Question about GE Spacemaker WSLP1100D Top Load Washer
Water wont empty out of washing machine
Water not emptying
SOURCE:
gittos73
  • 244 Answers
SOURCE: water in machine under bucket
your outlet hose put it down close to the floor into a bucket if water comes out then your pump may have blown if not it will be blocked up u may find if u take the outlet hose of water may come out which means your pipe is blocked
Posted on Aug 12, 2007
  • 209 Answers
SOURCE: Washing machine not spinning
check for a capacitor on the motor if it has one, replace that to start with, that what it sounds like
Posted on Oct 10, 2007
SOURCE: wash machine won't empty the water.
There is a filter behind the bottom front panel of washer. Remove bottom three screws and remove panel. Get something to catch water. Unscrew filter. Clean out filter drain. Should be good.
Posted on Jan 04, 2009
  • 3741 Answers
SOURCE: machine wont agitate
If your washer doesn't agitate, check these:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it.
Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Transmission The transmission could have either of these problems:
  • Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may not agitate properly or at all.
  • The transmission may have a worn or broken gear, or some other internal problem.
If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
Agitator The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Posted on Aug 20, 2009
SOURCE: Our washing machine started leaking lots of water
My Maytag Ensignia washing machine leaks large amounts of water when filling and during spin cylce. What could be wrong?
Posted on Jan 04, 2010
Drum wont turn or empty water
depending on the model, a broken belt is a good possibility. if you hear the motor going, but the bowl isnt moving, that is a sign of a broken belt, it is also possible the motor has failed.
Nov 11, 2013 | Washing Machines
Wont spin
Probably down to the water not emptying from the machine in the empty cycle and the machine won't spin because there's still water in the drum. If this is the case, the root of the problem is almost certainly a blocked filter, restricting the draining of the water and not allowing it all to pump out in time during the empty cycle. You probably need to find and clean your filter.
Feb 02, 2010 | Washing Machines
Help my machine hotpoint ultima wma 60 wont empty water tried 5 times water sitting there had turn machine off
p my machine hotpoint ultima wma 60 wont empty water tried various times water sitting there had turn machine off
Dec 21, 2009 | Hotpoint Washing Machines
Bosch washing machine wont spin or empty
PAV2300 Top Load Washer This washing machine tutorial will show you what to do if the washing machine does not drain or empty the water out this repair was done on a Bosch, Neff and Siemens type appliance.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 20, 2009 | Maytag PAV2300 Top Load Washer
Hotpoint wma13 wont empty, think pump is blocked
Yes,
The water pump most be clugged and/or defective.
Aug 18, 2009 | Washing Machines
Washing Mashine draw Wont Empty
check the screen on the valve where the hose connects to the washer, it may be clogged
Jul 07, 2009 | Washing Machines
Washing machine wont empty removed screwable filter all water ran out still wont empty
This is a comment problem. The drain pump may be broken or jambed with lint from the clothing. Remove the pump and check its operation. I usually just replace the pump as they dont last.
May 12, 2009 | Washing Machines
hi there this is a common fault empty the water into a bucket and remove the water pump to check for blockages, the pump is located at the rerar lefthand side of the w/m.
also check your drain hose where it connects under your sink.
hope this helps
Dec 11, 2007 | Washing Machines
GE Spacemaker WSLP1100D Top Load Washer Logo
96 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
jimorris77
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
