Question about Canon Selphy CP900
Cannon selphy cp900 cartridge broken
The cassette film in the ink cartridge has broken and now I can't print. what do I do?
SOURCE: Ink level counter disabled, not recognizing new (refilled) cartridge.
Now this is for the black PG-40 and CL-41.
After refilling your cartridges for the first time, you need to disable the ink monitor.
The instructions are in your manual. You know the book that no one seems to read.
Start button > Settings > Control Panel > Printers > (right click on printer model) > Printer Preferences > Maintenance Tab > View Printer Status > Option.
In the options menu you must left click on the enable status monitor. The check mark will disappear and the ink monitor is now disabled.
If you get a pop up message saying anything and the printer is flashing orange. Click ok on the computer, if no ok button. Hold the feed button on the printer for a few seconds.
Posted on Jul 16, 2008
SOURCE: Cannon Pixma 160 - How do I reset the ink level indicator
crapt the driver
Posted on Oct 21, 2008
don_farr
  • 1018 Answers
SOURCE: Why two black ink cartridges?
The larger of the two cartridges is used for text only. The smaller is used for color printing. Its purpose is to eliminate the need for a "Processed" black (black being mader by the color inks).\
Don
Posted on May 30, 2009
  • 127 Answers
SOURCE: Color ink cassette stuck in canon selphy
I doubt very much that you need to reset the printer, or, even if you did, that this would make much difference. It sounds as if there is a menu item which you should be able to bring up on the display which then allows you to release and extract the cartridge. I have scoured the web for information on this one and Canon, naturally, only supply the software, not the manual. If you have a manual can you look up and quote the relevant bit in it which deals with changing the cartridge? If there is nothing there which says that you have to go to a menu item to release it then it sounds like a mechanical problem - as in 'needs a bit of a yank'. I'll keep looking.
Posted on Jul 10, 2009
ThiruBulls
  • 103 Answers
SOURCE: cannon ink jet quit printing black
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel. # Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right). # Continue doing this until it looks clean. # Then dab the cartridge on the towel to make sure the ink is flowing. # Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier. 2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Posted on Aug 21, 2009
My selphy going through the motions of printing but nothing is on the paper
100 pics is a lot of ink
have you replaced the cartridges to fix the problem
Oct 29, 2016 | Office Equipment & Supplies
My ink cartridge is stuck. I tried to turn it off and on again and to push the paper leveler down but nothing helps.
My Canon Selphy CP740 start to jam ink ribbon and ink - Fixya
www.fixya.com/support/t10013530-canon_selphy_cp740_start
Jan 4, 2013 - My Canon Selphy CP740 start to jam ink ribbon and ink cartridge is blocked and cann't be removed from printers. ... Question about Canon SELPHYCP740 InkJet Photo Printer .... SOURCE: CP760 SELPHY CP760 COMPACT PHOTO PRINTER Thermal: ink cassette stuck in the canon selphy printer CP7.
Selphy CP740 - Catridge Eject Solution - YouTube
? 0:46
https://www.youtube.com/watch?v=9TqHINBmbgQ
Sep 11, 2013 - Uploaded by Mahadhir Shaarani
Selphy CP740 - Catridge Eject Solution. Mahadhir Shaarani ...Replacing Ink for Canon Selphy - Duration: 6:23. Jenuine Crafts... How to Print Different Sizes with the Canon Selphy Printer - Duration: 12:08. Janet Wakeland ...
Color ink cassette stuck in canon selphy 'Canon SELPHY ...
Feb 03, 2016 | Canon Selphy Cp800 Compact Photo Printer -...
Printer say's that paper is not compatible
then try a different size or layout landscape instead of portrait
Mar 13, 2015 | Canon Selphy CP900
Paper size
It looks likes the unit comes with a Paper Cassette PCP-CP400 which is for Postcard Size paper. You should be able to reuse the Cassette for any postcard size paper. If you want to use L Size or Card Size paper you will likely need to purchase an additional cassette for that size.
Jan 01, 2013 | Office Equipment & Supplies
The ink cartridge will not eject. It's stuck inside the printer.
Canon Selphy CP800. I had a cartridge ribbon break when it stuck to some photo paper I was trying to reuse and the cartridge became stuck and would not release. All you have to do is try to print a dummy print, the printer will then display that the ink cartridge needs replacing, it will then allow the cartridge to pop out when the release catch is operated. Beware of broken and torn ribbon inside the printer and try to remove the obvious loose pieces before inserting the new cartridge. Any remaining bits of ribbon should stick to the next photo you try to print but a ruined photo is a small price to pay as your printer should work ok once the debris is cleared. If you are adventurous you can dismantle the cartridge by inserting a small flat screwdriver into the retaining clips at each end of the cartridge cover. remove the used ribbon from the spool as it is only stuck onto the spool spindle. Re thread the unused ribbon onto the spool ensuring it travels round the deflecting spindle which is easily prised out and replaced over the ribbon. You must ensure that the new ribbon is wound onto the spool in the correct direction (check this by comparing the rotation with good cartridge by ensuring the ribbon tightens as it should) then wind the ribbon forward until the black line appears on the clear sheet of ribbon and carry on printing.
Dec 19, 2010 | Canon Selphy CP510 Thermal Photo Printer
The specified ink cassette cannot be found. Replace the ink cassette with the specified one. Press [Resume] to resume, or [Cancel] to stop.
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled or third party cartridges that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
Feb 21, 2010 | Canon SELPHY CP740 InkJet Photo Printer
Cannon selphy es2 - how do i remove old cartridge?
you can remove the old ink cartridge from the Canon selphy es2 by simply lifting the small green lever on the ink cartridge carrier. Take note of how the cartridge was situated in the carrier, then gently take the old cartridge out of the printer.
Jan 18, 2010 | Canon Office Equipment & Supplies
Canon Selphy 510
Hi! I have same problem. I opened cover (4 deep screws at the bottom) and found small plastic gear was separated from stepping motor shaft. I fixed it on shaft and my printer started work again. Today I will try to fix same problem on another CP510. I think same reason. Try to do it. Simple. vadim.y.astakhov@gmail.com
Feb 29, 2008 | Canon Selphy CP510 Thermal Photo Printer
CANON SELPHY DS810 PRINTER PROBLEM
If you open up where you put the ink in, there are rollers that feed the paper in/out of the machine. These may be covered in ink, so just clean them off with an alchahol wipe.
-CGEEK
Mar 17, 2007 | Canon SELPHY DS810 InkJet Photo Printer
Canon Selphy CP900 Logo
old marine
old marine
