Here is a Dell NPS-250KB,
http://www.justpowersupplies.com/dell-nps-250kb-b-power-supply.htmThis is a cutaway of an SMPS similar to yours,
(Switched-Mode Power Supply),
http://en.wikipedia.org/wiki/File:ATX_power_supply_interior-1000px_transparent.pngIn-between the letters B and C, and C and D, are the Heatsinks.
The shiny rectangular block looking objects, are actually aluminum fins, and put together, have a rectangular shape.
They are connected in a row with a thin metal strip.
[DO NOT open a Power Supply plugged into power!
Dangerous voltages inside that can -> Badly to FATALLY shock you!
(Fatally = Kill)
The Electrolytic Capacitors inside are designed to hold a charge, then release it all at once. Power supply unplugged from power, the capacitors inside can hold a charge for weeks, months, sometimes over a year!
They need to be properly discharged before working on the unit ]
I have a feeling you mean towards a Processor's Heatsink, inside a Dell desktop computer.
There are styles where Dell used a type of Thermal Glue, and stuck the Heatsink to the Processor.
A hair dryer set to medium, and slowly swirled around, and around on top of the Heatsink, will soften the glue.
{The above is AFTER the mounting clips are unclipped, that hold the Heatsink to the Processor}
WITH A GLOVE the Heatsink is gently twisted a little, one direction sideways, then the other direction, until it comes loose.
You can feel when the glue is soft enough, to start twisting on the Heatsink. You can also feel when it is not.
DO NOT manhandle it. The Heatsink will come loose, but so will the Processor. You will have a Processor with broken/bent pins on the bottom. This = No.
Or your reference may be to a particular style that Dell used.
This is one of many. Used on an Optiplex G150 desktop computer,
http://support.dell.com/support/edocs/systems/opgx150/sm_en/smdsktp.htm#mphs_assy(Scroll down)
So what is the Model Number of your Dell desktop computer? Post in a Comment.
Regards,
joecoolvette
