you mentioned that your TV is an old model, probably it does not have an HDMI port, in which case you have to use the RCA A/V connection. I understand you do not have a remote control for your TV, but you do not program a TV channel to watch DVD movies; you just switch between your TV and the DVD player as your audio/video sources. Here is what you have to do: check on your TV box for a button labeled 'Source' or 'Input'. Press on the button and it will alternate between TV and DVD (assuming you do not have any other device hooked up to your TV).
Dec 17, 2014 | Orion BDP3959 Player
Hi I have a orion tv and I can not figure how to get it to play a DVD player or to program a remote to turn the channels I need help
How to hook up a DVD Player:
http://www.wikihow.com/Hook-Up-a-DVD-Player
How to program a universal remote:
http://www.ehow.com/how_9191_program-rca-universal.html
Mar 20, 2011 | Orion STV2763 27" TV
I have an orion combination TV, VHS & DVD player. I cannot access the back of the set to see the model #. I want to know how to change the video input button. Don't see one.
the button is on your tv factory remote control. a universal remote wont work. now you can try to physically go to the channel down button on the tv. keep pushing it until it counts down the channels, then it should go to video 1, video 2, line video, front video. fixed! enjoY!
Nov 14, 2009 | Orion1934 19" TV
did you figure it out? i am trying to get my orion tv1333 to go into aux mode without a remote. thanks.
Sep 16, 2008 | Orion STV2763 27" TV
Dvd/tv hook up
plug in dvd player direct to tv yello red white for sound into a input ok vidieo one ect then change input on tv to that input ch2 hit ch down to go into inputs
Feb 10, 2008 | Sanyo DS31590 31" TV
Universal Remote Code for Dynex 20" TV/DVD
I just bought a 32" dynex lcd and saw that i couldn't program my two $5 ge remotes to work it. From reading in this forum and others I'm not the only one with the problem, I thought I was stuck with only the dynex remote. But the dynex website tells you how to get universal remotes to work,
It tells you to try the codes for Orion, Emerson, Memorex, Sansui, Sylvania, Zenith. The second orion code worked for me. both my ge remotes look and work the same but one uses a four digit code and the other uses a three digit code. I used 0135 on one and 135 on the other. There is a good chance that if you try the codes for the brands dynex lists you will find one that works. The 0135 or 135 might work for most dynex tv's.
If you have a ge remote and haven't programmed it for volume punch through you might try it. It allows the tv volume to be controlled using the ge remote even when it's set to something other than tv.
Nov 04, 2007 | Televison & Video
Video Mode - Orion 27" TV - Model stv2555A
VICTORY! Had the same problem with my Orion model FTDV2004. Lost the remote and couldn't program a universal remote to change the input to AV. After a day of reading posts, I just started pushing the channel up button. Somewhere past channel 115 the "Line1" and "Line 2" inputs showed up.
Sep 26, 2007 | Televison & Video
The input button
On some sets you can use the menu button to enter the menu and navigate to the page which shows what input is currently selected and change it there. If your set does not have that option, then you will need the remote to do it. I have found that on some universal remotes, the TV/VCR button switches the inputs on the TV when the remote is in the TV mode. If that button does not work on your remote for your set, and you have tried all possible codes for JVC TVs, then the only way to switch inputs is to invest a few dollars more and get an original remote from JVC or have the set repaired so that the input button on the TV functions again.
Jul 11, 2007 | JVC AV-27F702 27" TV
Can not get tv to go to aux mode to hook up a playstation2
Do you have the original remote control?. Without it you will not be able to switch to video or to the TV mode. If you do have the Original remote hand unit, look for a button call input or video. A universal will not work so please do not waist your hard earnd cash. Good Luck
Mar 22, 2007 | Orion1934 19" TV
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
