Question about Technics SL-PG480A CD Player
Splg580a I have a technics cd player and when i turn it on it displays F26...can anyone help me with this as it does not work while this shows
There is a problem between the power circuit board and the cdplayer board[located under the optical pickup system]. Check the connectore between them
Posted on Jan 29, 2008
    Problem Solver:
  • 7 Answers
Im pretty sure this is to do withthe laser, try using a cleaning cd, put your head next to the player and listen to if the actual disc is moving inside.
this might evan be a problem with the cd motor.
Posted on Jan 05, 2008
Rockford Fosgate stereo acting crazy. Don't get any sound when I restart the engine. Help!!
best fix is to look for a used eclipse rockford forthgate unit that works
Mar 01, 2016 | 2008 Mitsubishi Eclipse Spyder
What means the code error F26?
F26 Boiling protection. The program is interrupted and the drain pump is operated. The display shows Technical fault F26. Call the Service Department. The buzzer is activated for 2 minutes.
Temperature at NTC temperature sensor has exceeded 194?F (90C).
Check the heater relay and replace it if necessary.
NTC temperature sensor providing inaccurate information.
Replace the NTC temperature sensor.
Heater relay closed.
Replace the heater relay.
Aug 25, 2014 | Dishwashers
My maytag commercial washer display a code F26
This error code indicates that the door needs to be opened and closed.
The F26 code may appear the first time you try to use the washer. Open and close the door to clear the display.
The F26 code may also appear if the washer has run three cycles without the door being opened. Open and close the door to clear the display.
If opening and closing the door does not remove the error display, press Pause/Off or Pause/Cancel twice.
If Pause/Off or Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, and the condition above has been checked, call for service.
Oct 23, 2012 | Washing Machines
Radio and CD player in Jeep not working only Aux. Can only adjust volume when in Aux mode?
sounds like you might need a new cd player, if it was a fuse the problem would be there 100% of the time
Aug 11, 2012 | Jeep 2007 Grand Cherokee Laredo
U70 error message on cd player
U70 error message on cd player - Fixya
Apr 5, 2012 - U70 error message on cd player Cd player doesn't work at all. Displays 0 track, 0:00 (min,sec). The play - Technics CD Players question.
Technics error code f 70 CD Players Questions & Answers ... > Forum > Tags > error code f 70 > CD Players
Technics cd players error code f 70 related questions and answers. ... won't play cds changer turns on ok, reads error message I have the same problem.
Apr 05, 2012 | Technics Audio Players & Recorders
I buy a used technics sl-pg480a cd player and after i inserted a cd, there is "no disc" on display...i try with different cd's (mp3, avi,...) and it's always the same...i have opened a box and...
If it doesn't turn the disc it can't read the data and 'know' from that there is a compatible disc inserted.
You may have gotten hosed by the seller. Until you get it to play with a commercial music CD I wouldn't try anything non-standard or home-grown. It doesn't play anything but CD-A music so MP3 and AVI discs would not be recognized anyway.
Before you dive in and possibly wreck it, read this...
The manual:
Feb 20, 2011 | Technics SL-PG480A CD Player
When i turn on my technics cd player model number sl-mc409 it comes accross the screen f-26 and won't do anything. what does f-26 mean
I've just bought a used changer, that shows the same error. The instuction says " unplug the changer from its outlet, replug it in an turn the changer ON again"
That doesn't help in my case.
Have you found a solution?
May 01, 2010 | Technics SL-MC400 110-Disc CD Changer
Technics dv290 system
i once had a panasonic dvd player which displayed the same code H02 and used the same drive mechanism as your player. this turned out to be a worn spindle motor and once replaced, all worked fine. you may well have the same fault. hope this helps?
Sep 06, 2009 | Technics SC-DV290 System
Turntable mode does not work
Mar 18, 2009 | Technics SL-DZ1200 CD Player
Technics sc-dv290
Oct 26, 2008 | Technics SC-DV290 System
Technics SL-PG480A CD Player Logo
227 people viewed this question
Top Technics Audio Players & Recorders Experts
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
