Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
Clutch belt needs to be put on - Craftsman 42 in. Deck 19.5hp Lawn Tractor
  • 656 Answers
Go to craftsman lawnmowers .com for belt installation instructions and diagrams. Hope this helps, plese post solved on fixya.com.So I get credit for a solved problem if it does. If not, check back and give me more info.
Posted on Apr 24, 2014
1994 Polaris 300 4x4 want shift into high range just grinds
Bad linkage between shift lever and the transmission.
Apr 07, 2015 | ATVs
I have just fitted a new transmission belt to my westwood 1012, it will go into gear when the motor is off but when the motor is running the gears will not engage when the clutch is pressed
You've probably put the belt on incorrectly or not put the clutch wheel or spring back correctly. When you press the clutch a jockey wheel on the drive belt should release the tension, allowing the belt to slip and the gears to be engaged.
Oct 28, 2013 | Craftsman 20 Hp 42" Deck Lawn Tractor
Replaced drive belt for beater bar, but now beater bar motor will not engage/turn on.
The most likely problem is something was not put back together properly in the clutch. You can move the belts by hand with the clutch out of the machine. Move the motor belt and switch the lever off and on and see if the brush belt is turning on and off. It not you will need to take the clutch apart and reassemble it. Test it before installing.
Sep 10, 2013 | Dyson DC07 Animal Bagless Upright Cyclonic...
It jumps and jerks when driveing it
Problem is more than likely a burnt belt. The belt gets smooth spots on it causing it to slip in the clutches. It really isn't too bad to access the belt.
1. Remove 4 bolts holding left footwell to frame, and bolts or clips holding the footwell to front and rear fender.
2. Remove footwell
2. Remove all screws on the clutch cover, loosen clamp on the cover breather
3. Pull clutch cover off to access clutches and belt
4. Slide belt over rear clutch to remove, may have to rotate rear clutch to aid in belt removal
5. Install new belt over front clutch first then slide over rear clutch while rotating rear clutch
6. Reassemble in reverse order
That should help if you're going to replace the belt on your own, and to keep the belt from glazing or burning again keep it in low gear while under heavy load. Whether it's going up hills, pulling, in the sand, or even putting around under 20 mph it's best to keep it in low gear. That will help get the most out of your belt. Hope it helps, Daniel.
Sep 22, 2011 | Polaris ATV
How do i adjust the the clutch?
there is a clutch for the drive and a clutch for the blades, would help if you specified which. Generally there are two kinds of mower clutch, one is electric and not adjustable, the other is a spring loaded pulley to put tension on the belt. When the belt stretches, the pulley splits, or the spring weakens this type of clutch may need one or all of those components replaced to restore tension, but it is not "adjustable" per se. half the time the owner has put the belt back on wrong and there is no tension so exclude that possibility before you start buying parts.
Apr 22, 2011 | Craftsman 20 hp 42 in. Deck Yard Tractor
Zt7000 Craftsman mower clutch seems to have issues. Wires were broken from the PTO switch to the clutch by the clutch assembly. With no electrical charge going to the clutch, the flywheel and wires are...
The tab sticking down fits into one of the groves on the cluthc to keep the clutch from spinning while the engine is running, as well as when you engage it. The wires are broken due to the clutch bolt backing out, or the belt or part of the belt could have broken or lost some of the chords that have spun and wrapped around the wires and just broke them off. You need to verify that the bolt is tight first. The tab should not be bent, if it is you need to straigten it before you reinstall the clutch. Next reattatch the wires. Dont put the belt on yet. After you have reconnected the wires, test for 12 volts. You can do ths two different ways, the first is sit on the seat with the engine OFF. Turn the key to the RUN position, then engage the PTO (turn the blades on), you should hear a CLUNK. Do this two or three times. Or you can sit on the seat ( or have someone sit there) and use you volt meter set to DC volts and check your connector for 12 volts and ground. Then put the belt back on and try it out.
Nov 03, 2010 | Craftsman Garden
Craftsman 42 in. deck lawn tractor. Will start and idle fine but when you let out on the clutch the motor bogs down and dies
few reasons will try to narrow down first start it and put in neutral and deck disengaged release clutch if bogs then fuel problem the carb may need adjustment or repair or fuel filter needs replacement----if no bog step on clutch no put in gear release clutch if bogs check drive belt -upper belt on engine pulley and check for binding an idler pulley problem -debris -or rear unit binding -needs service-drive pulley damaged-rear locked--if not bogging in gear step on clutch engage deck release clutch if bogs need to check deck -belts-pulleys -mandrels -bearings and for bent or binding blades good luck
Mar 10, 2010 | Craftsman Garden
Wont go and screeches when letting off clutch/brake
Take off the shift plate between you legs, put it in nuetral, crank up the engine, put speed lever in high gear and slowly let off on the clutch. Everything will work as if in gear, it just won't move. you should be able to see what the problem is. Which belt did you replace and why? Watch the varible speed pulley (the one both belts go around). The bearings may be bad in it and not letting it turn, thus, smoking the front belt.
Jun 29, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Timing belt adjustment
recheck timing marks to align up..
I hope you did not rotate motor with timing belt removed or while working on clutch !!
If you did you need to take it in to a bike shop to get reset or you could bend valves or lots of other things>>
Jan 28, 2009 | 2003 ATK 605
Fan and clutch assembly
It is regular threads. You need to use a strap wrench to hold the pulley. Or make one by using a old leather belt. Just wrap the belt around the pulley. Put one end through the belt loop in the opposite direction.
Jul 03, 2008 | 1997 GMC Jimmy
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
51 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
