Question about Orbit Hardware & Accessories
Timer is off on day of the week watering schedule.It won't let me set the next day for watering
Have tried numerous ways to fix and nothing is working
    Scholar:
    New Friend:
  • 92 Answers
I am not familiar with your particular timer, but with my timer, I seem to experience a similar problem unless I regularly replace the back up battery. Conceivably, a drop in power, not enough to affect the rest of your electrical components is enough to cause the timer to mal function. ?? Best guess.
Posted on Apr 14, 2014
SOURCE: Utilitech Self-Adjusting Wall Timer- #0192773.
Here is the url to the pdf file. You can then magnify your computer screen.
http://www.thencc.com/LS/Instruction/LW60418_Instruction.pdf
Posted on May 14, 2010
SOURCE: Set up Intermatic outdoor timer 7day/7event
I have misplaced and forgot how to set a Model HB65R timer, can you help, thanks, Murray
Posted on Dec 24, 2010
SOURCE: Instructions to set Woods indoor timer 59377
Open following link to identify timer and download manual
http://waterheatertimer.org/Woods-timers-and-manuals.html#59377
To set current time, press and hold clock button while pushing hour and minute buttons.
Then release clock button
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Feb 12, 2011
aquaman987
  • 927 Answers
SOURCE: I have a Vigoro Water
Probably every third day is represented by 3.
Gary
Posted on May 31, 2011
  • 5245 Answers
SOURCE: how can I manual turnon my nelson timer
Open following link to help identify Nelson timer, then re-post question with model number so expert can access the manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#FM1D
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on Jun 25, 2012
How do i set the system to run 2 times per day
You have multiple start times in 1 or all of the programs A,B,C or D. 1 start time in the A program will run the zones in this program once on the days it is schedule to water. Example: Think of each program as a separate timer. All want to know 3 things What time to water, how long to water for and what days to water. Timer 1 is the A program. Set to water everyday at 8 am for every zone which has a duration. Don't want the plants to water everyday take the minutes out of zone run time in this timer or the A program. Want the plants to water M,W,F add a start time, a run time to corresponding zone and M,W,F in timer 2 or B program. Want the plants to water twice in a 24 hr period add a second start time to each timer or program. and so on. The programs are only used for watering schedules with more or less days per week you want a specific zone to water. Otherwise use only the A program with 1 start time for once a day or whatever days you desire for all zones.
Jan 03, 2014 | Weathermatic ProLine PL1600 Outdoor/Indoor...
Is the sunvic sp2 a 2channel timer please
Yes. It appears the Sunvix SP2 is 2-channel timer.
http://www.sunvic.co.uk/documentation/Programmer_Select_207.pdf
Two-channel means CH central heat and WH water heater can be programmed separately, and each can have its own timing program.
pg 3
The timer offers pre-programmed options for both CH and WH, which can be used, or program your own schedule. chart pg 5 and steps pg 3
Limitations: both channels operate on same clock time, and dip switch setting. pg 6. So the WH cannot be programmed for 5-2 weekdays-weekends and CH programmed for 24 hour.
As a convenience for varied work schedules, Sometimes people use the 5-2 weekday-weekend option so 2 days of week can have different programming, and then fudge current day setting during the set-current-time step pg2 so the 'weekend days' are actually moved to wedsday-thursday instead of sat-sun.
Option: both CH and WH timer programs can be linked and follow same programming by using copy button. pg 5
Using advance button on either side of timer, pg 3-4, WH and CH timing schedules can be overridden temporarily until next set point is reached. Then regular programming automatically resumes.
If override or Advance button is pushed for either CH or WH, it reverses whatever programming is in effect. On becomes off, or off becomes on. However if CH thermostat is satisfied and room temperature has not fallen below thermostat set point, then override will not turn CH on, but override will turn CH off. Same for WH override: If cylinder thermostat is satisfied with internal water temperature, the water heater will not turn on and heat more water, but the override can turn water cylinder off.
Unit requires Cr2033 lithium button battery. Pg 6. Probably lasts 3-5 years. Programming is protected for 30 days from power outage.
If programming is lost, change battery, the reset timer and reprogram to restore functionality.
Nov 24, 2012 | Hardware & Accessories
Ferroli optimax he plus 31c boiler timer instructions
Why does the display appear and i can set timer but then display goes blank and i carnt getthe lcd screen to display anything at all??
Dec 19, 2011 | Heating & Cooling
Verve Digital Water Timer as sold at B&Q have lost the operating instructions.
Verve water timers might be Melnor:
Open following link for manuals.
http://www.melnor.com/instructions.php
Links to other water timer manufactures and manuals are found on following link:
http://waterheatertimer.org/How-to-program-Gardena-C1060.html#manuals
Jun 14, 2011 | GARDENA Water Timer
I have Intermatic sprinkler model T8845pv. I want to set it for daily watering in only one of 8 zones. When I remove the gold pins in the main dial and locate the zone I want to water, it waters the...
Intermatic sprinkler timers are 24 hour repeat cycle, with day-skipper option.
The timer does not change zones. The timer just turns ON-and-OFF at scheduled times.
Each tripper represents 12-15 minutes of watering. And then the timer circuit turns OFF.
When timer circuit turns OFF, the sprinkler system is designed to advance to next zone each time.
So when the timer circuit turns OFF and then turns ON again, your sprinkler control starts watering the next zone. This is the way sprinkler systems are designed.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
If you had a sprinkler system with 1 zone, or could change your sprinkler system to 1 zone on certain days, then the timer would turn that zone on-off each time.
Call a local sprinkler company and see if they have a dual control or some solution >> but sprinkler controls are outside my area of expertise. I am timer expert.
You could solve problem with two separate sprinkler systems, but that would require two timers. I have never seen a 2-channel sprinkler timer. There are electronic two-channel timers that can handle two different programming schedules with minimum 1 minute on-off, and these timers can cost a few hundred dollars up to thousands, PLUS cost of the dual sprinkler system. Add a comment and let me know if two-channel timers are something you want information on.
Apr 27, 2011 | Intermatic R8806P101C -...
Gardenline - garden tap timer.I can't work out the instructions- the timer won't work . Please help and give me an easy guide line to the instructions.
1. Press PROG
2. Press up/down arrows to select the programme you wish to set (16 spaces are available)
3. Press SET
4. Press up/down arrows to set the hour at which watering is to start
5. Press SET to store the hour
6. Press up/down arrows to set the minutes at which watering is to start
7. Press SET to store the minutes
8. Press up/down arrows to set the number of hours over which watering is to take place (0-9)
9. Press SET to store the hours
10. Press up/down arrows to set the number of minutes over which watering is to take place (0-59)
11. Press SET to store the minutes
12. Press up/down arrows to select which days of the week watering is to take place (2nd means every second day, 3rd means every third day). When the required day of week is displayed press SET to store that day. The next day of the week will then be displayed and Set can again be used to store that day. Carry on throughout the seven days of the week as required.
13. Press the clock symbol to store the programme.
Mar 07, 2011 | Hardware & Accessories
Hey guys, the 15079 GE timer has 20 on/off settings. Are they for the whole week?
Eeeckles,
The timer you mention 15079 does has 20 on/off settings that can be set during a 1 week period that will then repeat each week. For example Setting 1 could be to come ON on Monday at 5:00pm and turn OFF Monday at 11:00pm while setting 2 could be to turn ON on MWF at 3:00pm and OFF MWF at 3:30pm.
You can find all of the UPDATE GE Timer manuals at the manufactures website: http://www.jascoproducts.com/support/timer-quick-start-guide.asp
Blessings!
Dec 31, 2010 | Jasco 15079 SevenDay TwoOutlet Digital...
Have a fleck 5600 water softener timer (not economider) dont understand the setting of the days of week when there is 12 pointers on the skipper wheel?
The 12 day wheel is used primarily so that the unit does NOT regenerate on the same day of the week, every week.
There is a 7 day wheel available for this valve so if you irrigate on specific days, and you need it to cycle on specific days, you have the ability to do it without the softener cycling at the same time as watering schedule.
Nov 15, 2010 | NRS Fleck 5600 - 64,000 Grain Timer Water...
I have a IIIWoods timer #59203WV and have trouble programming it to turn on and off exterior lights. Thanks for your response.
Manual:
http://waterheatertimer.org/pdf/Woods-59203.pdf
59203 plug-in timer: your outdoor lights have to plug into side of timer.
If you want a timer to replace outdoor light switch: buy in-wall timer Aube T1032 or Lowes sells Utilitec 0192773.
http://waterheatertimer.org/Programmable.html#Aube
Add a comment for more help with in-wall.
Here are instructions for 59203 plug-in timer:
Plug in the timer until battery is charged.
Unplug timer so you can program easily.
Press R reset button with paper clip to clear.
Set the time of day:
Press and hold clock button
Press hour button until current hour shows
Press minute button until current minute shows
Press day button until current day shows.
Release clock button
Program review:
Write out ON-off schedule showing hours minutes and days
For example: timer turns ON 6:00 pm all days of week.
Timer turns OFF 1:00 am all days of week.
First step: Set program1 ON > hour, minute, and day.
Next step: Set program1 OFF > hour, minute, and day
If needed, go to next step: Set program2 ON > hour, minute, and day
Next: Set program2 OFF > hour, minute, and day
How to program timer for ON at 6:00 pm and OFF at 1:00 am all days of week:
Step 1: Press PROGRAM button until display shows 1 ON (this is program1 ON)
Press hour button until 6 pm shows
Press minute button until :00 shows
Press day button until all days of week show (MO TU WE TH FR SA SU)
Step 2: Press PROGRAM button until display shows 1 OFF (this is program1 OFF)
Press hour button until 1 am shows
If you want to set another program, you will repeat same steps for program2
Press PROGRAM button until display shows 2 ON
If you are done programming, press clock button
Press ON/AUTO/OFF button until AUTO displays
Nov 13, 2010 | Woods INDUSTRIES 83660 OUTDOOR SECURITY...
How do i set timer
How to program Raindrip R673CT
Download R673CT manual at raindrip
Other models
R683CP
R672CT
Raindrip drip water guide
R673CT
Install 2 AAA batteries to power display
Set current time:
Press TIME and hour digit flashes > Use up-down arrows to set 24 hour clock
Press SET to confirm hour
Use up-down arrows to set minute
Press SET to confirm minute
Use up-down arrows to set day of week
Press SET to confirm day
Program review
Timer can set 16 watering schedules
When programming, look at display:
Notice: PROG for programming mode, #1, start time, run time, SU MO WE for days
Press PROG and display appear just like image above
Use arrows to select 1, 2, 3, 4 through 16 different watering schedules
Programming
Start time hour will flash
Once hour flashes, use arrows to select hour
Minutes will flash
Use arrows to select minute
Press SET to confirm minutes
Run time hours will flash
Use arrows to set run time hours duration (0 to 9 hours)
Run time minutes will flash
Use arrows to set run time minutes
Press Set to confirm
Now #2 shows on display this is about which days the timer will water
Decide 1) every other day, 2) every third day, or 3) watering at will
1) To water every other day:
While 2nd is flashing, press SET and SU TU WE FR will appear in display
2) To water every third day:
While 2nd is flashing, press down-arrow
3rd will start flashing and TU WE SA will display
3) To water at will:
While 2nd is flashing, press down-arrow twice
SU will flash
Press down-arrow to go to MO TU WE etc
Press SET when day you want appear on display
To set another watering program
Scroll back up to "programming" on this page
Press arrows to select programming 1 thru 16
Repeat programming sequence
After programming is set, press clock button and current time will show
Oct 07, 2010 | Raindrip R673CT Digital Water Timer
Hardware & Accessories Logo
53 people viewed this question
Top Orbit Hardware & Accessories Experts
Craig Butler
Craig Butler
Hippy_dd
Are you an Orbit Hardware and Accessory Expert? Answer questions, earn points and help others
