Sonicwall tz215 LAN light flashing and no internet connectivity
    Problem Solver:
  • 7 Answers
Have you verified on the Network/INterfaces page that the X1 interface is getting an IP address from DHCP or PPPoE?
Posted on Apr 27, 2014
Cisco vpn disconnection through sonicwall firewall
This may sounds obvious but have you forwarded the correct ports through sonicwall for your VPN?
If you have, do you have any QoS running, it could be worth checking that VPN has priority over VoIP etc.
Do you get disconnects all the time or is it only during busy periods? You may be overloading your server, perhaps it's time for more RAM.
Oct 31, 2013 | SonicWALL PRO 2040 (01-ssc-5703) Firewall
I need to add an ip range to my sonicwall tz 170
This is not directly possible to do with a TZ170 as the device will only allow configuration for 1 static or dynamic IP at a time for the WAN port.
However this being the case, I suggest setting the SonicWALL up as a perimeter firewall and place devices that require the other public IPs form the additional IP range behind the TZ170. Basically the SonicWALL becomes the gateway for the other IPs needed as long as the range of the IP block is contiguous.
This would involve using the 4 ports of the LAN on the back of the TZ170 to connect directly to the other devices or if it is more then 4 devices, using a switch connected to the LAN side of the SonicWALL to provide connectivity to the multiple devices behind it. Most TZ170 are licensed for 10 connections on the LAN side and if you require more then 10, additional licenses will need to be purchased.
I would be careful pushing too much traffic through a TZ170 as it is designed for Small Business use and will quickly become overloaded with too much traffic causing high latency/traffic bottlenecks and in extreme cases connections being dropped. This is especially true for multiple VPNs.
Jan 23, 2010 | SonicWALL TZ 170 SP Firewall
Sonicwall client won't connect to the internet
The default VPN policy rules prevent LAN access, also known as split-tunneling, since this creates a security risk (the ability of the VPN session to be hijacked or compromised through a covert channel).
If you are not the system admin, you need to talk to your system admin. If you are the system admin, then you need to review the documentation with respect to
http://www.sonicwall.com/us/support/kb.asp?kbsk=policy+allow+lan
Oct 07, 2009 | Sonicwall PRO 3060 NFR (01-ssc-5378)...
How to routing router static ip address and local
Use the Sonicwall configuration wizard..
Please find below is to configure what ever you want.
Setup Wizard - This wizard will help you quickly configure the SonicWALL to secure your Internet connection. Once completed, you can use the SonicWALL Web Management Interface for additional configuration.
Registration & License Wizard - This wizard will help you register you and your firewall with mysonicwall.com and obtain licenses for additional Security Services features.
PortShield Interface Wizard - Segment and configure the integrated managed LAN switch of the SonicWALL.
Public Server Wizard - Quickly configure your SonicWALL to provide public access to an internal server.
VPN Wizard - Create a new site-to-site VPN Policy or configure the WAN GroupVPN to accept connections from the SonicWALL Global VPN Client
Thanks
Apr 22, 2009 | SonicWALL TZ170 (01-ssc-5740) Firewall
Sonicwall Safe mode Problem
How do I access the SafeMode menu?
In emergency situations, you can access the SafeMode menu by holding in the Reset button on the back
of the TZ 180 (it’s the small pinhole button located to the left of the Console port) for 12-14 seconds until
the ‘Test’ light begins flashing yellow. When the SonicWALL is booted into the SafeMode menu, assign a
workstation a temporary IP address of 192.168.168.200 and attach it to a LAN interface on the TZ 180
Then, using a modern web browser (Microsoft IE6.x, Mozilla 1.4+), access the special SafeMode GUI
using the device’s default IP address of 192.168.168.168. You will be able to boot the device using a
previously saved image, or you can upload a new version of firmware with the ‘Upload New Firmware’
button.
Apr 07, 2009 | SonicWALL TZ 170 Firewall
Cannot connect with SonicWall VPN Client with GigaFast EE420 R
sonic is sitting on the gateway. so dont matter where u are still u cant get outside
Jul 29, 2008 | Computers & Internet
Netopia 3347
Netopia 3347 has 4 lights on it,pwr,dsl,lan internet.
Internet light should be off on the CPE and u need to disable DHCP in the Netopia as well to communicate with Sonicwall.
Jun 08, 2008 | Computers & Internet
Help with installing a sonicwall soho tzw no software.
Hello dlewis2900, What I want you to do is to reset your router by locating the Reset button on the back of the SOHO TZW next to the LAN connection. Using a pointed object, press and hold the Reset button for 5-10 seconds. All settings are returned to the factory default settings including the password and the default LAN IP address of 192.168.168.168. The I want you to reenter your ISP information and configuration settings. Once this is done try to ping your gateway (ISP gateway router) address. Then try to ping the internet try to ping this address: www.dslreports.com This is the quickest way to get back to where you want to be without trying to redo a lot of configurations.
Sep 03, 2007 | SonicWALL TELE2 Firewall
Sonicwall Pro 300 DMZ Problem
If you're within a network and try connecting to computers on it with the WAN public IP, it simply won't work - you must use the network IP. On an external Internet connection, it should connect fine to the public IP. If you have access to an external machine (remote desktop), or if you know of an FTP proxy, you can try it that way. I also believe http://www.webftp.co.uk/ a web based FTP client would act as somewhat of a proxy, you could try that with the public IP and see how you go.
Aug 09, 2007 | SonicWALL PRO 300 Firewall
Sonicwall tele2
Hello ask4jon, I gave this advice at an earlier time and I think it applies here to. What I want you to do is to reset your router by locating the Reset button on the back of the SOHO TZW next to the LAN connection. Using a pointed object, press and hold the Reset button for 5-10 seconds. All settings are returned to the factory default settings including the password and the default LAN IP address of 192.168.168.168. The I want you to reenter your ISP information and configuration settings. Once this is done try to ping your gateway (ISP gateway router) address. Then try to ping the internet try to ping this address: www.dslreports.com This is the quickest way to get back to where you want to be without trying to redo a lot of configurations.
May 29, 2007 | SonicWALL TELE2 Firewall
Computers & Internet Logo
David Payne
David Payne
