Question about Sanyo SRR49FD
I need to order a condenser coil for srr-49fd
The coil has a leak and needs replacing
Error code sh2 on a Sanyo srr-49fd
SH2 means sensor number 2 is shorted
Aug 03, 2013 | Sanyo SRR49FD
Weather king 10AJB30A01 runs but doesn't cool
Hello, in order to find the leak usually a dye is injected into the system and will pinpoint exactly where a leak is. If the condenser is leaking your better off replacing it then trying to spot braze it. The ductwork needs to be supported properly with very little restriction so the air csn move freely. Flex duct has a tendecynto tear or come apart so it needs to be checked over and repaired if you see it torn or sagging anywhere.
May 10, 2012 | Weather King 10AJA1801AH Air Conditioner
Blows air but will not cool
Hello my name is Heath it will be my pleasure to assist you. The first thing to check is the filter in the furnace or air handler. Also check the inside coil to be sure its not frozen up. Does the air coming out feel cold? It sounds like the unit could be low on charge which means it has a leak and should be leak checked repaired and properly charged. You would need refrigeration gauges to put on the system in order to properly check the refrigerant charge in the system. One other thing could be a dirty condenser coil. Turn the power off to the unit and use a garden hose with a strong nozzle and spray water through the whole coil to try and blow any dirt or debris through the condenser coil in the outside unit.
Sep 04, 2011 | DeLonghi Heating & Cooling
Air condition blows cold air but room is not cooling off
Aug 28, 2011 | Heating & Cooling
My rudd uaka 037JAZ leaks, like to replace just AC and not coil and furnace motor. Replacement suggestion for this unit? Homeowener George
Hello, it depends where the unit is leaking from, if it is leaking from the condensing unit then you can just replace the condenser, however if it is leaking from the evaporator coil then you will need to replace the evaporater. As far as brand for replacement I like rheem equipment. The best thing to do is have a hvac technician come out and give you a estimate on a new AC and then you can make a decision.
Feb 21, 2011 | Ruud UAKA037 Air Conditioner
Need a replacement coil for a Coleman Evcon air handler Model # AH12L10NA. I am losing freon at a rapid pace. Leak detector indicated leaks in the indoor coil in the air handler. PLEASE HELP! Thanks in...
This may be a bigger issue than you want to tackle alone, generally speaking the coil will have to be ordered from a dealer, as most wholesalers will not sell to the general public. Further, this will require brazing the new coil in, evacuating the system, installing a dryer and recharging.
Jul 12, 2009 | Coleman Heating & Cooling
Sanyo SRR49FD Logo
49 people viewed this question
Top Sanyo Refrigerators Experts
John Tripp
John Tripp
Steve
Are you a Sanyo Refrigerator Expert? Answer questions, earn points and help others
