Question about Toshiba MW20F51 20 in. TV/VCR/DVD Combo
Where do you plug in power cord for toshiba 20 inch tv
Can't figure out where to attach power cord
    Master:
  • Toshiba Master
  • 752 Answers
The power cord for this model (MW20F51) appears to be permanently connected to the unit as on (the bottom of) p.11 of the manual, which you can find here
http://support.toshiba.com/support/modelHome?freeText=2841937
Simply pug the other of this lead into a mains point at the wall. It may be helpful for you read the manual before you do this, because it contains the set up information. You should save or print of the manual (there are 72 pages by the way) for reference if you not have a copy.
What country are you in, Jean ?
14.April.2014
Posted on Apr 14, 2014
I need a power cord...where can I get one?
Something like this. Make sure you order the right plug and make sure yours has a figure 8 connector to the back of your television.
UpBright NEW AC Power Cord Cable Plug For RCA 22 26 32 40 42 inch Series...
Jan 01, 2016 | Iview International 22 inch LED TV with...
Older-model Toshiba TV shuts off by itself
There is a large sand filled resistor on the main board close to where the power cord attaches that cracks. This will stop power until it cools enough to make the connection then heats up rapidly to open it again. It may be worth the trouble if you're handy with a soldering gun and can get the back off the TV. If not then I'd consider getting a flat screen.
Aug 21, 2014 | Televison & Video
Toshiba tv/dvd won't turn on
Check the reset button, wall socket where it plugs in, power cord, and if equipped cabinet interlock.
Bypass the on/off switch with a known good one.
Next check the voltage setting device it could be faulty.
It usually is set for 125v.
good luck!!!
Feb 24, 2013 | Toshiba 20a43 20" TV
Toshiba 52 inch TV turns on then blacks out.
Unplug the power to the TV and HD cable box, wait 5 min. Plug TV and HD cable box back in.Everything is working like new. Go figure.
Sep 29, 2009 | Toshiba Televison & Video
My toshiba dvd/tv combo power button just stopped working. Where do I find the fuse box?
Make sure it is unplugged then follow the power cord to the board it is right in front of where the power cord attaches to the board.
Sep 04, 2009 | Toshiba MD20Q42 20" TV/DVD Combo
Toshiba 32A33 After a power spike
The main power fuse inside the TV may have blown. The rear cover must be removed to check it. Unplugging the power cord from the wall outlet is the first safety item. Finding all the right screws to remove the cover (without taking out some you shouldn't) is sometimes tricky. When you remove the cover the power cord will still be attached inside, so remove the cover carefully. There is a danger of touching residual high voltage near the picture tube. Carefully look for a fuse near where the power cord attaches to the circuit boards. Often the fuse will be obviously burned open (the small conductor inside the clear glass is melted or the glass is blackened). Replace only with a fuse of the same type and amp rating. Putting a higher amp rating fuse or slower acting fuse can have costly and possibly dangerous consequences. Be sure to plug the power cord in when you do your test with the new fuse. If you haven't done anything close to this before, you may want to refer this job to an expert.
Aug 11, 2009 | Toshiba 32A33 32" TV
The electricy plug and cord
If The Unit Is Under Warranty There Is A Good Chance You Will Void The Warranty. But If The Unit Isn't Under Warranty I'd Go Ahead And Pull The Real Of The Tv And Repair The Power Cord Just Make Sure Everything Is As It Should Be Before You Put The Tv Back Together And Make Sure There Are No Exposed Wires Anywhere.
Sincerely,
Michael Scott
Feb 09, 2009 | Toshiba 53H71 53 in. Rear Projection...
20DL74 toshiba- Power cord was missing
Hi redneb711,
I am happy to help.
The cover on the back of the tv has to be removed. Facing the back of the tv at the bottom of the cover on the sides are Arrows, press in on these arrows and pull towards you.
The cover should hinge from the top and come off.
The power adaptor plugs into the bottom hole below the inputs.
I have provided a link to the manual. http://www.toshiba.ca/web/pdf/14,20DL74.pdf
let me know if you require further assistance and please rate this solution. Lone99star
Jan 27, 2009 | Toshiba 20DL74 20 in. EDTV-Ready LCD...
Looking for a power supply
Sorry about the above post, but I wasn't signed in yet and this crazy GLITCH here put me down as a GUEST instead. The above post was mine, as I'm resending it again below.
Thx,
Frank
FRANK'S FIX IT SHOP
AC/DC power adapter + Power cord. 24VDC power adapter + power cord for Toshiba 20HLV15 20" Flat Panel LCD TV
Specification:
Input :100-240VAC (50-60Hz)
Output : 24VDC 4Amp (72W)
Part# ADP-2404-3PX
Approx cost: $50-60
Call Toshiba USA and give them that p/n for an exact cost quote plus shipping.
Best regards,
Frank
Apr 01, 2008 | Toshiba 20HLV15 TV
No picture, sound and flashing red power light...
Pull off the back pressboard. At the bottom left hand corner is the power cord that attaches to the power supply board. There is a white plug that attaches directly to the power cord. With the TV power off, pull this white plug up to disconnect. Then push it back in. Then plug your TV back in and press the power button on the front of the TV. I just did this and it is working fine.
Sep 16, 2007 | Toshiba TP43H60 43" Television
Toshiba MW20F51 20 in. TV/VCR/DVD Combo Logo
69 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
