Question about Vehicle Parts & Accessories
How do I tighten the power steering belt on a 1991 nissan sentra 1.6 liter engine
    President:
  • 1,702 Answers
Hi, On most of these cars there is a spring loaded idler pulley on lower part of engine. You may need to replace because this has seased tight. Talk to mechanic for more info.
Posted on Apr 14, 2014
How do i tighten power steering belt on a 1991 Nissan sentra
This is just a general answer. There are 2 ways to tighten a power steering belt, 1, by adjusting the power steering pump OR 2 by adjusting a tensioner pulley.
Inspect the belt system and see which one your vehicle uses. If the pump is adjustable, it will be mounted on one end by either a sliding bolt on a curved bracket like the alternator, or by an adjusting bolt.
If your car has an adjusting pulley, check the routing of the belt. It will normally run from the front engine pulley over the adjusting pulley then over the power steering pump pulley. The adjusting (tensioner) pulley will have to be loosened, then either pulled to the tightening position by hand and retightened, or else there will be an adjusting bolt and nut which must be turned to tighten the belt before retightening the pulley.
Sorry, I don't know your car that well so my answer is just generic.
Good luck
Apr 14, 2014 | 1991 Nissan Sentra 2 Door
My 91 with the 3.0 liter V6 has a belt squeal when first started. It does it worse when the engine is hot. The squeal wiil stop if I rev the engine, but it does it every time I start it now. I've been...
remove the alternator, power steering and fan belts as they will no effect you car when engine is just running, the water pump runs of the timing belt, if it still squeals it you water pump.
Aug 29, 2010 | 1991 Nissan Pickup
I neel to put tension on the alternator belt on a
the alternator is the adjuster,loosen all the bolts,jimmy the alt out away from the block, then tighten bolts,check not too tight after above.
Jun 06, 2010 | 1999 Nissan Sentra
How to change belts
1.) slacken alternator bolts..
2.) pus alternator forward,,
3.) remove that belt (TAKE NOTE WHERE IT GOES)
4.) slacken compressor or power steering pump,,
5.) push forward,, remove that belt (TAKE NOTE WHERE IT GOES)
6.) replace bolt belts and tighten back slackened components,,, use a bar to pry the alternator (power steering or compressor ) back to create tension on the belt before you tighten back the bolts..
PS TAKE CAREFUL NOTE THE POSITION YOU REMOVE THE BELT FROM AND REPLACE NEW ONE ACCORDINGLY!!
Mar 12, 2010 | 1991 Nissan Maxima
What is the cylinder head torque spec for a 2005 nissan sentra 1.8 liter engine
  1. For 1.8L engines, tighten the bolts in sequence, as follows:
    1. Step 1: Bolts 1-10 to 22 ft. lbs. (29 Nm).
    2. Step 2: Bolts 1-10 to 43 ft. lbs. (59 Nm).
    3. Step 3: Loosen bolts 1-10 completely.
    4. Step 4: Bolts 1-10 to 22 ft. lbs. (29 Nm).
    5. Step 5: Bolts 1-10 plus 50-55 degrees.
    6. Step 5: Bolts 11-14 to 74 inch lbs. (8 Nm).
      0900c152801afb79.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Cylinder head torque sequence-1.8L engine
      0900c152801afad8.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Tighten the valve cover bolts in sequence-1.6L and 1.8L engines
Nov 13, 2009 | 2005 Nissan Sentra
2005 Nissan Sentra 1.8S, with AC - how to replace belts?
first of all you don't have to loosen the pulley,this will no solve the problem,well you already loosen the adjuster,good,bot thing you have not done i will tell you now,on the power steering pump where the belt pass there is also a bolt that hold it ,you must loosen that also,then after you will see the pump moving on the two position that means you will see the belt loosen on 1 position an d the position it will tight the belt,try that man.............
Aug 23, 2009 | 2005 Nissan Sentra
Where is the turnsignal flasher located 1991 nissan sentra 4dr
In your fuse box should be a large 1-2" square box inside the fuse box. Or under the dash board .
Jul 09, 2009 | 1991 Nissan Sentra 2 Door
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
