Question about GE Jkp90Dpbb 27" Built-In Combo Microwave And Thermal Wall Oven
GE Dualwave Mirco Oven combo - Oven works fine - Micro doesn't even show the clock
I was microwaving a cup of tea water and the microwave didn't ding at the end of the cycle. When I walked up the clock display waas off. So I thought the breaker had blown. I turned the breaker off and on. Wasn't the problem. The over and all the dials work fine - just nothing on the microwave works. I know this is an older unit - would the clock stop functioning or could this be a interior fuse issue?
    Prodigy:
    An expert who has answered 500 questions.
  • GE Expert
  • 650 Answers
There is a very good chance that it has blown a fuse. They would be located behind the control panel. Be careful around the wiring to the high voltage circuit and make sure that the power is shut off.
Posted on May 10, 2014
  • 112 Answers
SOURCE: GE double oven wall, JKP85B0A3BB
I would start by checking all of the door switches. Once you remove the shell, you will see them all on a rail where the door latch goes. Some will be normally open, some normally closed. If they all check out, check all of your overloads and thermal fuses. They should all read closed. If they all check out as well, replace your magnatron, capacitor, and diodes.
Posted on Oct 25, 2008
ginko
  • 19396 Answers
SOURCE: Microwave will turn on but not heat
Test the high voltage capacitor, the rectifier diode.or the magnetron.
If it additionally does not spin and no light, then check also the door switch.
The diode and capacitors can br tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, even if power is off. Capacitors can get discharged by shorting their two contacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Posted on Apr 27, 2009
  • 8 Answers
SOURCE: Convection works but Microwave does not heat
try using a voltage stabiliser .it may just solve ur problem..
Posted on May 17, 2009
SOURCE: GE glass top and oven are not heating?
I have an electric oven that is turning on but not heating up. The oven, broiler, & stove top are not heating up. Any easy solutions to this?
Posted on Oct 20, 2009
lscf150
  • 443 Answers
SOURCE: i have a ge jkp86 electric oven the oven will not
First thing that comes to mind is to make sure you are getting the correct voltage to the oven, you need 220 / 240 volts, check your breakers, fuses ,etc.
It is possable for the microwave oven to operate even if the power supplied to the oven is only 110 volts, but that low of voltage is not enough to power up the ovens heating elements.
If all seems well there, then maybe the oven element has failed / shorted ?
Good luck !
Posted on Jan 27, 2010
F84 trouble code on electrolux icon wall oven
I am getting the same error right now for the microwave part of the microwave oven combo. The oven is working fine with no racks out of place.
Sep 10, 2012 | Electrolux ICON Designer E30SO75ESS Oven
Ge profile oven lock button won't go off
  • 1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door.
    2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle.
    3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad.
    or
  • 1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers.
    2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time.
  • 3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off.
  • 4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down.
  • 5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
  • Nov 22, 2011 | GE Profile JK915 Electric Single Oven
    I purchased a microwave/convect oven combo last week. Installed today, everything works fine except that the lower oven won't heat. I tried turning the breakers off waiting a few minutes and back on. ...
    Ensure that the clock is set and that is not in auto mode, the clock is only linked to the main oven and therefore it will not opearte if the clock is not set correctly, all the best
    Sep 04, 2010 | Bosch HBN 9722 GB Electric Double Oven
    Ge wall oven will not heat up on bake,boil or clean cycle
    GE JKP86BF3BB COMBO MICRO/ELECT OVEN
    NO HEAT ON BROIL OR BAKE ELEMENTS
    CKD WIRING FROM PANEL OK
    CKD TERMINALS AT ELEMENT HAVE 120V ON EACH ELMT
    FAN COMES ON
    THE ON INDICATOR SHOWS WHEN TMP &START PUSHED
    MICROWAVE WORKS FINE
    I ORDERED A NEW BAKE ELEMENT TO TRY-NOT HERE YET
    STUMPED
    Mar 16, 2009 | GE JTP15 Electric Single Oven
    Kitchenaid Superba microwave oven combo close door error
    turn off the main power outlet it will work.
    Feb 09, 2009 | Ovens
    Jenn-Air JMC7000 Microwave Stopped working
    take the trim off of the microwave and on the top of the oven on the right side all the way in the back there should be a reset button just like a surge protector.
    Dec 01, 2008 | Ovens
    My GE Microwave/Oven Combo Unit JKP85B0A3BB has a melting chamber
    It is one unit. You can not replace just a microwave.
    Sparking when microwaving
    Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
    Microwave Oven Basic Troubleshooting Tips
    heatman101
    gfgh
    Mar 08, 2008 | GE Profile Advantium SCB2001KSS Stainless...
    GE Jkp90Dpbb 27" Built-In Combo Microwave And Thermal Wall Oven Logo
    96 people viewed this question
    Top GE Ovens Experts
    William Miller
    William Miller
    Dan Webster
    Dan Webster
     Fix Your Board
    Fix Your Board
    Are you a GE Oven Expert? Answer questions, earn points and help others
