Question about Panasonic PT-LB60U LCD Projector
Panasonic pt-lb60U image color wrong - Panasonic PT-LB60U LCD Projector
4 Suggested Answers
  • 17 Answers
SOURCE: Panasonic PT-AE900U displays black and white only
sounds like bad cables, or wrong setting on projector you may have it set to compoent instead of composite,, you don't tell how you are hooking it up. (what type of cables you are using)
Posted on Jul 17, 2008
marketex
  • 371 Answers
SOURCE: PT L711U + all my black colors are blue
Your projector needs to be aligned and serviced, normal occurrence
after 6 years since service.
Posted on Apr 19, 2009
  • 3 Answers
SOURCE: panasonic projector Pt-LB60u has a greenish hue
upon the bulb life running out on pani projectors and proj. tv's the lamp set will start to produce a green hue get a new lamp bro. try this web site i highly recomend them www.electrified.com
Posted on Feb 09, 2010
I have a panasonic pt-60dl54, the sound works but green picture
Hi,Yes your problem sounds like the DMD board.This is how it works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens.You will need to replace the DMD board. Have a blessed one!
Apr 13, 2010 | Panasonic PT-50DL54 50" Rear Projection...
Panasonic projector Pt-LB60u has a greenish hue around part of the edge of the projection. What would be causing this?
Feb 08, 2010 | Panasonic PT-LB60U Multimedia Projector
Panasonic PT-AE900u Horizontal Ghost Image/ 2:35 Image Retention.
It sounds like an Intergrated Circuit (IC) has fried. Even on a good day, this is not something you can attack at home. As a tech (and as an owner of that model samsung), I'd need a map & tools to know what's going on. Your best bet in this situation is to contact Samsung and let them recommend an authorized service center in your area. Sorry I can't be of more help, but this is a rather serious problem.
Jul 21, 2009 | Panasonic Televison & Video
Poor image
check the menu for color convergence option try that
May 15, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Apr 18, 2009 | Panasonic PT L711U Multimedia Projector
Pt-52lcx65 52 in.
call panasonic customer service....open a claim....problem is most likely that the eprom needs to be reflashed.....i contacted them several weeks ago, told them my problem which was 5 baseball sized colored spots, 1 red, 2 blue and 2 green. they had me perform a couple of tests using a dvd. when i reported the results they set up a service call with a local authorized repair shop. results were amazing. reflashing the eprom took about 4-6 minutes. in addition my brilliant color returned to the set as well as another problem of neon images going away. this was paid for by panasonic. my set was 2 years over warranty. panasonic has issued a service bulletin on this and are backing up these units.
pt-61lcx35
hope this helps, i am quite satisfied with what was done.
Dec 18, 2008 | Panasonic PT-52LCX65 44" HDTV
Lamb will not reset
Reset The Lamp Timer.
While simultaneously holding down (+ . >) and AUTO SYNC on the projector, Press ( I ) ON and ( - . < ) on the projector.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset.
NOTE..... Make sure only to reset the lamp timer only when replacing the lamp. If you reset the lamp timer and continue to use the same lamp, this may cause the lamp tp become damaged or explode...
Sinista
Mar 18, 2008 | Sharp Notevision PG-B10S Multimedia...
Green....purple....colors
If you are technically savvy and you can solder.....requires
chassis pull...replacement of convergence IC's...mounted on large heatsinks on board to the right looking in from rear....If
you want help........Let me know................T.
Dec 27, 2007 | Panasonic PT-53WX53 53" Rear Projection...
Oct 25, 2007 | Panasonic PT-AE900U Multimedia Projector
Panasonic PT-LB60U LCD Projector Logo
23 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
