Question about Utilitech 1-1/2 HP Irrigation Pump UTP15P1
Where can i find a wiring diagram
My pump came without a wiring diagram and i am trying to hook to 220 volt
  • Utilitech Master
  • 16,210 Answers
Even the company did not post that in direct response to an inquiry. That is a bad sign. So what wires are present on the unit?
Posted on Apr 14, 2014
Wiring diagram for sx model
look on the side of the motor it has a diagram for both 240 and 120 if wiring 220 motor should already be wired if 120 volt you have to move the wires shown on diagram
Aug 27, 2014 | Pool & Spa
220 volt wiring diagram
see side of motor schematic 120 volt vs 220 volt
Dec 02, 2013 | Waterway Pool & Spa
Dayton wiring diagram
Wiring diagram should appear on side of motor.
Dayton is sold by grainger.
Contact WW Grainger with model number etc and they will send email the pdf file showing wiring.
Take photo of wiring diagram on motor label, and attach to question for best possible chance of accurate answer.
May 21, 2013 | Pool & Spa
230 volt waterway spa pump model#sd-20-2n22cd electal scamatic
check voltage if 220 between two hots its 220 if only 120 low voltage if 220 ok then 1st hot to L1 then 2nd hot to L2 then green to ground or case if white you might have 120 volt then see side of case of motor for low voltage wiring
Apr 20, 2013 | Waterway Pool & Spa
Well water jet pump
the diagram is on the tin cover that covers the wires
Mar 23, 2012 | Plumbing
I NEED THE WIRING DIAGRAM TO HOOK-UP AN INGERSOLL-RAND TYPE 30, MODEL V 234 N4, SER. # 30T 37128 I UNDERSTAND THAT IT CAN BE WIRED FOR 110 VOLT OR 220 VOLT POWER.
The wiring diagram is on the outside of the
motor case, on most motors,on the label
Also on the inside of the wiring connection
cover
May 25, 2011 | Ingersoll Rand Type 30 Reciprocating Air...
A o smith b854 motor schematic diagram 115v . How do I hook up 115v to the factory set 230v?
Remove the back of the pump housing ... inside you will find the 110 volt connection place.
If your pump is on a dedicated line (as it should be) run it on 220 VAC ... To convert your line from 110 to 220 all you need is a double pole breaker of the proper amperage ... take the white wire presently on the ground bus bar and put it on the other side of the new double pole breaker. Then you will have 220 ... and you will save a few bucks on electricity.
Jul 11, 2010 | Smith Pool Pump Motor Square Flange - 1 HP
Wirng connecions for 110v pentair pool motor???
There shopuld be a diagram on the nameplate of the motor, or on the cover for the wiring compartment, or there is some stamped indication at the wiring lugs that tell you where to put your feed and what position the internal wires are to be in or the jumper .. for 110 volts or 220 volts.
May 29, 2010 | Pentair 3hp Whisperflo Pool Pump In -...
I need a wiring diagram for a kobalt 60 gallon air compressor
If it's a 220 volt motor, hook l1 and l2 (220 volts) to the line terminals. If it's a'dual voltage' motor (120 or 220)and you want to use 120, hook 120 to the terminals marked 'line'. Make sure the motor is connected for the voltage you're using if it's dual voltage.
Jul 21, 2009 | Air Tools & Compressors
Utilitech 1-1/2 HP Irrigation Pump UTP15P1 Logo
313 people viewed this question
Top Utilitech Plumbing Experts
Paul Carew
jhnolson
Are you an Utilitech Plumbing Expert? Answer questions, earn points and help others
