Question about Epson Office Equipment & Supplies
How to re-fax pre-scanned documents - Epson Office Equipment & Supplies
2 Suggested Answers
  • 628 Answers
SOURCE: Faxing and Scanning Original documents won't go through feeder on Toshiba EStudio 352, any suggestions?
Click the "Edit" tab, make sure the "SADF" is not enable...
Posted on Jul 11, 2012
How do I scan document to my pc
To scan using Windows Fax and Scan
  1. Place a document on the scanner, or, if the scanner has a document feeder, place one or more pages in the feeder. ...
  2. Click the Start button , click All Programs, and then click Windows Fax and Scan.
  3. To use Scan view, at the bottom of the left pane, click Scan
More Help:
How to Scan from Printer to Computer
How to Scan Document in Windows 7
Use your computer to print scan and fax
Mar 02, 2015 | Samsung SCX 4623F - multifunction fax /...
Scan driver
What problems do you have with your scan driver????
If you need to scan a document, and you have problems with your scanner, you can use the Popfax service:
1. Subscribe for Popfax fax email paid or free offer
2. Send the document you wanted to scan by fax, from your fax machine to the Popfax fax number
3. ou will receive the document in PDF on your email .
Easy and cheap! Try it now!
Jul 11, 2011 | Office Equipment & Supplies
The receiver of my FAXes says that there is a black line down the middle of each page. The FAX is a good copy-clear, etc.... but this line has to go. What can I do? Thanks, Donna
Dear Donna,
When a document is scanned from the top portion of the printer, it will loop around and output from underneath. The scanning glass on the far left side will have some debris on it. Lift the the lid exposing the glass portion, inspect for "stuff" on the glass, perhaps pen or white out. You can use a mild soap and lightly dampened cloth to remove any debris.
Good Luck,
Pre
Jan 14, 2011 | HP OfficeJet 6210 All-In-One InkJet...
Scanning the document
I'm confused? The listed product is a Fax/Modem, not an all-in-one. It doesn't have a scan function. To send a document via a fax, you will need to scan it with a scanner (separate hardware) and then fax it. In Windows 7, a program called Windows Fax and Scan is included. If the devices are installed with the correct drivers, you can do the two steps in one program. Open the program, click on New Fax. Select Insert > Pages from Scanner (only available if the scanner was on and connected when Fax and Scan was started). Scan the document; fill in the contact information for the receipient and send. The Contact information may take a few steps since it is a Windows Contact page.
I hope this helps.
Apr 09, 2010 | Hiro V.92 56K PCI DATA FAX VOICE MODEM...
How do i scan photo's to my computer?
If you have the software installed that came with the printer then that has the facilities you need. It will step you through the process offering you options to improve the scan results.
If you have microsoft office (pre 2007) then there are also some easy options to scan documents or pictures directly into your work.
Many other graphics programs also have the option of "aquire image from"
These sort of options also make it easy to scan and fax if you have a modem installed.
Aug 10, 2009 | HP Photosmart C6280 Printer
My kodak 5500 all in one inkjet printer will send fax, but comes thru blank at the other end. Yes I have the document with lettering up like it says.
The problem, more than likely, is the quality of the scan. The 5500 sometimes overexposes the original. Test the scanner by scanning the document tou want to fax using HomeCenter software and looking at the screen preview. You can make some pre scan image density adjustments by changing the fax settings brightness setting to low (1 or 2) and changing the color setting.
Apr 30, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
I HAVE A PANASONIC FAX kx-FPG376 IT WONT SEND FAX MAKES COPIES AND RECIEVES FAXES
I dont know how we got disconnected but here is the instructions
Adjust the width of the document guides (1)
to fit the actual size of the document.
2 Insert the document (up to 10 pages) FACE
DOWN (2) until a single beep is heard and
the unit grasps the document.
L If the document guides are not adjusted
to fit the document, re-adjust them.
3 If necessary, press {A} or {B} repeatedly to
select the desired resolution.
4 Press {DIGITAL SP-PHONE}.
5 Dial the fax number.
6 When a fax tone is heard:
Press {FAX/START}.
When the other party answers your call:
Ask them to press their start button. When
the fax tone is heard, press {FAX/START
To redial the last number
1. Press {REDIAL/PAUSE}.
2. Press {SET}.
L If the line is busy, the unit will automatically
redial the number up to 2 times.
L To cancel redialing, press {STOP}.
To send more than 10 pages at a time
Insert the first 10 pages of the document. Add
the other pages (up to 10 at a time) before the
last page feeds into the unit.
Pre-dialing a fax number
You can dial the fax number first before inserting
the document. This is convenient if you need to
refer to the document for the other party’s fax
number.
1. Enter the fax number.
2. Insert the document.
3. Press {FAX/START}.
Sending from memory (Quick scan feature)
You can scan the document into memory before
sending it. To use this feature, activate feature
#34 (page 62).
1. Insert the document.
2. Enter the fax number.
L The document will be fed into the unit and
scanned into memory. The unit will then
transmit the data. If the document exceeds
the memory capacity, transmission will be
canceled and this feature will be turned OFF
automatically. You must transmit the entire
document manually.
L This feature cannot be used if {DIGITAL SPPHONE},
{TALK} or {SP-PHONE} is
pressed.
To stop transmission
Press {STOP}.
Aug 27, 2008 | Panasonic Office Equipment & Supplies
Send Fax Issue
I have a brother intellifax 770 and I bought it used so their for I do not have the owners manual and I am having trouble setting it up and getting it to work. I can fax out but I just can't recieve faxes I can fax my daughter but when she faxes me she gets an error of 388 but she is able to fax and recieve faxes so we know her end is not the problem.
Aug 20, 2008 | Brother IntelliFAX 4100 Laser Fax
I want to scan then send instead of scanning whilst sending
There are 2 methods of sending 1. Through memory, in which the machine scans the document then sends when all pages have been scanned. 2. In real time, in which the document is placed in the ready mode and the line monitor or handset is used to dial the number. In this case the document is not scanned until a response is heard from the other machine.
However, in the case of the memory being full, either of documents in the queue or if there are documents waiting to be printed (because of no toner or no paper) then the machine will not allow sending from memory.
Feb 07, 2008 | Canon FAX-L200 Plain Paper Laser
11 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
