My soundbar is not dispayibg anythi'm g but red
My soundbar is not dispayibg anythi'm g but red light
How do i connect a technika TKSBSE213 soundbar to a telly
Does your TV have a Digital optical port? It's a cable that sends a red light source. That is actually how you're suppose to hook up a soundbar. digital optical cable Bing images Straight forward. Plug and play. If you're TV doesn't have an optical port, as I know your soundbar does then you have to use a stereo Y Cable. 3.5mm to Red/White. Sound bar will have 33% the power going this way as opposed to an optical cable. Aux Audio Out has a itty bitty amp pushing power. Purpose of the Digital optical Cable is a light source.
Jan 18, 2015 | Audio Players & Recorders
I have a Philips soundbar that I have hooked up to my flat screen tv using audio (red,white) cables directly from soundbar to tv and there is no sound coming out.
Be sure you are hooking up the Audio Output from the TV or satellite to the soundbar.
From the satellite box both Audio Output and Video Output go to the TV, and then Audio Output from the TV goes to the soundbar.
Or
From the satellite box Video Output goes to the TV and Audio Output goes to the soundbar.
This may help as well:
https://www.youtube.com/watch?v=Z27WtBy4IUs
Jan 07, 2015 | Philips HTL2101A/F7 Soundbar 40 Watts
SOUND BAR IS ON BUT SUBWOFFER DOESNT WANT TO TURN ON RED LIGHT IS ON BLUE LIGHT NOT ON
turn the soundbar off, then press and hold the reset button on the back of the subwoofer until the blue light starts blinking fast. the point the remote at the soundbar and hold the mute button until"ID SET" shows on the display. Then turn on the soundbar and it should find the sub and pair with it.
Sep 12, 2014 | Samsung HWE450 Wireless AirTrack Sound Bar
How do i get a manuel for it202b soundbar
The manual can be downloaded from this site.
http://content.etilize.com/user-manual/1022923625.pdf
Follow instructions on top of page 7 using the Source button.
Jun 13, 2014 | iLive It202b 32" 2.1-channel Soundbar -...
How do I program the jamo torsten sound bar to my remote control?
Great product, horrible instructions that focused on every language known to man rather than clear steps. Hope this helps....for the JAMO TORSTEN 2 WAY SOUNDBAR W/ WIRELESS 10" SUB 360 Series, as well as other Klipsch soundbars.
If the SoundBar is in STANDBY mode (solid RED status light), push the <SOURCE> button on the SoundBar until the status light is solid GREEN.
STEP ONE (Place the unit in learning mode): With the status light showing solid GREEN, press and hold the <SOURCE> and <MUTE> buttons on the front of the SoundBar at the same time (approximately 3 seconds) until the status light flashes RED and GREEN.
STEP TWO (Select the function to learn): Press the <MUTE> button once on the SoundBar (the status light changes to solid ORANGE).
STEP THREE (Learn the function): Hold your remote control within one foot and pointed at the front of the SoundBar. Slowly press the <MUTE> button on your remote control four times. On the first three presses, the status indicator light will flicker ORANGE with each press. If the unit has successfully learned the function, on the fourth press of the button, the light will flash GREEN several times and then turn to solid GREEN.
To program the remaining functions, simply repeat all steps, substituting <MUTE> with the new function and button presses (VOLUME UP, and VOLUME DOWN) on steps TWO and THREE.
Apr 28, 2014 | Jamo Torsten Soundbar with 10" Wireless...
Unable to use lg42pq3000 with lg soundbar
You have to direct the audio out on the tv to the optical output in the setup menu
Jan 01, 2014 | LG 42PQ3000 42" HDTV Plasma TV
How to set up LG NB2020 40W Soundbar
Connect optical cable to soundbar and tv. Plug in the soundbar.
One gotcha -- the red light on the soundbar means the power is off. No light means the power is on.
Jan 16, 2013 | Audio Players & Recorders
I have just got a 55 led 3d smart lg tv with tibo stand and soundbar i cant connect it to my tv as the tv doesnt have a red/white output i connected it through a headphone jack and all its doing is ma
If your soundbar has the input for a toslink, which is an optical sound input you may need to go this route. You will know it by seeing a very small flap with a red light emitting from behind it. Most newer tvs only have this output for sound anymore. Check Amazon for a toslink cable.
Dec 07, 2012 | Televison & Video
Red status light will not go off or change on Boston A TVee model 2 soundbar.
I am also having the same problem. It was working fine until we moved. Plugged it in at the new house and nothing but a red light. Sub is green though.
Jul 10, 2012 | Boston Acoustics TVee Model Two TV...
We bought a Samsung Soundbar x810 but the Subwoofer does not seem to be working properly although the blue and red led light up. I have tried rebooting/resetting per user manual instructions but it still...
Purchased a x810 & everything tests out fine except TV signal sounds from cable box. We have the Comcast cable box connected to the 50" Samsung Plasma TV hooked up to Samsung x810 Soundbar all using HDMI cables. But we are not getting cable shows sound through Soundbar. Please advise
Nov 04, 2009 | Samsung HT-X810T Theater System
20 people viewed this question
 Grubhead
Grubhead
