Question about Bissell Healthy Home HEPA Bagless Upright Vacuum - Metallic Blue
Brand new Bissell Healthy Home 5770H Upright will not turn on.
It's only been used once and has been sitting for a few months. We get nothing when we push the on button. Tried different outlets. It's clean since it hasn't been used much. I will check to see if the assembly is tight like someone suggested.
If the brush attachment isn't locked into place than the vaccuum will not work make sure it is attached properly.
Posted on Jun 28, 2009
  • 328 Answers
Try and see if the fuse in the plug has gone - it may need replacing rather than a fault with the Bissell
Posted on Jun 19, 2009
Bissell healthy home vacuum will not turn on. I have checked everything on the vacuum. All the filters are clean and there are no clogs. I have had it for 10 months with no issues until now.
- The handle may not be installed properly, causing a loss in the power connection. Remove the handle completely. Slide the handle back into place on the lower section of handle and tighten the screw.
Jun 06, 2010 | Bissell Healthy Home HEPA Bagless Upright...
Brush won't turn.
Is the grey "brush" button on the handle depressed? Brush won't turn unless the button is down
Feb 03, 2010 | Bissell 5770 Healthy Home Bagless Upright...
The motor for brush won't turn on for the bissell healthy home vacum
Jan 01, 2010 | Bissell 5770 Healthy Home Bagless Upright...
Motor that turns belt and brush isn't working
Are you sure it isn't the belt? If it is worn it won't turn the brush. If it is the belt then you can get them here:
Bissell Healthy Home Replacement Belts
Nov 11, 2009 | Bissell Healthy Home HEPA Bagless Upright...
Bissell healthy home won't stay on unless i hold the start button
We had the same problem. Open the handle by undoing the screws and then pull one side off. Depress the button a few times and see if it catches. It worked for us and now it is just like it should be again. Good luck!
Oct 31, 2009 | Bissell Healthy Home HEPA Bagless Upright...
The brushes on my new healthy home vacuum wont rotate when the machine is turned on how do i access the belt location
If you turn the vacuum over so you can see the brush roll, there is a brush cover that is held on by (4) screws. Remove those screws and the base plate cover will come off. With the base plate cover off you can access the roller brush an belt. If you need a replacement belt you can get it here:
http://www.vacbelts.com/bissell-healthy-home-belt.htm
Oct 23, 2009 | Bissell 5770 Healthy Home Bagless Upright...
Bissell Healthy Home Agitator Brush Switch
you might have a bad belt ,could be stretched .but if its new i would take it back to where you bought it.it should still be under warranty
Mar 29, 2009 | Bissell Healthy Home HEPA Bagless Upright...
Bissell Healthy Home HEPA Bagless Upright Vacuum - Metallic Blue Logo
330 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
