Question about Whirlpool WDF510PAYS Full Console Dishwasher in Stainless Steel with 14 Place Settings WDF510PAYS
Model wdf510payws stops running during cycle after about 45 minutes
Cancel and drain can be restarted after a few hours
  • 145 Answers
SOURCE: Normal cycle light flashing
If its the ormal led flashing that is normally caused by a stuck key ing the key pad. Might try unplugging and plugging back in but sounds like you need a new touchpad.
Posted on Apr 18, 2008
  • 38 Answers
SOURCE: The only button that works is the cancel drain
Sounds like a keypad malfunction or the control board has gone bad.
Posted on Feb 23, 2009
  • 52 Answers
SOURCE: quiet partner II is stuck in cancel/drain mode...
you need a new cycle selector ...or "timer "....
Posted on Jul 25, 2009
rylee_smith
  • 8619 Answers
SOURCE: My diswasher does not drain.
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter. Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines. First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. If you have checked the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 08, 2010
  • 3247 Answers
SOURCE: DU1055XTS wash cycle runs for 1hr 20 minutes then
I am not quite sure if I have understood the problem that you mention.
The dishwashers have several wash cycles and depending on what temperature applies to each cycle the wash cycle time will vary.
My suggestion would be to first try a short cycle like Rinse only and see if that completes. This should last about 10 minutes. Next try Normal (suggesed total time is minimum 71 mins.)
Apart from dishwasher taking longer wash time due to heating water, there is also possibility of some dirt in the wash pump. The dishwasher has got a dirt sensor which checks the amount of soil in the wash water. It periodically lets off some water into drain and takes fresh water. This could prolong the wash cycle. If possible check the chopper assembly (item 6 ) in this diagram. You can work this out if you notice inlet valve operating many times during the wash cycle.
The other thing that can prolong wash cycle is a faulty thermister (item 25). This means it is not giving correct water temperature and the heater could be heating longer. However, at some stage this should trip the high temp fuse. Doesn't seem that this is happening.
YOu have some options to look at. Please accept this solution if you found it helpful otherwise please post a comment.
Posted on Jan 28, 2011
How can i set program time when power failure during dishwasher is running ?
There should be a "cancel and drain" or similar to drain the machine and so you can restart your choice of wash cycle when power comes back on again. I don't believe it's possible to have the machine resume from where it was in the wash program if the power fails.
Sep 26, 2015 | Samsung Dishwashers
Maytag dishwasher model MDBTT53AWW2 wont drain completely in normal cycle. I time drain cycle in normal cycle and it took 45 sec. in cancel cycle it run 2 mins. I replaced the pump and check the flapper...
Sometimes the machines get out of cycle and you have to remove power from the board to rest the electronics. After a while the code on the board gets corrupted and you need to reset. Try uplugging for 30 minutes to clear the board of power.
Oct 17, 2013 | Dishwashers
Whirlpool GU2300 Dishwasher. The machine stops for long periods during the cycle. All lights go out. If the machine is opened before the cycle finishes, it will not resume. If I try to restart, the normal...
Hi
Door latch.
Open and close the door to make sure the door latch is securely fastened.
Check the dishwasher wiring for a possible loose connection where it connects to the house wiring.
Fuses or circuit breakers.
Check your house fuses or circuit breakers to make sure you have power to the dishwasher.
Thanks for contacting fixya.com
Oct 24, 2009 | Dishwashers
Whirlpool Dishwasher won't drain during normal cycle
As you say a clogged line or valve does not make sense.
Try running it without the heated drying and see if it empties or if the cancel button will work then.
The dishes should air dry quickly if you empty it and open the door.
It could be a defective thermostat allowing it to get too hot during the heat cycle
May 18, 2009 | Dishwashers
Will not spin during any cycle w/ or w/out clothing inside
that sounds like something else, I had a similar problem yesterday, the washer would stop after a few mins, I traced the fault to the water hoses, it was plummed in with a hot water feed that can get dirty over time. this had blocked the inline fiter stopping water getting into the machine, if it does not fill within three minutes it can cancel, I cleaned the filter and was out in 10 minutes.
Apr 13, 2009 | Washing Machines
Kenmore 22082
OL on my washing machine
May 17, 2008 | Kenmore 22062 Top Load Washer
Washing machine won't drain
It sounds like you may have some bad contacts in the timer or you may have a bad lid switch which will not allow it to go into a spin during the rinse cycles or the final spin.
Oct 30, 2007 | Kenmore 24032\24036 Top Load Washer
Whirlpool WDF510PAYS Full Console Dishwasher in Stainless Steel with 14 Place Settings WDF510PAYS Logo
19 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
