Question about Husqvarna POWERCUTTER/HEDGE TRIMMER HOOK - HVA 531 03 09 20
2 year old husqvarna k760 powercutter. It would bog out and die under load. I noticed the intake tubes were cracked. Once changed and re-assembled, It wont start. Seems to not be getting fuel. anyone
New spark plug, compression perfect and new intake tubes. No fire and im confused.
  • 425 Answers
Are you referring to the fuel lines and if so did you get them mixed up and hooked on the wrong carb inlet? If so try reversing them and see if it starts.
Posted on Jun 21, 2014
Dies when opening throttle
Hi, Anonymous and the usual suspects are:
1. Idle circuit and transfer ports clogged.
2. Air fuel mixture adjustment too lean.
3. Pilot jet clogged.
4. Faulty accelerator pump.
5. Float level too low.
6. Float bowl contaminated old fuel, water, dirt, rust, etc.
7. Float bowl vent or overflow tube clogged.
8. Fuel flow to carburetor restricted.
9. Intake manifold leak.
10. The gas cap is not venting properly or fuel tank venting system blocked.
11. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
12. Needle and seat stuck closed in the float bowl.
13. Multi carburetors not in sync
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
2006 yamaha ttr 125 dies when give little throttle
hesitation bogging ttr125 TTR
OEM parts for Yamaha
http://www.tjsconcepts.com/ttr225/TTR225_Service_Manual.pdf
http://www.tjsconcepts.com/ttr225/TTR225_Owner_Manual.pdf
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 22, 2014 | 2003 Yamaha TT-R 225
2006 ttr 50 dies when giving gas
Hi, Jason and the usual suspects are:
13. Multi carburetors not in sync.
TTR50 bogs and dies when twisting throttle
http://www.r6messagenet.com/forums/general-motorcycle-talk/93609-bike-idles-but-dies-when-i-give-gas.html
YAMAHA TT R50E Owner Service Manual
Yamaha TT R50E Owner Manual
Nov 15, 2012 | 2003 Yamaha TT-R 125
2000 Chevy Malibu 3.1 - starts rough on cold morning
Sounds like you have a vacuum leak somewhere in the engine's intake manifold. Put a vacuum gauge to it.
Jul 29, 2017 | 2000 Chevrolet Malibu
I have a 1994 mercury 90 2 stroke . I have replaced trigger , power pac , plugs , fuel filter and coils to start . It run good up to 3100 rpms then bogs down like it only runs on 2. cylinder ! What could...
Have you checked the "Fuel Pressure Regulator", the ethanol in gas these days can cause the tubes to swell and crack... also the little diaphram inside the regulator can get stuck causing the motor to bog down under a load. if you have a book you can locate it. if not you can likely go to Boats.net and enter your motors serial number to seek out parts and it will usually take you to different schematics and diagrams for each part.
I have a Mercury 115 four stroke and did all of the same things that you did... spent upwards of $1,000.00. to do a maintenance overhaul and it still bogged down when i got up around 2800 to 3100 RPM. it turned out to be an $85 part and about 45 minutes to change out my Fuel Pressure Regulator. Its worth a shot!
May 29, 2012 | Mercury Boating
I have a husky 371xp. the saw will fire up and rev up and down on its own with out me giving it gas. then once i do give it gas it will bog down and shut off. could i have some bad seals? or whats the...
Irractic and high idle is normally an air leak, so yes it could be crank seal leaking, or the induction tube cracked, or the impulse tube from the crankcase to the carb cracked, or the cylinder base gasket blown out.
Jul 08, 2011 | Husqvarna Chain Saw 20" Bar
One question, im looking to buy a husqvarna k760 demo saw, i need to cut metal, such as truck and trailer frames. just need to cut them down to length so i can load and bring to scrap yard. i figure it...
The K760 black cutter blade is called a Cut-n-Break blade. The manufacturer states that it has an improved stable core to increase its performance. I have a friend who recycles scrap metal and uses the Mastercraft 5" dual cutter. It cuts through metal like butter without any kickback.
Hope this helps,
Handie Andie
Mar 26, 2011 | Husqvarna Garden
My 97 oldsmobile cutlass supreme is leaking coolant and over heating, why? I also noticed tht the oil is milky. Please help
The most likely source of your problem is NOT a head gasket or cracked head, but the black plastic plenum or "upper intake manifold". These GM engines tend to melt, crack, or warp the plenum because of the hot EGR tube sticking up through the plastic.
If water is getting into your oil (milky looking), your lower intake manifold gasket is probably cracked. Once the plenum is off the engine, there are only about a dozen bolts holding the lower intake manifold on. When you replace the gasket, it is recommended to use an ALL METAL gasket with rubber seals to prevent this from happening again. The metal gaskets cost about $80 where as the plastic ones that are prone to breaking cost about $45. Better to fix it right once than to do it wrong several times.
Also, if you are still using Dexcool coolant (orangeish), be sure to change it every two years or so as it does bad things to seals when it gets old.
Nov 13, 2009 | 1997 Oldsmobile Cutlass Supreme
Husqvarna POWERCUTTER/HEDGE TRIMMER HOOK - HVA 531 03 09 20 Logo
432 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
