Question about Lexus Keyless Remote/key combo rubber cover - 3 button
When the car is started it idle high for 15 to 30 seconds
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 103 Answers
Cars are supposed to idle high when the engine is not warm. The idle should lower as the engine warms up.
Posted on Apr 18, 2014
Revs really high when starting
About 222,000 results (0.52 seconds) Search Results
    vrrrrooooommm... high rev at start up - JeepForum.com
    www.jeepforum.com > ... > WJ Grand Cherokee Forum
    Jun 15, 2011 - 15 posts - ‎7 authors
    anyone know the cause of high rev to 2K rpm at start up? just recently started ... 2003WJ ... The Ultimate WJ Grand Cherokee Buyer's Guide High Idle on Grand Cherokee
    Mar 23, 2012
    high idle at start
    Jun 8, 2009
    Engine Revs on Start up
    Apr 14, 2009
    High rpm idle on cold start.
    Jul 12, 2008
    More results from www.jeepforum.com
    wj over rev at start up - JeepsUnlimited
    www.jeepsunlimited.com/forums/showthread.php?506251...rev-at-start...
    Jul 29, 2009 - 17 posts - ‎12 authors
    why the hell does my 2000 wj over rev to about 2300 rpm when start up its so ... 2003WJ Overland 4.7 H.O. ... the dealer I told them about it and they did a warm high idle software update ... 98 ZJ Laredo 5.2: Fully built and very kush. .... Jeep®, Wrangler, Cherokee, and Grand Cherokee are copyrighted and ... 4.7 high rev start
    Mar 30, 2011
    2004 Grand Cherokee 4.0 High Idle
    Mar 25, 2011
    RPM surging problems
    Sep 13, 2010
    2002 Jeep Grand Cherokee 4.7 high idle?
    Nov 22, 2009
    More results from www.jeepsunlimited.com
    High idle/rev up on startup Jeep Grand Cherokee 2000
Feb 08, 2016 | Jeep 2003 Grand Cherokee Laredo
High idle at start up 2200rpm then slowly drops but always seems high have to ride brakes to stop
Long High idle after start up - YotaTech Forums
www.yotatech.com/f116/long-high-idle-after-start-up-246386/
Dec 20, 2011 - aviator's Avatar ... When the high idle is no longer needed the piston retracts and the throttle ... Sometimes the piston gets gunky and slow to react... clean the ... you are already idling higher then normal the idle up will only be worse... for ... it takes to kick down when I first start it up, high idle is at 2200 RPM it ...Missing: lincoln
High idle at start up - F150online Forums
www.f150online.com/forums/v8.../306364-high-idle-start-up.html
Oct 27, 2007 - ... King Ranch · Lightning · Lincoln Blackwood & Mark LT · SuperCrew · SVT ... my 2000 when its been sitting goes up close to 2k then drops down in seconds. ... so what your saying is when it's cold outside I can expect it to start andidle at 2200 rpm. sounds pretty off to me. ... Vehicle: 2004 Ford F150 5.4L. 4.6l Intermittent High Idle. Why?
Jul 12, 2005
Dual remote oil filters????
Jun 29, 2001
More results from www.f150online.com
Nov 30, 2015 | 2004 Lincoln Aviator
HUSQVARNA 128LD WILL START RUN FOR A FEW SECONDS AND DIE.
You need to adjust your idle screws. Start at 1 and a half turns out for High and Low then go from there.
Aug 22, 2014 | Husqvarna 128 LD Weedeater
1999 yukon high idle why
One of the sensors, map, tps, etc may be going out. Could be a dirty (carbon) throttle body.
Jan 23, 2018 | 1999 GMC Yukon
I have a 4x4 89 s-10 4.3 v6 fuel injection. When I start my truck it idles high. After 30 to 50 seconds the idle goes back to normal. If I put in in reverse or drive when idle is high my back tires spin...
Sounds like the rear pads are worn out, your front brakes are keeping the truck from rolling. You need to have the high rpm checked for that 30-50 seconds as it is called the "cold start routine" and is meant to rev the engine for that time period. There may be an adjustment to keep it from over revving, check the specs for the rpm.
Even if you fix the rear brakes, the stress on the U-joints and differential or transmission is needless and can be fixed by limiting the high rpm in the "cold start cycle".
Jan 13, 2013 | Cars & Trucks
My idle is high and can't get it to get back to around 700rpms. i was driving home one night turned on my road then it started this problem of idleing high, never stops, when the car starts it idles around...
What kind of vehicle is it? Try the throttle position sensor if it has one. If it has a carburator the choke is probably not working properly and needs cleaned or rebuilt.
Feb 09, 2011 | GMC Jimmy Cars & Trucks
Why does my 2000 ford taurus idle so high when i start it
this is normal, if the idle wasn't high (about 2,500 RPM) the engine wopuld stall out until it warms up to normal temperature. If it is above 3000 RPM for more than a few seconds you have a problem.
Mar 25, 2010 | 2000 Ford Taurus
Idle is high after changing the timing belt
Replace the idle speed control valve.Very common on fords this fails.And what you are telling me are the same symtoms.Good luck m8.
Jul 07, 2009 | 1999 Ford Contour
High fast idle at start up.
On most newer cars there is a fast idle motor controlled by the computer that will hold the fast idle till the engine reaches a preset temp in the computer then the engine should drop down to the set idle according to specs for that car. If the oil pressure continues to stay low after the idle goes down you may need to replace the oil pressure sending unit or if worse case the oil pump.
Nov 18, 2008 | 2003 Hyundai Tiburon
Lexus Keyless Remote/key combo rubber cover - 3 button Logo
29 people viewed this question
Top Car and Truck Remotes.com Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Car and Truck Remotes.com Vehicle Part and Accessory Expert? Answer questions, earn points and help others
