Question about Royal Vacuums
Royal 4000 vacuum wheel adjustment
Adjustment on the rear wheel came apart when lifting unsure how to out ti back together.
5 Suggested Answers
Kazong
  • 152 Answers
SOURCE: Hoover upright vacuum information
cant help with manual but if i may why would u take it apart theres not much to service but to take the belt off turn the machine over and down by the roller there are a few screws take them out the cover should come off and thats it
Posted on Feb 06, 2008
WonderTech
  • 268 Answers
SOURCE: Problems with Royal 4000 Classic Bagged Upright Vacuum?
Try this site.
https://www.2instructions.com/search.php?cmarque=ROYAL&modele=4000%20CLASSIC
Posted on Aug 06, 2009
  • 175 Answers
SOURCE: replace wheel axle on my kirby g3 vacuum. have a
The spring goes inside that pedal that you step on to advance the height. Place that spring in that pedal and then place the pedal into its' groove, then put the axile and wheel assembly over the pedal and put your screws back into the mounting sections.
Posted on Jan 01, 2010
small6363
  • 18391 Answers
SOURCE: what type of bag does the 4000 classic commercial need?
Go here for the bags > http://www.vacuum-depot.com/royal_vacuum_bags.asp
Posted on Nov 26, 2012
G series kirby ultimate the wheel fell off and its on the side with the height adjustment....all fell on to floor when it came apart....how does that wheel stay on is there a part missing or do you just...
I cleaned the end of rod and the hole in the wheel, and then forced the wheel back on the rod. A little bit of glue at the end of rod will help to keep wheel stay.
Apr 21, 2011 | Kirby G5 Bagged Upright Vacuum
How to get the vacuum apart to change the belt
Turn power nozzle bottom up.
Remove the 5 screws.
Insert tip of a standard screwdriver into each square hole on either side of the wheels and twist to release the tabs.
Holding the power nozzle together, turn it over.
Lift the back of the cover up, then remove it.
Remove the screws at the ends of the brush.
Lift out brush.
Remove belt and replace with new belt.
Place brush back into slots and replace screws.
Check belt to make sure it's settled correctly and check tautness. It should have some give, but not much.
Replace cover by inserting front lip into the slot at the front of the base. Carefully manipulate into place, ensuring the latches click into place.
Turn PN bottom up.
Replace screws.
Feb 25, 2011 | Electrolux Epic 3500 Vacuum
How does a electrolux Epic 6500 come apart to replace cord?
The top and bottom of the canister need to be separated to gain access. I don't recommend this being done by the owner as it is tricky taking it apart, and even trickier reassembling it. Please take it to an authorized Aerus Electrolux store for a trained service tech to repair.
I've seen many vacuum come in to the shop due to the owner being unable to put it back together, putting it together incorrectly , and/or having broken pieces.
http://www.aerushome.com/storelocator/
Jan 18, 2011 | Electrolux Epic 6500 Vacuum
How to clean turbo brush of harmony electrolux and put it back together properly
Wait, there are two more screws that must be removed before the top shell will come off. They are located under the wheels. Pop the wheels out by simply inserting yoru finger or a small tool into the wheel and pulling straight up. Remove those two screws and then you can proceed as mentioned above.
When reassembling the head, if the shell does not snap back onto the base, check for plastic chips or other debris in the narrow slots on the underside of the shell. Clear these slots out and the head should easily snap back together.
Dec 02, 2009 | Electrolux Harmony Canister Vacuum -...
Electrolux z4494 vacuum cleaner mains cable wont stay out
Opened up case as follows:
- Open lid of bag chamber. Remove lid by gentry prising the hinge arms slightly further apart so the hing unclips from the body.
2 deeply recessed screws now accessible at rear edge of bag chamber - undo.
Prise out large button of on/off switch to reveal another screw - undo
Prise out large button of cable retract to reveal another screw - undo.
Cover now lifts off.
Inside I found the brake wheel had fallen out of its plastic bracket. The plastic bracket is hinged, and moved my pressing one end with the big button, which lifts the wheel away from the cable drum. Gently prised the bracket arms apart and put the brake wheel back in.
Solved it - but don't know why it happened, or whether it is likely to happen again.
Sep 01, 2009 | Electrolux Vacuums
Try this site.
Aug 05, 2009 | Royal 4000 Classic Bagged Upright Vacuum
Brushes wont turn on shampooer
Dear Momneville
I have the same steamcleaner and had the same problem, I took mine apart a found a clog between the turbine and the wheel that the turbine moves by vacuum when it gets glogged there is no vacuum to move the wheel. If you are not mechanically inclined in suggest you do not take it apart unless you think you can get it back together properly.
Hope this helps
ahill_1
Dec 24, 2008 | Hoover F7220900 SteamVac V2 Upright Vacuum
Problem with wheels
If the belt is over a year old, it should be replaced. This is normal maintenance and is often overlooked. When the handle is in the upright position, it will appear the the height adjustment is not working. What's actually happening is that the height adjust is easily moved so you can make any adjustment you want. When the handle is pulled back, the front of the machine will lower to that setting and lock, so it will not adjust itself while you are vacuuming. If you wish to change the setting, you have to return the handle to the upright position, or you can lift the front of the machine with your hand, taking the weight of the machine off the wheels and this will allow you to slide the adjustment to another position. It is possible that the adjustment mechanism has come apart. It is comprised of three separate components. It would be very difficult to explain it here and should be addressed by someone familiar with this model.
Jan 12, 2008 | Hoover U5264-930 TurboPower Bagged Upright...
Can't open rear compartment
To seperate the two body halves: 1-Set the vacuum on it's wheels & open the front door. 2-Place a wide screwdriver blade just between the reaer cover and the rubber bumper and tap the screwdriver on the side to push the bumper forward towards the door a little bit. 3-Grasp the bumper and pull it straight out. 4-Leave the vacuum halves together...flip the vac over on it's top. 5-Put your palms against each wheel with your fingers in between the body halves..pull each side out just a little and snap the lower body upwards. It will then come apart. 6-You can then mark the wires on the cordwinder for corresct replacement afer the repair. Make sure you put the bumpers back on each I-Beam before you put it back together. (they don't need to be removed). And the FLAT end of the rubber bumper is against the front door. Good Luck !
Aug 30, 2007 | Electrolux Epic 6500 Vacuum
Vacuums Logo
15 people viewed this question
Top Royal Vacuums Experts
Electroboy
Electroboy
Are you a Royal Vacuum Expert? Answer questions, earn points and help others
