Question about Scotsman DCE33PA1BC 15in Built-in Automatic Ice Machine/Maker w/ Drain Pump, Black
Water keeps running. Ice making very slow and blocks not 100%. Scotsman Iceone
    Novelist:
    Champion:
  • Scotsman Expert
  • 373 Answers
Replace water inlet valve.
Posted on Jul 17, 2014
5 Suggested Answers
Sea Breeze
  • 4654 Answers
SOURCE: water keeps running
Check for trash in the water valve. Insure the water lines don't have rust flakes in them. The water valve is operated by the float arm. Anything in the water line can keep the valve stuck open and stop production of ice. Hope this helps, Sea Breeze
Posted on Oct 28, 2007
Sea Breeze
  • 4654 Answers
SOURCE: My binsensor lingh is on but my bin is not full so my ice machine
I see you already said you bin sensor light was on. The drop door has a metal tab that waves over a sensor as it opens, if that part when it closes does not tell the board that door is shut the the board thinks the bin is full. I know you already know that but until I can talk to Scotsman on the phone or review their service manual for your model. One good thing about Scotsman is they are very helpful to their customers. Unless the machine is obsolete.
Posted on Apr 23, 2009
farfield
  • 462 Answers
SOURCE: Scotsman ice machine(sce 275g)
The older cubers were opperated by a cube size thermostat. when the temp reached the cube size tstat setting it would energize a harvest timer motor and this timer would continue running through a holding switch on the timer. when the cam comes around and the micro switch drops the water is introduced (it would be warm) and the hot gas from the refrigerant would be introduced to the evaporator causing the cubes to drop. at the end of the cycle the cam pushes op in the holding switch and finally open it and because the cube size tstat is now warm the timer motor stops.
The timer had a white plastic stem with a 1/4" D shaft. It would only turn clockwise. Try looking for this and advancing it to see if your sol valve will open or get voltage to the valve.
Posted on Jun 02, 2009
  • 102 Answers
SOURCE: Our Scotsman ice maker is making ice but is not
is the drain running clear is the condenser clean and are both spray nozzles in place?
Posted on Aug 06, 2009
Scotsman ice machine slow water fill
Check to see if there is a water filter inline if so then change it. If not then check where the supply water line is hooked up to the machine pull line off and turn water on to make sure you have good water pressure. if you have good pressure then pull the water inlet valve and take it apart to make sure it is not stopped up with trash and that is it.
Mar 12, 2015 | Scotsman CU1526SA-1A 150 Lb Self-Contained...
Water diagnose light blinking 0n cm3 scotsman ice machine even after changing water level sensor
Is the sump tray full of water? or is it not filling up fast enough? Water level sensor lets control board it needs water or its full of water. If machine is not getting enough water or slow filling then check the water filter, if water is flowing good through filter good then pull water line off of the water inlet valve to make sure there is no trash blocking water at inlet. If not then make sure the water solenoid is getting power call from board to solenoid, if getting 115v to coil and slow to no water to sump then replace valve, if no power to valve then replace board.
Sep 25, 2014 | Kitchen Appliances - Others
Check the water inlet valve water seeping through valve should be running over into bin. Replace or rebuild valve. the machine should have slowed down on production of ice also.
Jul 17, 2014 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Why won't Ice maker make ice?
Scotsman Prodigy - bad Ice thickness probe
May 10, 2014 | Prodigy Scotsman CU1526MA-1A Ice Maker...
I have a Scotsman SCN60 nugget icemaker and when I add cleaning solution to reservoir it just stays there
Hi, Are you using Scotsman ice machine cleaner? and are you using the right amount?
1. Open the door and turn the ice machine control knob to off.
2. Scoop out all the ice, discard it.
3. Pour 4 ounces of Scotsman ice machine cleaner into the ice machine reservoir.
4. Turn the ice machine control to on.
5. Allow the machine to operate for about 2 to 3 hours.
6. Pour hot water into the bin to melt the ice that has formed. That ice will likely be white and frosty looking.
7. Clean the bin liner of mineral scale by mixing some ice machine cleaner and hot water, and using that solution to scrub the scale off the liner.
8. Rinse the liner with hot water.
9. Sanitize the bin liner.
Now a dirty evaporator plate will not stop it from making ice it will cause it to hang up on the plate during harvest cycle if machine is not making ice good then there is something else wrong but when you clean the machine also make sure you clean the condenser coil and fan if this is dirty this will cause it to slow down on production of ice.
Dec 19, 2013 | Scotsman DCE33PA1BC 15in Built-in...
Can`t get scotsman cme250 to work properly. either doesn`t make ice or won`t harvest ice. when cube size thermostat is turned up so it makes ice it takes long time to start forming cubes. electrical...
The problem could be a series of things beginning with ambient temperatures too high, fan not working properly, if water cooled there could be a problem with that also. As a technician I would first look over the condenser and make sure air flow is proper and then attach my gauges to see the suction and discharge pressures. I have found many restaurants that keep their ice machines in the hot kitchen where it creates high ambient temperatures and allows grease from the grill to collect on the condenser blocking air flow. Yes under charged is possible or over charged but the best and most effective route is to call a Scotsman Certified Technician. I have worked on Scotsman's and they are very tricky to fix unless you know the process of event. If water is not pre-filtered there is a chance that the water control valve may be stuck open allowing warm water to continue flowing causing these symptoms. Here Is a=> Scotsman CME250 Ice Machine User Manual If unable to find these simple checks above or from the manual and still having problems it will need to be time to call a Technician. If you do not have Adobe Reader Click Here=> Adobe Reader X (10.1.0) Tell me what you find and please don't rate me if I was unable to solve this from here. I am here to help you up and to the point of calling Scotsman for addition help. Thanks, Sea Breeze
Jul 15, 2011 | Scotsman Ice Machine, Cuber, 1825 lb....
I own the Scotsman Prodigy CU1526SA model. My machine is not making ice, the machine's Code Display shows code 3, which according to the manual, code 3 is for "slow water fill". But the...
chech water inlet valve to make sure there is no trash blocking it. if it is cleare then i would check the water supply to the machine and make sure the supply line is not kinked.
May 16, 2011 | Scotsman Ice Machine - 290lb...
Scotsman has become very slow in making ice
I would try cleaning the unit, plus if there is a inline water filter I would replace it
May 23, 2010 | Scotsman Ice Machine - 290lb...
Jun 28, 2009 | Scotsman DCE33PA1BC 15in Built-in...
Water keeps running in scotsman icemaker
Oct 28, 2007 | Scotsman Cooled Modular Contour Cuber...
Scotsman DCE33PA1BC 15in Built-in Automatic Ice Machine/Maker w/ Drain Pump, Black Logo
173 people viewed this question
Top Scotsman Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Tim Whalen
Are you a Scotsman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
