Question about Samsung CLP320 AllInOne Laser Printer
Clp-325 samsung says door open but is not
When I want tro print the CLP-320 replies "door is open. close the door". But doors are all closed.
CompuFirm
  • 89 Answers
SOURCE: Samsung CLP-315 prints half a page and then stops
It sounds like your fuser is causing the jame,.
when you remove the paper can you wipe the toner off the page or does it adhear to the paper ?
If it does not the fuser is causing the jam, if the toner does not wipe off the paper then the feed tires would be the cause of your jam
The fuser is at the back of the printer and will be very hot, so be careful.
Posted on May 26, 2009
  • 406 Answers
SOURCE: Our Samsung CLP 300 's red light stays on..
Install a smart panel on PC and see the error on the PC screen.
Posted on Nov 02, 2009
  • 99 Answers
SOURCE: My samsung 315 clp has status LED red light on.
It is a color laser printer.it has 4 toner cartridge(1)black(2)magenta(3)cyan(4)yellow all cartridge is missing or toner finished.Please purchase full set toner.All toner cartridge has a image sensor.When toner is run out then it is out of work.
Posted on Dec 14, 2009
  • 11 Answers
SOURCE: my samsung clp-315w prints smudgy black lines
Cleaning my unit resulted in the solution of this problem. I removed the toner cartridges, the imaging unit, and the waste bin, opened the back door as well, and blew it out with "canned air". This will not solve all problems, but it is the right place to start. be careful to keep the imaging unit out of bright light when you you have it out of the printer.
Posted on Mar 21, 2010
autolatry
  • 115 Answers
SOURCE: CLP -315 Keeps telling me
the unit most likely has a damaged sensor. samsung actually offers a decent warranty and usually will repair manufacture defects in a timly manner.
Posted on Mar 07, 2011
CLP-320N KEEPS TELLING ME TO CLOSE DOOR...ALL THE DOORS ARE CLOSED
Most likely you should check the 'door open switch', probably its broken.
Apr 24, 2014 | Samsung CLP-315W Laser Color Printer
Samsung clp 320 'door open' problem
If the printer was just powered up and immediately gave the door open error, look for a paper jam. When this happened to me, that was the problem, even though it was saying that the problem was an open door.
Aug 01, 2012 | Samsung CLP320 AllInOne Laser Printer
My Samsung CLP 315w refuses to print a whole A4 page. Stops half way then message comes up paper jam but when I open back / front, paper not jammed and when I close it document continues printing then...
most likly hood is your exit sensor is faulty. The printer work in this way. if it does not print out all the document. it will print again. that is why you kept getting this same issue after a jam open and close door it will print again.
replace the exit sensor it will help.
Apr 16, 2010 | Samsung CLP-315W Laser Color Printer
Samsung CLP-315W Color Laser Printer will print only half page
http://www.fixya.com/support/t3934542-exit_sensor_problem_samsung_clp_315
Mar 23, 2010 | Samsung CLP-315W Laser Color Printer
Printed ok, then after last print orange light came on it it did not print again
check if there is a paper jam in ur printer also check if the cartridge door is closed
Jul 08, 2009 | Samsung CLP-315W Laser Color Printer
Samsung CLP-315 prints half a page and then stops & jams. Interior is clean. Our CLP-315 is doing the same thing. Only had it 6 months. The paper stops printing half way through and you have to open the...
May 26, 2009 | Samsung CLP-315W Laser Color Printer
Printing starts..then stops when paper is just appearing.
Replace the exit sensor clipped into the moulding above the fuser. (Very Common)
Mar 26, 2009 | Samsung CLP 315 Laser Printer
Open door problem
There is door sensor that will be broken during your unpacking ,its near the door that show error ,try to find it then you can remove it by unplugging the cable or repair it if you can ..
Jan 15, 2009 | Samsung CLP 300 Laser Printer
SAMSUNG CLP 500
The order iin which you open and close two of the covers is important, as there is an interlock between two of them. This can (and does) get damaged.
The toner access door is the first one you open, THEN the top cover (the one that gives access to the Transfer Belt and Drum.
Make sure the Drum unit is properly pushed into the printer, and that the Transfer Belt is lacated properly AND the two locking levers fot the Transfer Belt are in their locked positions PROPERLY.
THEN close top cover - you shouldn't need to force it.
Followed by the Toner access door.
Yes check the duplex door too !
If this fails it is likely to be a broken case part, or failed sensor.
Dec 26, 2007 | Samsung CLP-500 Laser Printer
Samsung CLP320 AllInOne Laser Printer Logo
73 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
