Question about True T-35
Condensation on cabinet of True Freezer model number T-35
  • 884 Answers
Where is the condensation forming? Usually a door seal or door closure problem, or site conditions (high ambient). Make sure the condenser grille is clear and clean, as the thermostat can easily be fooled into running long periods
Posted on Apr 30, 2014
2 Suggested Answers
woodchuck789
  • 4070 Answers
SOURCE: water in cabinet of new TWT-60
The drain hole is at the bottom of the evaporater coils probably behind a cover inside. Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Aug 30, 2009
Freezer won't go below +30 F
Sounds like the condenser coil is dirty
Dec 19, 2013 | True T-35
True freezer T-35F shoudl it be running hard all the time?
Check and clean condenser regularly, check thermostat set at 2 or 3 and check fan is working ok. Apart from that, check the evaporator isn't frozen solid with ice.
Jul 01, 2012 | True 35 cu. ft. / 991 liter Commercial...
How To Replace Relay On True T-72 Reachin
If it's mounted inside a box along with the capacitors there is 1 screw holding it from the back. Often you have to unmount the box from the compressor to access the screw.
Apr 04, 2012 | True 72 cu. ft. / 2039 liter Commercial...
I have a bottom freezer refrigerator and the freezer works but the fridge does not,,condensation forms on bottom of fridge. What is going on?
Check in the inside rear of the refrigerator cabinet for vents.When you hear the compressor running, wet your fingers and hold them in frontof the vent to check for air flow.
If it seems there is none, then the fan that is supposed to distribute the coldair from the freezer is no longer running.
If this is true, go to the Sears parts department and enter makeand model number to see if they have a line drawing illustration of your unit.
This will allow you to see if this fan is accessible enough for youto DIY or if you need a pro.
Sears partsdepartment
Good luck-
Jun 19, 2010 | GE Profile PDS22MHR Bottom Freezer...
Water in cabinet of new TWT-60
Aug 30, 2009 | True TWT-60 Stainless Steel Commercial...
Ballast
You haven't supplied a model number... Makes a big difference. Generally speaking though you pull off the bottom louvered section and it will be inside of a post where the condensing unit plugs in or mounted against the sidewall.
Jul 04, 2009 | True 72 cu. ft. / 2039 liter Commercial...
Fan runs freezer and fridge don't cool
Please check the model number again, I can't locate that number. The number should be like for example 194.258978 Look at following areas for the model number
  • Beneath Or Inside Food Compartment On Cabinet Frame
  • On Plate Lower Front Or Rear Of Cabinet
  • Beside Compressor Door On Right End
  • Near Rear Of Cabinet
  • Inside Liner At Top
  • I think your refrigerator has a defrost timer and this may be the problem, Let me know what you find, Thanks, Sea Breeze
Mar 29, 2009 | Kenmore Refrigerators
True T-35 Logo
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
