Question about 1991 Nissan D21 Hardbody Pickup Gray Window Crank Handle Pair New
Heater switch quit working
Yesterday I went to warm up my truck and the switch was not working. Air comes out of the vents, warm and cold regardless if they are on, but the switch is not coming on
    Sergeant:
  • 181 Answers
Hello. Check the fuse for the heater.
Posted on Apr 19, 2014
  • Briana
    Briana Apr 19, 2014
    checked the fuse its fine, im thinking its the fan
  • DJ CRO
    DJ CRO Apr 19, 2014
    Hey me again. The good thing is that something is good. Now your truck is a 1991, well, the best thing to do is go to a well know junkyard that have good condition items. Junkyards will charge you a higher price if they take it out, but they will give you a smaller price if you take it out. So, if you can do it, then more power to you, but if you can not, have a friend to come along with you.
Heater Switch
Switch could have burned out,but not likely.Use a hot and ground wire to the motor after unplug the wires to see if motor runs.First,after unplugging the motor,flip the switch on and check power on the plug with a test light.
Apr 17, 2014 | 1991 Nissan Pickup
Water gurgling in heater, heat is warm, air is very light coming out of the vents, sometimes air goes cold then comes back warm.. a bump will make it go cold
it's look like the a/c evaporator is block by dirt,oil look at it ..It should be clean as this one
hope it helps
Apr 04, 2014 | 2000 Chevrolet Blazer
The air works but when switch to warm still cold
Check the heater core. If the vehicle is warmed up and no warm air will flow out the vents when you raise the thermostat, then it's most likely the heater core.
Mar 10, 2013 | Cars & Trucks
No heat just cold air
Is the gauge showing the engine is warming up to normal temp ?
Are the heater hoses getting hot ?
If the heater core is getting hot, it could be a blend door problem. The blend doors direct air thru the heater core and the ac evaporator among other things.
Dec 06, 2012 | 2005 GMC Yukon
Ac compressor wont engage on its own
there is a low pressure shut off switch to prevent compressor damage charge the system before testing anything else
Jul 10, 2012 | 1997 Chrysler Concorde
4.6 liter has one heater hose warmer than the other. may be plugged core,or is ther a fuse to climate control switch?
Look for a heater valve on one of the hoses if there is no valve i would say its a plugged heater core.
Dec 11, 2009 | 1999 Ford F150 Regular Cab
1999 Suburban, A/C on warm air from front vents, cold air in rear
The car uses the same freon in the front as it does in the rear. If the rear a/c is working, you either have a plugged evaporator in the front unit, or perhaps a bad heater switch. Try switching the heater to hot and see if it blows even warmer air from the front vents. If so, the heater switch is working and then it sounds like a plugged evaporator or maybe a plugged orifice tube. That is a good place to start looking. Hope this helps.
Jul 07, 2009 | 1997 Chevrolet Suburban
Cold incoming air with warm air
heater box is warped doors not closing fully
Dec 30, 2008 | 2004 Chevrolet Venture Passanger
Delayed or intermittent heat
after checking the heater core hoses they were both hot I went in to look at the blend door and noticed it wasn't moving on hot or cold so I simply disconnected the lincage and moved to hot and its working ok. but its not completely repaired
Oct 27, 2008 | 2003 Jeep Liberty
1991 Nissan D21 Hardbody Pickup Gray Window Crank Handle Pair New Logo
59 people viewed this question
Top AM Auto Parts Vehicle Parts & Accessories Experts
Todd Arndt
Todd Arndt
noagge
terry stevens
Are you an AM Auto Parts Vehicle Part and Accessory Expert? Answer questions, earn points and help others
