Question about Dometic RM2620 Refrigerator
Blows heater element fuse when on
If i disconnect heater element fridge go on if i connect heater element i blow fuse
    Top Expert:
  • Dometic Master
  • 8,488 Answers
Replace heater element
Posted on Oct 06, 2017
3 Suggested Answers
  • 905 Answers
SOURCE: The fridge is blowing the 12 volt fuse as soon as
Unplug the wire located at terminal J4 (12v positive) on the control board, and see if you are still popping fuses. If so, then the fault lies between the wire you just removed and the fuse that keeps blowing.
If the fuse holds, and blows when you plug the wire back onto J4 terminal, then unplug the wire(s) at J2. These go to your door heater (used in humid conditions to remove condensation), as well as the interior light. The switch for the door heater is located on front panel, or is at the top edge of the freezer compartment with door open. It is not unusual for this switch to have issues since it gets chilled and moisture condenses on it. If unplugging the wires at J2 allows the fuse to hold, you probably got a shorted heater or bad heater switch. But, pull the lens off the interior light, and check the contacts there as well.
If the fuse still blows with J2 removed, then unplug the connector in the top left corner of the control board. This goes to the control panel on the inside of the fridge. If the fuse blows, replace the control board. If the fuse holds, the replace the control panel.
Posted on Jul 18, 2010
motor1258
  • 6674 Answers
SOURCE: RM2652 Dometic, blows 15A fuse in about 15 seconds
Sounds like you have a short in your heating element for 120VAC. I'd change it.
Posted on Jun 21, 2011
My hot tub will not heat up and the one pump is running. I can not turn the lights on or adjust the controls
check the fuses if no heat sounds like the pump that isnt running is the recirculation pump (which heater is connected to) if fuses keep blowing try disconnecting the heater element maybe shorted
Mar 04, 2015 | Jacuzzi Pool & Spa
Blowing fuses
Defrost element will be causing a short circuit. If the house fuse is blowing it would indicate that the value of the circuit breaker on the fridge circuit is too high.
Replace the defrost element .
Apr 08, 2014 | Angelo Brothers Westinghouse (r) Savona ES...
Spa has 20amp fuse that blows whenever I either restart spa or turn on jet pump. I disconnected pump and it ran fine until I restarted the spa and fuse blew again.
something is drawing a load when it shouldnt be. remove all circ pumps, booster pumps, and disconnect heater element. turn on hot tub and see if it trips. then do the same, re connecting the element, and pumps, one at a time. when it does trip, thats where the problem lies. bad pump or element
Feb 08, 2014 | Pool & Spa
3a fuse blows stat wiring good
Your heating element could be shorting out inside the tank.If you have 2 elements, disconnect one wire from the top one turn on. if the fuse doesn't blow then the top element is mad.try the same check on the bottom one ,dont forget to put the wire back on the top one first. remove fuse before you disconnect the wires.becarfull
Jan 17, 2014 | Water Heaters
My dryer stopped heating and i changed the vuse and blow again can u tell me whats the problem thank u
The blown fuse is most likely caused by a short circuit in the dryer.
The first component I would check is the heater element as this is a highly stressed component in any electrical appliance.
Replace the blown fuse, then disconnect the wires to the heating element( Make sure you insulate the wires so as not to cause a short circuit against the dryer body).
Now turn on the drier & see if the fuse still blows. If it still blows, the problem is then most likely with the drum motor.
If it doesn't blow, you have only to replace the heating element.
Best wishes,
Graemevm
Apr 12, 2011 | Dryers
The fridge is blowing the 12 volt fuse as soon as I power up the motor home, The fridge is turned off and it still blows the fuse, I tried to undo the 2 wires that go to the 12 volt block on the fridge and...
Jul 13, 2010 | Dometic RM2652 Refrigerator
AEG Lavamat 76400 during spin cycle blows a fuse
its not the heat element its the water pump i would say it has gone to ground try disconnecting the water pump if the fuse does not trip then replace the water pump
Jul 03, 2010 | Washing Machines
My washing machine keeps shutting down and blowing a fuse.
You must have a short circuit ,try disconnecting things start with the heater element, disconnect one wire see if it still blows...next try motor plug, until the fault clears at least this tells you what the problem part is.....
Apr 11, 2010 | LG WM-2077C Front Load Washer
Dometic RM2620 Refrigerator Logo
32 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
