Question about Nordic Track NordicTrack C2150 Treadmill
Console not working properly
The home button is not working. I have tried resetting it to see if that was it, but it turned on to a blank screen and then a few min later it shut off. I can't use the treadmill at all. No other buttons working either??? HELP!
SOURCE: Buttons doesn't work...
you more than likely need a new keypad
www.AtlantaFitnessRepair.com
Posted on Aug 24, 2009
  • 40 Answers
SOURCE: Nordictrack motor will not run when start button is pushed.
Likely the cover of one of the motor brushes popped off. Unplug the machine before you pop it back in place, then try it again.
If that doesn't work, most likely it's the motor control board, or possibly the console, or finally just a loose connection behind the console.
But most likely, it's the motor brush cover. I've been seeing that alot with this model.
Posted on Nov 01, 2009
SOURCE: When I turn on the
First of all you need a Surge protector, you can get one from Nordictrack.com, it is on sale. Secondly, unplug the treadmill and leave it unplugged for at least 24 hours. Before you plug it back again, make sure you already have a surge protector on your outlet. Also make sure Trreadmill is the only load on this circuit. Plug it and try again. I had the same problem, and mine works this way. Some times, with dilrty power, the bit get set and the bottons stop working. Good Luck!
Posted on Jan 03, 2011
ercupa190
  • 12223 Answers
SOURCE: Nordictrack COmmercial 1500 console buttons don't work
http://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitnes
11_17_2011_8_43_24_pm.gifsincerely. Please keep me in touch.
Posted on Nov 17, 2011
ercupa190
  • 12223 Answers
SOURCE: Treadmill won't start. Console works but when
If the console takes batteries, replace them. If this does not work or your console does not require batteries, check the reed switch or optic sensor. Reed Switch: Unplug the treadmill and remove the motor hood cover. The reed switch is mounted on the frame next to the front roller pulley. There is a magnet glued into the front roller pulley. When adjusting the reed switch, make sure it is pointing directly at the magnet. Move the tip of the reed switch within 1/8" of the magnet. Also, check to see that the wire is not damaged, and is connected to the console
Optic Sensor: Unplug the treadmill and remove the motor hood cover. The optic disk and sensor are located either at the end of the motor or the right hand side of the front roller. The optic disk spins between two sensors on the optic switch. The disk must spin freely without touching either sensor. The sensors can be moved by loosening the adjustment bolt holding the switch to its bracket. The switch can then be slid. Center the disk.
11_21_2011_11_34_59_pm.gif11_21_2011_11_35_24_pm.gifRemember the Display Console Board has circuit that send to PController Motor, and after you did the adjustment you can conclude if the Sensor Reeed is faulty, 2) The Display of 3) The main Controller Motor.
Posted on Nov 21, 2011
Siri keeps asking "Which setting' What setting should I say?
Never happened to me, but try reseting the phone. You do this by turning the phone off and then back on again but hold the home button while turning it back on. If this doesn't work, you might have to take your phone to a repair center.
Oct 07, 2014 | Apple iPhone Cell Phones
Tip
Display problems while playing Virtual Console games
If you are experiencing display issues (dim, blank or half-blank screen, ghosted image, etc.) with a Virtual Console game while using the Component Video Cable, please read the following:
Some Virtual Console games default to displaying 240 lines of video. Some HD TV's are unable to display a signal with only 240 lines. Try the steps below to set the Wii to output 480 lines of video, which may solve the problem:
  1. While on the Wii Channel Menu (main screen of the Wii), connect a Nunchuk to Wii Remote.
  2. Select the Virtual Console game from the Wii menu, then select "Start" to begin the game.
  3. When the game starts, press the Home button on the Wii Remote. (In many games, the music can be heard when the game starts.)
  4. Select "Operations Manual" from the Home menu.
  5. Press the Z + A + 2 Button simultaneously (the Z Button is on the Nunchuk). A sound will be heard if the button combination has been entered correctly.
  6. Close the Home menu. The game should now display correctly. Note: You will not have to do this the next time you play, as the Wii console will remember these settings.
If the Virtual Console game is still not displaying properly, but all other games work fine, please call 1-800-255-3700 so that we may assist you further.
on Mar 04, 2010 | Video Game Consoles & Games
Ipad has voice over only when turned on..blank screen
Triple click the home button. Then double tap the VoiceOver off button. This should allow the device to return to normal operation. Then you can reset by pressing and holding both buttons (power and home) until it resets if you need to.
Aug 23, 2014 | Apple iPad 32 GB WiFi Tablet PC
Kocaso M1066 won't get past the first blank white startup screen. Suggestions?
Memory could server me wrong, but on some tablets you have to hold down the reset button and the power button at the same time in order to get a complete reset. I think this one might fall into that category. The following sequence works with other models of the same manufacturer, so give these a go if the first suggestion fails.
The button to hold down is the menu button next to the home button. With it powered on hold down tthe menu and power buttons until it goes off, then release the power button and then hold it again while holding the menu button. An android with an exclamation and triangle will appear. Tap the power button and the menu for reset or updates appears. Select factory restore and follow instructions then select reboot at next screen.
Hope they help,
Gill
Jan 28, 2014 | Tablets & eReaders
My PS3 Turns on. The green light turns on but when i turn it to the right HDMI the screen is blank.
This sounds like a cable problem. If you're going through a home theater receiver, try plugging it directly into the TV. If it works then it sounds like your home theater box needs to be tuned properly. If it doesn't work, then try replacing the HDMI Cable.
Failing that it could be a problem with the HDD. Try holding down the power button until you hear it beep a few times, then let go.
Jan 22, 2011 | Sony Playstation 3 (PS3) Console
Iphone 3GS- only get the apple loading screen.
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
Nov 29, 2009 | Apple iPhone 3G
When i turn on ps3 all i get is a blank tv screen? hooked up thru hdmi. triied another hdmi cable i know works still a blank tv screen
when you turn your ps3 on ..try holding the power button down for about 10 seconds..that shud cure your delema..if the ps3 is working properly
Nov 06, 2009 | Sony Playstation 3 (PS3) Console
Iphone not loading after reset, only apple sign is being desplayed
Step 1. Turn off your iPhone.
Step 2. Hold down the power and home button.
Step 3. When you see the Apple logo, release the power button but continue holding the home button down.
Step 4. Open iTunes and wait for it to tell you that its in restore mode.u try this
Apr 17, 2009 | Apple iPhone 3G
Nordic Track NordicTrack C2150 Treadmill Logo
89 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
