Question about Dell 5650 Computer Speakers
Dell 5650 5.1 speakers yellow, black, p green wires. new dell computer no yellow spot. speakers don't work
  • 3 Answers
What you need is a splitter and not an adapter. Forget the colors yellow, green, black. They are not relevant. The business end of those colors occur inside the box. Dell manufactured these "bass ackwards". You need a 3-way headphone splitter and that will solve your problem. I bought a RadioShack Headphone Splitter Cable model 42-2458. Hope this helps. Just plug into headphone outlet
Posted on Oct 09, 2016
SOURCE: Dell 5650 computer speakers
same thing here just turned off and now has no power , checked the fuse it looked good , plug it in a different outlet and no power . I am going to throw the speakers out in the street and cut my losses .... another fine product sold by dell
Posted on Mar 25, 2008
SOURCE: dell 5650 speaker wire adapter
As I understand it, this adapter is used ONLY to adapt a standard 2-channel stereo output to the 3, 1/8" plugs of the Dell 5650 5.1 system. These 3 plugs would normally plug into the front, rear, and center/sub outputs on a computer designed to output 5.1 channel sound.
To make this clear, what this means is that the output you get from your 2-channel stereo system, using this adapter with the Dell 5650 5.1 system, will NOT be full 5.1 surround sound...it will be 2-channel stereo signals intermixed so that it plays from the 5650 system through the Dell amplifiers and speakers...nothing more.
This cannot be over-emphasized. The adapter does NOT create true 5.1 sound from a 2-channel stereo output system.
If you are hoping to get true 5.1 output from a 2-channel stereo system, you will be disappointed.
All this adapter likely does is split/mix some of the 2-channel signal into the rear channel, and split/mix some of the SAME 2-channel signal into the center-sub channel, just so you will get some output from those speakers. There may be some low-pass filtering for the sub-woofer input.
It is almost certainly a very simple passive circuit consisting of resistors, capacitors, and possibly an audio transformer or two.
Look for circuit on Do-It-Yourself electronic sites and build it yourself...or you're almost certain to be ripped-off.
Posted on Jan 19, 2009
  • 7 Answers
SOURCE: Dell 5650 Speakers on Gateway DX4200
the speakers should have a stereo jack on a wire which would be the out put, if it is a surround sound speaker system then it most likely will have a few wires, if your computer has only one stereo jack input then the green cable would be the one you would connect in most cases, if it has 3 or 6 then you would follow the colour on the jacks and match them up with the input on your computer. if you have done all this and doesnt work check if there is audio icon in the bottom left task bar and if you can use other speakers, if you can everthing should work, if not then check for drivers online.
Posted on Feb 11, 2009
SOURCE: 2 Dell 5650 have no sound
the surround sound speakers plug into the rear of the computer with three plugs. an adapter comes with it to plug those three into one green plug. if you plug that green plug in, the rear and center speakers should work, although i don't know if the surround sound will work correctly but you should get sound
Posted on May 06, 2009
paul7of9
  • 1189 Answers
SOURCE: i have the Dell 5650 Computer Speakers and first 2
Hi, these instructions will help you with the Audio problem. These are the steps to setup and 'restore' the “Audio Drivers” Part (1) Click on the "Start" button, go to and click in the (right, pane) Control Panel.
Scroll to find, "Ease of Access (or) Speech Recognition Options. Click, on" Replace sound with visual cues."
In the See also: (Category), click, on “Audio Devices, and Sound Themes” click, “Playback” Next, click on the Active "Speakers.” Click “Configure” to "Audio channels" The (Speaker Setup) "wizard,” appear! Select (Test) click, Next! Follow the instructions. Part (2) Click 'Properties' change the "sound"(Level). Click on Enhancements, "Apply" changes. “The (Advanced),“not recommended!” In, the Controller Information (block), click on, Properties to "update" Drivers. Check to see if Device usage: (enable) if not? "Change it." *Note: Click "OK" to all change; 'Save' and Apply!, before exiting. “Did this solution help?”
Posted on Feb 03, 2010
Dell 5650 speakers
Try plugging into light green if basic card or integrated system (built into motherboard). If it is a aftermarket Card Check owners Manual on CD that came with card or go to MFG website and search your with your model # for manual and/ or specifications on hardware.
Apr 14, 2014 | Harman Kardon HK595 Computer Speakers
Hi, im searching for the stereo wiring chart for my mitsubishi lancer 2002 GLXI. i have searched for it but the colours are completely different to what i have. For example the colours i have are - Blue/...
This is all I could find. Hope it helps.
WIRE COLOR POLARITY LOCATION
Battery RED/BLACK (+) RADIO HARNESS
Accesory BLUE (+) RADIO HARNESS
Ground BLACK (-) RADIO HARNESS
Illumination GREEN/WHITE (+) RADIO HARNESS
Power Antenna YELLOW (+) RADIO HARNESS
LF Speaker (+) WHITE/BLUE
LF Speaker (-) BLACK/BLUE
RF Speaker (+) WHITE/RED
RF Speaker (-) BLACK/RED
LR Speaker (+) YELLOW/BLUE
LR Speaker (-) GRAY/BLUE
RR Speaker (+) YELLOW/RED
RR Speaker (-) GRAY/RED
Apr 14, 2011 | 2002 Mitsubishi Lancer
Is there a way to connect my Dell MMS 5650 speakers to a Macbook Pro laptop or a wireless router? Where can I find cables for converting? Thanks!
The speakers should directly connect to the "line-out" socket on your Macbook computer, without any need for adapters.
I have _never_ seen a wireless router that had _any_ "audio" capability -- what you're asking for seems to be unreasonable.
Any "Dollar Store" or the "big-box" stores (such as Best Buy, Office Depot, Staples, Future Shop, Wal-Mart) should have adapter-cables.
Aug 19, 2010 | Dell 5650 Computer Speakers
Rear Speaker delay
It will not be the length of the wires, as the signal travels at close to the speed of light!
If the connections to the speakers are bare wires the cause is probably that you have wired the speakers with opposing polarity. Check the wiring and ensure that positive (red) is wired to positive on the speakers.
The speaker cable should be marked in some way to indicate which core is which. It doesn't matter which core you use provided that you wire red to red and black to black, or whatever other colours your output and input have.
Apr 01, 2010 | Dell 5650 Computer Speakers
Are these speakers adaptable with my Compaq Presario PC?
Hello my friend, with regards to your problem first we must check if your currentl audio device is compatible with your speakers. I mean you have a 5.1 speaker then let us check if your audio plugs is also a 5.1 channel in order to accomodate your speaker. else you can istall your speaker in to your currentl audio device but not all speakers were work cause it needs to have the same specs from your speaker to your audion device installed in your computer.you can only use the green, and blue then if you have mic the you could used the pink plugs but for your black plugs in your speaker it cannot be used.
Jun 16, 2009 | Dell 5650 Computer Speakers
Apr 03, 2009 | Dell 5650 Computer Speakers
No sound from speakers when in rear speaker port
you need to download the drivers, or check the volume control on the quink lanch in the right hand counter
Feb 14, 2009 | Dell 5650 Computer Speakers
Feb 10, 2009 | Dell 5650 Computer Speakers
Dell 5650 speaker wire adapter
Dec 16, 2007 | Dell 5650 Computer Speakers
Dell 5650 Computer Speakers Logo
221 people viewed this question
Top Dell Audio Players & Recorders Experts
jairo sanchez
Greg Cann
Greg Cann
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
