Question about LG Computers & Internet
Have an LG DVD writer.It worked the tuesday and thursday it didnt.Its not picking up the cd`s in the tray.What can the problem be! i put LG cd in and it did`nt put it on the screen so their is problem somewhere. My windows media player also decided it doesn`t want to burn both went the same time,but if you go to control panel and check it out it tells you its normal.the music plays on player but cant copy or burn to cd,tells me I must get another burner,so I downloaded Real and Nero is on my Lg cd then Gom and it doesn`t want to play the movie we hire.can you perhaps tell me or email me at lynetteknoetzen@telkomsa.net so I can get your reply Thank You Lynne
I took it to a IT guy and he fixed it for me,it needed codecs.Thank you
Posted on Jun 19, 2009
Dvd writer is not ejecting
PUT IN THE SMALL HOLE WITH NIDDLE OR PIN ON THE DVD/CD ROM DRIVE NEARLY EJECT BUTTON ,THAT 'S EASILY TO OPEN CD TRAY
Jun 28, 2012 | LG Computers & Internet
Dvd writer not working
what is the OS ?maybe it need to an upgrade or ur dvd-ram & os need to a driver...
May 10, 2010 | LG GSA-H55N DVD-RAM Burner
Sir, I purchased LG DVd writer,i intalled
put the lower or higher version of power dvd software
Sep 29, 2009 | LG Computers & Internet
I just installed an LG 22x Internal Super writer DVD and my computer is not recognizing it. I have a jumper connecting the other drive. It is not picking up either one. Both open but nothing else. The...
I suppose your's is a SATA drive. Disconnect all the sata cables except for the Hard Disk and that of the Writer in question. Boot up and check if the drives works. If not take pains and try installing the drive in another PC (one of your friends'). If it still has the same problem check with where you bought it.
Jun 20, 2009 | LG SecurDisc 20x External Double-Layer DVD...
Compurt is not recognizing a new LG 22x Internal DVD rec
Change the Master/Slave/CableSelect(CS) jumper on the back of the drive (between the power connector and IDE cable)
STEP 1:
Check that the IDE cable red stripe goes to pin 1 (closest to power plug) flip cable if needed.
STEP 2:
Move Jumper to SLAVE position. reboot. check for drive in os. if it's not there;
STEP 3:
Move Jumper to MASTER position. reboot.
If it's still not working replace your IDE cable and try again
My LG multi dvd writer lightscribe tray wont open. the green light is steady. no matter how many times i try to eject the tray ang it wont open. there is dvd+r inside.
use a unfolded paperclip and insert it into a small hole below the disc tray. This is the manual eject port. Stick it straight in and push, a little bit of pressure will be needed.
Apr 20, 2009 | LG Super-Multi GSA-4163B 16x8x16x DVD+R/RW...
Door
Hi abdu
The problem is that at some stage you or someone else forced the cd open or closed, but not to worry, it's not broken. What happened is that the gear that pulls the tray in, mite have slipped a tooth or two. You'll have to open it up. Take the top cover off. It has four small screws holding it. When you take the cover off, the gear system should reveal itself. Now the gear that pulls the cd tray in and out must me ajusted. Before you open the dvd writer, make sure it is in it's utmost closed position. Very Important!. There should be a screw in the centre of this gear. Carefully unscrew completely. Now it depends on which direction the gear turns when it close the tray. Seeing that it doesn close completely, the gear turns anti clockwise to close. Lift the gear in a up sliding position and turn it one teeth clockwise, press the gear back, fasten the screw and test. If it still needs more adjustment, repeat the process with another teeth clockwise. Note if it worsen that it doesn't close, then you need to reverse the process and move the gear anticlockwise, but make sure to mark the teeth that it was originally on when you opened it.
Hope this helps
Cheers
Deon
Sep 10, 2008 | LG (GCE-8527B) CD-RW Burner
LG GSA-H55N Problem
There are 2 seperate lenses for CD's and DVD's, If you have had the drive for a while it is likely to be either 2 things.
1 - possible dust on DVD lens, try a lens cleaning disk..
2 - if 1 didnt work its likely the DVD lens is burnt out and you need to replace the drive..
However before replacing drive try downloading new firmware from LG site and then try once more..
http://www.ukdvdr.co.uk/shop/CD-DVD-Writers-and-Readers-c-336.html
Individual drives - the pioneer at £18.99 isd a great buy!
hope this helps
Dec 16, 2007 | LG GSA-2166D DVD RW Dual Layer Burner
My LG CD Writer ejects automatically without any operations...
This is normally as sign that the writer is faulty, especially if ejecting on your pc's start up. Just go through this first to check if it's just a driver fault. Go to my computer>properties>hardware>device manager and look down the list for your cd/dvd drives and click the '+' sign then highlight your dvd drive and right click to delete. Restart the pc and windows will find the drive again automatically and install the drivers
Apr 02, 2007 | LG GMA-4020B Super-Multi...
Computers & Internet Logo
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
