Question about DeLonghi Coffee Makers & Espresso Machines
Coffee doesn't come out from the filter
Expresso coffee does not flow out. Boiler works the steam knob as well. I cleaned the filter holder. I have got the machine a month ago I made arounf 10 coffees. I don't think i have used too much. What can I do? thanks
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 37 Answers
Loosen the coffee grind to make it more coarse
Posted on Apr 15, 2014
SOURCE: Machine Does not draw water into the boiler
I have had this same problem - it is due to an airlock in the boiler/tubes. Simple solution is to use a syringe or similar and gently force some water up the intake hose from the tank, then try the pump again.
Posted on Oct 10, 2007
Cuisinexpert
  • 61 Answers
SOURCE: DCC-1200 coffeemaker cleaning button flashes
Make sure that when you do the vinegar solution, you do at least 4 cups of white vinegar, and fill it up the rest of the way (max fill line) with water. The manual says to "fill to capacity with a mixture of 1/3 vinegar and 2/3 water," which lots of people misunderstand, and think it means "1/3 CUP vinegar and 2/3 CUP water," which is not the case. It means 1/3 of your 12 cups (and 1/3 times 12 is 4 cups) of vinegar, and 2/3 of your 12 cups (aka, fill it up the rest of the way) of water.
You might have to let it soak for an hour before you try to brew it--this lets the vinegar work at the calcium buildup a LOT better (kind of like soaking your pots and pans before you try to clean them), but it should definitely work for you. If not, call Cuisinart's tech support (1 800 726 0190) and they might be able to get you a replacement :)
Posted on Aug 21, 2009
SOURCE: Breville expresso filter
Put the coffee filter in the oven (yes the OVEN) and run a auto-clean cycle, it will turn all to hashes. Run a clean water cycle after to clean it.
It may discolor the filter a bit, but this is only cosmetic.
It happened to me because the grinder at the grocery store had trouble without anybody noticing it. It's then I decided to buy my own grinder.
Good luck,
JF
Posted on Oct 17, 2009
EsWorld
  • 1618 Answers
SOURCE: i have saeco incanto deluxe coffee machine,ventilate msg appears
Check the end of the steam nozzle, make sure it is not blocked. If not then with the knob open for hot water cycle push in on the knob if that works then the tap rod assemble or the steam valve needs to be replaced.
Posted on Feb 21, 2010
  • 1089 Answers
SOURCE: brewed coffee goong into used grounds holder
HI
That is a stripped thumbscrew. You need a new one. When it starts to brew, the stripped thumbscrew pushes up and allows the coffee to fill the head and dredge drawer.
The plastic rod that has 2 small hooks on the end and has ribs around the opposite end is your thumbscrew. It holds the filter screen in place. There is suppose to be a small round nut that is molded into the position between the legs with the hooks. If you use the key to tighten the thumbscrew you will pull the nut out and then the thumbscrew will pop out of the brew head. Check the stem of the filter screen. If you have an item that is about 3/8 of an inch long and has a grove in the middle and small bumps on it, that’s the nut. You need a new thumbscrew. Remove the old nut on the stem before putting it in the new thumbscrew. Remember it’s a thumbscrew, so it only needs to be finger tight. The key is for removing only.
Posted on Jun 07, 2010
Testimonial: "nailed it! Now I just need a new thumbscrew"
My expresso machine won't steam. Just suddenly stopped. Have tried running vinegar through system, but still won't run through steamer.
Hi, I dont know which brand machine you have, but I should be able to work out what is wrong. If your machine has a press button or turn knob steam tap, then it could be the solenoid which opens the steam flow. The solenoid itself maybe stuck or the coil maybe faulty. You just need to work back from the steam arm to work out which solenoid it is. It should make a clicking sound when activated. Commercial machine solenoids canbe disassembled and cleaned. If its a domestic machine, then just replace the solenoid. Also, some machines have a micro switch that activates the steam valve. If its faulty, then replace it.
If its a domestic machine you have, then another thing that maybe at fault, and that is the thermoblock (small boiler). If it doesn't heat up then no steam canbe made. The thermoblock has an element inside, and they can not be replaced. You have to replace the whole thermoblock. It can be easily checked with a multi meter to see if the circuit is broken. On some thermoblocks, is a thermostat or overload sensor. It is also easily checked with a meter.
So lets break it down a) solenid
b) micro switch
c) Thermoblock
d) thermostat/ thermol overload
Hope this has help you. Id be looking towards the thermoblock. Dazza
Oct 20, 2011 | Krups Gusto 880-42 Espresso Machine
Tip
Ventilate error -
The following procedure works when you get the ventilate error:
The Ventilate sign can be due to one or more of the following reasons:
Cause 1- Water leaking from the inlet valve below the water tank. The hose from the inlet valve to the pump can be air locked. When using the hand pump, do not thrust its nozzle too deep
Cause 2- Blockage in the passage of water due to clogged passage anywhere between the pump and espresso delivery nozzle.
Cause 3- Pump is not working. Open steam/water outlet knob and hear the pump work. If you do not hear any noise from the pump, this may be the main cause.
Cause 4- Flow meter is faulty. This part is like the water meter for homes. It measures the flow of water and signals the electronic board. The malfunctioning flow meter will not send signals even when water is flowing through it.
Cause 5- Hose is disconnected and water is not flowing in the system.
Cause 6- O-rings at hose connection is leaking, reducing the water flow to be sensed by flow meter.
Cause 7- Boiler gasket is leaking. Reduces flow of water through the system.
Cause 9- Brew unit is blocked, blocking flow of water through the flow meter. This also causes pump to slow down and ultimately stop with muffled sound within 15 seconds.
Cause 10- Brew unit not connecting brew valve, preventing flow of water. Same sign under cause 9.
Cause 11- Steam is leaking. Registers reduced flow of water at the flow meter.
Cause 12- Solenoid valve is blocked or solenoid coil is bad. Same observation as cause 9.
Cause 13- Electronic Control board is bad. Though rare it can happen due to condensed water from leaking steam. When steam is leaking or boiler is leaking, machine should not be used any more to prevent steam shorting the Electronic board.
Some of the above causes can be checked and corrected before seeking technical help. Do not assume anything without physically checking each of the following:
1- Make sure the water tank is full. If the water tank has water level float, make sure the float is in its housing and it floats as water is filled in the tank. If the level float does not rise with the level of water, then replace the float.
2- Water is not leaking from below the tank. The inlet valve is good. If leakage is present, replace the gasket in the water inlet valve.
3- Prime the machine by opening the hot water knob for 20 seconds or pressing the hot water button. Hot water flow shows the boiler is not blocked with minerals and pump is good. The solenoid valve is good.
4- Water & steam flowing normal, check the brew group for blockage. Determine when was the last time brew group was cleaned. Clean the brew group as explained elsewhere on these pages. If the machine has pre-ground function, try making a fake espresso (without coffee). Make regular espresso in other models to make sure that water goes through brew group and espresso is dispensed.
4- If hot water does not flow because the pump is not activated, then pump is bad. Replace pump.
5- Pump starts to work but within few seconds its sound is muffled and finally stop. This indicates there is serious blockage in the water line or the boiler is clogged with mineral deposits. If water is leaking and seen on the counter top, the chances are that water is leaking from hose connections(replace O-rings) or the boiler is leaking from seams (replace boiler).
6- Prime the machine by opening steam outlet for 20 seconds. Steam flow shows that steam boiler / steam outlet is not blocked. If the steam does not flow, then steam boiler or steam passage is blocked. Replace steam boiler or steam valve
7- Check the solenoid valves to make sure that they open & close as the coil is energized. Solenoid valve is located between the pump and boiler. The pump is activated simultaneously as the solenoid valve when espresso selection button is pressed. Some models may have a solenoid valve near the steam valve. In these models, the solenoid valve is activated to allow passage for steam/hot water. If the valve is not functioning, the ventilate sign will appear.
7- Hear the pump work when priming the machine. Louder noise from the pump can be due to
** air-locked water hose, or
** water is not sucked from the tank or the pump is sucking air instead of water or
** the diaphragm inside the pump has lost flexibility and not developing pressure to push water forward
** the hydraulic system is blocked at one or more locations due to mineral sediment. Find the location and cause of the block and correct it.
** Clean the brew unit (see cleaning instructions) and make sure that
a- the ground coffee used is not powdery fine.
b- The dose of coffee grounds is not in excess specification
c- check if there is blockage. Find the cause and remove it.
8- If steam and hot water flow is normal, but the ventilate sign persists, then the flow meter or the electronic control board is bad. Replace flow meter or the control board, as necessary.
Try also the following:
  • Press hot water button once. Message on the screen will not change, this is normal.
  • Open the steam knob and allow the water to flow freely from steam wand into a cup. The screen should now read "Hot water,ventilate", you may need yo empty several cups of water before message changes. In some case it is necessary to refill the machine container without interrupting the operation.
  • As soon as the screen displays "hot water," turn the steam valve off .
  • If the machine warms up again, then problem is fixed.
on Jan 21, 2011 | Saeco Magic Comfort Plus Espresso Machine
I have a gaggia deluxe coffee machine which won't dispense coffee. the pump works with the steam nozzle and I've checked the guidance on the possibility of an air lock, and dispensed a lot of water...
it can be 3 problems, you can eliminate them 1 by 1 in this order:
  1. Calcium in the boiler > you unscrew the filter&filter holder(2 bolts) than you unscrew the screw in center (you see it after disassembling filter holder). If it is full with calcium, the pipe which goes vertically up for few centimeters you can drill it with 3 mm drill BUT AFTER YOU TAKE OF THE FINAL 4TH BOLT. You continue and release the short pipe and provide flow from boiler, test it and clean it than with decalcifications'(it will be more easy for you)
  2. We suppose case 1 isn't, and u have flow after unscrewing the 4TH bolt, than you must check the pressure valve (it returns the higher pressure with dispensing water back to container. Follow the short rubber pipe and you will find it. check the gasket and functioning of it
  3. Pump could be to week with pressure that she can't open the spring of valve above 4TH bolt, in this case you need to change pump.
Mar 02, 2011 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Hi, We have just bought a DeLonghi Caffe Treviso. We are not able to get any coffee/liquid to drip out of the filter holder. The problem seems to occur when we are trying to preheat the machine, for...
Sounds like you need to prime the water pump. Remove the filter holder, open the steam knob and then press the coffee delivery switch. Wait for water to flow consistently from the steamer and then close the steam knob. Water should then be forced to flow through the goup head (coffee head). If you cannot get water to flow from steamer then the pump may have already been damaged or it may have been faulty from the start. If water will flow through steamer but not for the coffee, then the group head is blocked. Good luck hope this helps and remember that all machines should be primed like this before use.
Dec 15, 2010 | DeLonghi Perfecta ESAM5500 Fully Automatic...
My shaerer expresso machine (ambiente) is giving error, level steam probe, when this happens it will not steam. This problem does not happen all the time and can be cleared by shuting machine off then...
"level steam probe" occurs when it takes more than two minutes to fill the water in the steam boiler. The easiest solution is low water pressure to the machine. Does it have a water filter? replacing it will probably help. Other problems could be the fill valve is not opening fully and or scaled water lines going to the steam boiler. The first thing I would do is activate the hot water tap and look at the pressure. If the water is coming out slow then I know its a restriction to the machine.
Nov 10, 2010 | Schaerer Siena Espresso Machine
Leaking water from steamer
For the grouphead check the basket there might be a slight bump around the edge that is preventing it from making a good seal when it contacts the gasket in the head. If the Double works fine then the gasket is not the problem.
For the steam wand try flushing wand for 3 seconds just before steaming, if that does not help with the watery milk, then the boiler is not getting hot enough to produce steam.
May 18, 2009 | FrancisFrancis! X1 Espresso Machine
THE Machine is not heating the water.
You may have a restricted flow meter. If the flow meter does not spin when you open the steam knob the boiler won't heat. A chip of bean that got into the water receptacle and when the water tank was replaced the chip flowed to the flow meter and restricted it. Now it won't spin and the boiler won't heat.
Apr 03, 2009 | Saeco Vienna SuperAutomatica Coffee...
Water on top of the filter after brewing
my experience with this machine is that this varies greatly with the type of beans you use. I would experiment with a few types of beans, roasts, and you might get lucky.
Nov 28, 2008 | Breville ESP8XL Espresso Machine
No hot water or steam
Well, I have little exposure to Saeco, but a lot to commercial coffee machines.
Saeco have a lot of custom made components, although these can be purchased, nothing is cheap! Neither is their repair service!
First, is the boiler heating?? If so:
No hot water/ no steam suggests a blockage. Assuming you can hear the pump working when attempting to do a coffee, you will probably find the water flowing back into the water tank via the relief valve. Of course, this valve itself could be the problem, or the pump failing to work through a blocked inlet filter or other problem.
Look now at the group head. Ever cleaned it? The filter and spray block should be removable, do so and clean them carefully. While you have them out, see whether water reaches the head by "making a coffee" into a cup placed under the head. BE CAREFUL OF SCALDING. If water now flows, cleaning the screen and spray block should restore operation.
Beyond that, it's inside the machine! There is a 3- way valve that operates when making a coffee. This can become clogged with coffee. There is another valve to open the steam.
If, like Saecos I have worked on, the boiler does both the hot water and the steam one at a time, look for problems BEFORE the boiler.
Hoe this helps a little....
Jan 19, 2008 | Saeco Vienna SuperAutomatica Coffee...
Silvia
there are two class of expresso coffée: one produce crema and the other none. A 9 sec shot, means you are putting ground coffee that are way too coarse. The Silvia requires coffee grounf extremely fine, near powder texture.
Hope this help
Dec 28, 2007 | Rancilio SILVIAespresso&cappuccino machine
Coffee Makers & Espresso Machines Logo
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
