Question about Canon FAXPHONE L80 Laser
Sticking Buttons Numeric Button #1 Sticks;does not show up on LCD window
How do i reset SC542 error in Ricoh Aficio SP300DN?
FOR RICOH AFICIO SP 3400SF follow below steps.
1. To access Service Mode, On Control Panel press following buttons one
by one immediately.
Cancel Button (Red) ---> 1 (Numeric One) ---> 0 (Numeric zero) ---> 7
(Numeric Seven) ---> Copy Button (Green)
2. In Service Menu you will find Engine reset Menu. In that you can reset
SC 545 in Fuser Reset Menu. And you can also reset SC 542.
Feb 23, 2015 | Ricoh Office Equipment & Supplies
Sanyotv com
Sanyo TV Service Menu Method 1
1.Unplug the power cable.
2.Press and hold the {MUTE} button on the remote control while plugging the power cable back into the outlet.
3.Keep pressing the {MUTE} button until the TV powers on with the Service Menu displayed.
4.Use the {CH+} {CH-} buttons to select menus.
5.Use the {VOL+} {VOL -} buttons to change settings.
6.Some menus might have sub-addresses. Use the numeric buttons {0} to {7} to adjust sub-item data.
7.Press the {MENU} button or turn the TV off to exit.
Sanyo TV Service Menu Method 2
2.Press and hold the {VOL -} button on the TV while plugging the power cable back into the outlet.
3.Keep pressing the {VOL -} button until the TV powers on with the Service Menu displayed.
Sanyo Projector Service Menu Method 1
Factory Menu Access
1.Press and hold the {SELECT} and {INPUT} buttons on the Projector at the same time for about 10 seconds.
2.The Factory Menu will be displayed.
Service Menu Access
1.Press and hold the {MENU} and {INPUT} buttons on the Projector at the same time for about 10 seconds.
2.The Service Menu will be displayed.
Use the {UP} {DOWN} {LEFT} {RIGHT} buttons to move through menus and change values.
To exit, turn the Projector Off.
Sanyo Projector Service Menu Method 2
1.Press & hold the {MENU} button on the Projector for about 10 seconds.
3.Use the {UP} {DOWN} {LEFT} {RIGHT} buttons to move through menus and change values.
4.To exit, turn the Projector Off.
Jul 20, 2013 | Televison & Video
Hi, how do i sync my venom dvd remote to my xbox 360? thank you
To enter a TV code:
1 Turn on your TV and point the remote toward it.
2 Press and hold the TV and OK buttons simultaneously for two seconds. All of the buttons on the media remote will then light up for two seconds, after which only the numeric TV buttons (1-12) will remain lit.
3 Enter the code for your TV.
4 Press the TV button again to save the code and exit. All of the buttons on the media remote will blink three times to confirm your selection.
To scan for a TV code:
on the media remote will then light for two seconds, after which only the numeric TV buttons (1-12) will remain lit.
3 Press the CH+ or CH- button to send a series of off commands to your TV. Repeat until the TV turns off.
Jul 02, 2011 | Venom DVD Remote Control for Xbox 360
My printer ricoh aficio SP 3400SF is showing service call error code SC542. kindly help to come out of this error. \r\nvr babu
by one immediately.
Jun 23, 2011 | Ricoh Aficio AP3800C Laser Printer
How to fax?
This section describes dialing and sending faxes directly using the Numeric buttons.
note:
  • A PBX (Private Branch Exchange) is an on-site telephone switchboard. If your machine is connected through a PBX or other telephone switching systems, you have to dial the outside line access number first, and then the number of the party you are calling.
Sending a Fax with the Numeric Buttons .
Click here for other useful sending methods.
1. Preparing for sending a fax.(1) Make sure that the power is turned on.
(2) Load a document on the Platen Glass or in the ADF.
important:
  • When sending a double-sided document, set the document on the Platen Glass. You cannot scan double-sided documents from the ADF.
(3) Press the FAX button.
The fax standby screen will appear.
(4) Adjust the density (scan contrast) or image quality (fax resolution) as necessary.
See "Adjusting the Sending Quality"
2. Sending the fax.
  • When the document was loaded on the Platen Glass:
(1) Use the Numeric buttons to dial the recipient's number.
(2) Press the Color button for color sending, or the Black button for black & white sending.
important:
  • Color sending requires that the recipient's fax machine supports color faxing.
(3) Press the OK button.
The machine starts sending the fax.
note: When loading two or more documents
  • Load the next page, and press the same button as you pressed in (2) of step 2. Repeat the same procedure to scan all pages of the document, and press the OK button.
  • When you have sent the first page with the Black button, the following pages will be sent in black and white.
When the document was loaded in the ADF:
The machine scans the document automatically and starts sending the fax.
important:
note:
  • To cancel sending a fax, press the Stop button, and follow the instructions on the LCD.
  • If documents remain in the ADF after pressing the Stop button during scanning, "Close the feeder cover [OK]Eject the document" will appear on the LCD. Press the OK button so that the remaining document is automatically fed out.
Automatic redialing
  • When sending a fax and the recipient's line is busy, the machine will redial the number after a specified interval. Auto redial is enabled by default. Auto redial can be enabled or disabled by selecting ON or OFF. Select ON to specify the number of redialing in Redial times and redialing interval in Redial interval.
Redialing the Number Dialed with the Numeric Buttons
1.Prepare for sending a fax.
(4) Adjust the image density (scan contrast) or quality (fax resolution) as necessary.
2. Select the telephone number recently dialed.
(1) Press the Redial/Pause button.
Most recently dialed fax number using the Numeric buttons will appear.
(2) Use the g0016984.png (-) or g0008875.png (+) button to select the number to redial.
The selected number will appear in the fax standby screen.
3. Send the fax.
important:
Jun 03, 2011 | Canon PIXMA MX340 Wireless Office...
I need to reset to the old factory settings. How do i do?? Kind regards, Kerstin
1. Press the d.menu button to display the DTV menu. 2. Press the up or down button to select "System", then press the enter button. 3. Press the up or down button to select "Reset", then press the enter button. 4. The "Enter PIN" screen will appear. 5. Enter your current 4-digit PIN code by using the numeric buttons (0~9). 6. Press the exit button to exit.
Manual - http://downloadcenter.samsung.com/content/UM/200603/20060325173246984_BN68-01007A-00Eng-0302.pdf
May 06, 2011 | Samsung LE26R74BDX 26 in. HD-Ready LCD...
Bugaboo Frog reclining mechanism sticks
hi there if you find the white buttons sticking try getting sand paper and rub it around the button that will make it slighty smaller, and it may help otherwise you may need to change the white buttons visit www.buggypitstop.co.uk
Jan 16, 2010 | Bugaboo Frog - Aubergine Stroller
When I close the laptop and reopen it, there is just a black screen and I can't get it to work. So I end up having to turn off the computer. Also when I go to the shut down from the start menu, the standby...
You probably have a sticking hibernate, or sleep button. Near the hinge, there is a tiny pin looking thing sticking up. When you shut the computer, this presses against a switch below the case and puts the computer into sleep or hibernate mode. If this sticks, it won't boot up right. Shut the computer down and use canned air to blow out at the pin opening to clear any debris.
Sep 30, 2009 | Dell Inspiron 1300 Notebook
Car radio and cd player locked
The 4 digit code is entered using station preset buttons "1" through "4". Each time you press one of these presets the appropriate code digit increments from 0 to nine. As an example, say the code is 5193, press the "1" preset 6 times (zero is displayed on the first press, 1 on the second, etc.), press the "2" button twice, the "3" button 10 times and the "4" button 4 times. The code 5193 will be displayed on the unit.
To accept the code, press the CD button and if the code is correct the unit will come back to life.
Jul 28, 2008 | 2002 Mitsubishi Galant
Canon FAXPHONE L80 Laser Logo
18 people viewed this question
old marine
old marine
