Unit will not stop
No paper in unit and bin is not full. Yet unit continues to run
  • 20 Answers
Dear Hal,
Here is some generic information about shredders that may help you.
Most of the shredders have a micro switch that "senses" if the paper has been introduced to the shredding slot. These micro switches are activated by a little arm/leveler that touches the paper and activates de contact inside the shredder housing. Also, note that some shredders may have an optical sensor that may be "clogged" with paper dust.
If you shredder does not stop, the sensor may be stuck in a on position, or, in case it has optical sensor may be detecting dust or a little piece of paper may be blocking the optical sensor and keeping the motor running.
I hope this gives you some light in further investigating your problem.
RC
Posted on Jun 17, 2014
3 Suggested Answers
  • 215 Answers
SOURCE: The "bin full" keeps on coming on
first off, fellowes has had problems with the bin full sensors that sometimes, can only be corrected by replacing them. however, there are two things to check. make sure it doesn't have a bunch of shredded paper hanging down from the cutters. that can trigger the bin light as the sensore are located under the head, but above basket. last, but not least, clean the sensors. they get paper dust on them after awhile causing same indication. if those two things don't fix it, it will have to have sensors replaced.
good luck,
razors
Posted on Apr 15, 2009
  • 105 Answers
SOURCE: Unit runs for 4 seconds and then shuts down
there are led sensors on the bottom of the cutting head above the bin . they are either dirty or defective.
Posted on Dec 04, 2009
How do i fix output bin is full remove all paper from bin
Try reinstalling the software if a reset does not do the trick.
To reset unit, pull the plug when it is turned on. Then push and hold the power button for about 30 seconds, then replug back the unit and push the power button.
Sep 07, 2015 | Office Equipment & Supplies
Hp 9050 laser jet stacker error
Probably just a bad sensor or dirty sensor causing the issue.
Stacker or stacker/stapler output bins
For the 3,000-sheet stacker or 3,000-sheet stacker/stapler, the output bins are the upper bin (face-up) and the lower bin (face-down).
The upper bin (face-up) is the top bin on the stacker or stacker/stapler. This bin holds up to 100 sheets of paper in face-up order as they exit the printer. A sensor causes the product to stop when the bin is full. Product operation continues when you empty or reduce the amount of paper in the bin.
Lower bin (face-down) is the lower bin on the stacker or stacker/stapler. This bin holds up to 500 sheets of paper and can stack or staple jobs. This bin is the default output bin.
Aug 19, 2014 | HP Stacker For LaserJet 9040/9050/9500...
Scotsman ice machine water runs continually never shuts off. It will make ice but really racks up water bill. It is as if the float never senses the reservoir is full. What is my problem?
OK is the bin full of ice to where the ice stops making ? and is the water running over into the ice bin. If this is whats happening then cut the machine off, If water is still coming into sump tray then pull the water inlet valve and replace it. If the water stops when you shut the machine off then check the water float or sensor since i don't know what model you have, If float then replace it , if probe sensor then replace it. Now if there is no water running over into ice bin during freeze cycle then nothing is wrong ice machines use a lot of water every time it go's into a harvest it dumps the water in the sump tray.
Jan 12, 2014 | Scotsman Ice Machine, Cuber, 1930 lb....
Staples titanium shredder
Sometimes the sensor gets blocked by pieces of shredded paper. Unplug the unit and remove it from the paper bin. Turn it upside down and see if there are any "stray" pieces of shredded paper hanging on the unit. Remove the stray and replace the unit onto the bin making sure it is properly seated. If that is not the problem, try "tamping" the shredded paper into the bin and by doing so, giving the machine more room for the shredded paper. If neither of these help, refer to your owner's manual to see what recourse you may have.
Jan 08, 2014 | Office Equipment & Supplies
BIN FULL LIGHT IS ON BUT IT IS EMPTY
Unplug the unit from the power source. Open the front of the machine to expose the bin area. Remove the paper bin and look for any signs of paper trapped at or around the blade area. Pull or brush away any debris that may be in that area. Wipe around the sensor with a dry loin cloth or use a can of compressed air for tighter areas. Replace the bin and close the front. Reconnect the power and the Bin Full light should go out.
Feb 20, 2012 | Gbc GDX1813 Shredder
Need owners manual for B&D paper shredder Model BD-10P. i have a jam
Hi and welcome to FixYa, I am Kelly.
The manual is little help but you can find it here:
http://media.homedics.com/IBs/bds/BD-10P_IB.pdf
Troubleshooting
If you have a problem with your shredder, check the symptoms and remedies below.
If you cannot solve the problem this way, contact Black & Decker paper shredders
Customer Service.
Do not open shredder head to attempt repair: It could expose
you to electric shock and will void your warranty.
- Check to see if bin is full. If bin is full, empty bin and
replace. Follow instructions under maintenance.
- Oil cutting cylinders.
Shredder squeaks, grinds or runs
below capacity.
- No action required. This is a self-Shredder continues to run for cleaning function.
1 or 2 seconds after shredding
has been completed.
Symptom Remedy
- Make sure shredder is plugged in.
- Make sure power switch is in "Auto" position.
- Make sure bin is fully closed.
- Check to see if either bin is overfull which could result
in a jam. If so, empty.
- If you are unable to clear the jam, turn off and unplug
the shredder. Slowly and carefully pull the remaining
paper out. Forcefully removing the paper is likely to
cause irreparable damage to the shredder.
Shredder does not start or stops
while shredding.
Paper jams.
HOW TO GET SERVICE:
Visit our website at www.blackanddeckershredders.com or call the toll free customer
service line at 1-800-297-5028.
® SKU #BD-10P
Product Information
This product is designed to shred paper, staples, small paper clips, credit cards, CDs and DVDs.
It is not intended to shred large paper clips, continuous forms, adhesive labels, transparencies,
newspaper, cardboard or any other plastic other than credit cards. Using it for these purposes
is likely to cause irreparable damage. Please do not attempt to shred more than 10 sheets/1 CD
or DVD at a time. Shredder should not run more than 200 sheets/50 disks continuously. Items
should be centered and unit will begin and end shredding automatically. All disks should use
specific entry as noted on your shredder.
Maintenance
It is important to empty the waste bin regularly to ensure the smooth operation of the
cutting cylinders. The shredder will not operate when the bin is full. Regular oiling
is also necessary for proper performance. It is recommended to use the shredder oil
every few weeks.
Maximum running time: 3 minutes
Automatic cool-down period: 30 minutes
Voltage: 120
If you have any questions regarding the product, please feel free to
call toll-free 1-800-297-5028
Thanks for Choosing FixYa,
Kelly
Apr 07, 2011 | Black & Decker Garden
Standard top bin full remove paper
Greets!
Firstly, is the exit bin full of paper? If it is, just remove it.
If not, then it's going to be a sensor that recognizes the paper amounts in the exit tray. Check for broken plastics and possibly stuck plastic flaps in the exit tray.
If it's neither of those, try turn it off, unplug, then reverse.
Other than that, if no go, then it's an internal sensor issue. At that point, probably the best bet is to replace as repair costs would outweight a new unit cost most likely.
Feb 26, 2009 | HP LaserJet P3005 Printer
good luck,
razors
Jan 20, 2009 | Fellowes Manufacturing Powershred C-220...
Techsolutions TS-8000 runs continually when switch is on. Normally you need to feed it to start is in the on position
I have a TS2500 and it behaves in a similar fashion. It sounds like you may have a paper jam keeping the paper sensor switch turned on. The first thing to do is make sure that the container that collects the shredded paper isn't full. Everytime I fill mine up I have this problem. Emptying the bin and pulling the shredded paper from the bottom of the unit usually allows it to automatically shut off. If that isn't enough, make sure that you don't have a paper jam in the cutter rollers. The most important thing you can do is make sure the unit is unplugged before doing anything with the shredding mechanism.
Hope this helps.
Dec 09, 2008 | Tech Solution TS-4500 Shredder
Bogus 'Full' warning
or you could just tape the bucket in place. when the compressor kicks in the unit vibrates which might be shacking the bucket loose to the point that it doesn't make contact with the switch.
Jul 02, 2006 | Maytag M7DH45B2A Dehumidifier
73 people viewed this question
jasbo
jasbo
