Question about Speed Queen AWS44NW Top Load Washer
Speed queen spin
The washer machine shake violently
  • 351 Answers
SOURCE: speed Queen home washer will not spin/drain
check belt size
Posted on Mar 29, 2008
  • 177 Answers
SOURCE: Speed Queen Top Loader heavy duty washer
First unplug the machine, now take off the front panel, two screws at the bottom of the front panel, front panel swings up and off.
check to make sure the six springs are still in place.
Under the tub is bearing housing between the tub and base usually white in color, under this is a plastic ring, does it seem to float easily when you move the tub. it could be broken. Also look around for loose or missing screws.
If all seems fine, make sure you have all four rubber feet on, level machine, in the front first side to side, then pull machine toward you to bring rear legs off floor, these are self leveling, have someone assist and make sure they are not stuck, use a pliers and break loose if they are. So with the machine on its front feet and the back feet off the ground set the machine down on all four feet check level front to back adjust as needed on the front legs. You should reset rear legs as you adjust the front. now with machine level tight the nut between the front legs and the base locking them.
This should help, if machine still shakes it could be the balance ring, has lost if solution its filled with a salt water solution, the hard part is you need to find it under the tub cover. we will go into the detail if we need to. ask more questions later
Posted on Jul 08, 2008
  • 14 Answers
SOURCE: I have a speed queen washer. Last wash my
the seal in the transmission is bad
Posted on Feb 22, 2009
mhamlin63
  • 138 Answers
SOURCE: What is the capacity (Size) of the Speed Queen Marathon Washer?
Pi,r,squared times height. Remember math back when we didn't have computers? So that's 3.14 x radius(half the distance across drum)squared(times itself) times height or depth of drum. Remember to do radius times itself first, then Pi, then height.
Posted on Jun 29, 2009
  • 142 Answers
SOURCE: SPEED QUEEN WASHING MACHINE LEAKS WATER WHEN IT STARTS WITH WASHU
check hoses and pump area.
Posted on Sep 14, 2009
My Speed Queen washer shakes and walks during the spin cycle. I have leveled the machine and ajusted the amount of clothes in subsequent loads and it still shakes. How do I solve this? Thank you!
Did you remove the shipping bolts from the back of the washer? They are located on the back, usually very clearly marked "REMOVE" and have a red or yellow plastic washer/bushing. This is a fairly common problem with front load washers, from what I understand.
They're big suckers, and they keep the drum suspension from absorbing any vibration (so the drum doesn't slam around during shipping). Good luck!
Jan 27, 2011 | Speed Queen CTSA0AWN Front Load Washer
Front loading machine shakes violently during spin
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 14, 2010 | Washing Machines
My brand new amana washer shakes violently when spinning
try adjusting the feet on the bottom of the washer the floor may not be level to adjust the legs turn them with a wrench or if the lock nuts are not tight turn the legs clockwise as you look at the front of the machine till all four feet are sung on all 4 corners. This is the most common problem. hope this helps and thanks for using fix-ya
Feb 15, 2010 | Washing Machines
Kenmore Oasis HE shakes violently during spin cycle
Machine legs should be adjusted so that machine is level and standing on all four legs. The load in the machine should be evenly distributed. Utube has an excellent video on washing machine repair.
Nov 20, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Shakes violently in the spin cycle
hi...
the reason it shakes violently is because
1)Most noisesfrom a washing machine occur during the spin cycle. If you hear loudthumping during the spin, the load of clothes may have becomeunbalanced. Stop the washer and redistribute the clothes, then re-startit. Repeat these steps if necessary.
or else the other reason may be
2) If your washer doesn't spin or agitate on either the delicate or regular cycle, check these:
Selector switch
Clutch assembly
Drive motor
Selector switch Ifyour washer has a selector switch on the control panel, make sure thebutton for your selection is pressed all the way in, or set properly.
Clutch assembly ManyGE®/Hotpoint® washers use a clutch and an automatic shift lever. Thisassembly is quite complicated. If there's a problem with it, youprobably should contact a qualified appliance repair technician.
Drive motor manywashing machines have multiple-speed drive motors. Though it'suncommon, the drive motor may work fine on one speed but not onanother. If the drive motor has failed on one speed, you need toreplace the entire motor.
On something like this you will need to
remove the washer wrap toinspect the suspension springs & base assembly. Be sure the shippingpins have been removed. The tub should float freely.
I think my solution would have helped you...rate for me if it is been useful.....thank you for using fixya....
Jul 20, 2009 | Admiral Washing Machines
Shake when spins even when no clothes in it
Make sure the lags are solid to the floor. Any bit of difference will be exagerate when the washer spins. put a piece of paper under each of the front legs. While the washer is spinning try and pull the paper out. If you can pull the paper out with no problem, that leg needs adjusted to the floor more. If Ican help further, please let me know
THanks
Vic
May 15, 2009 | Speed Queen ATS90AWN Front Load Washer
Samsung P801 Front Loader shakes violently during spin cycle.
When the washer goes into spin cycle it is suppost to start at a slow speed and continue to increase speed (to a maximum of 800 RPM) as the water leaves the clothes. Your washer is going directly to 800 RPM which causes the washer to shake and stop giving you the E4 code. The control board that controls this speed increase must be replaced.
Feb 23, 2009 | Hotpoint Ultima WD72 Front Load...
Washer shakes violently when spinning at high speed.
is the washer level and on solid surface both will cause machine to dance
Feb 06, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer shakes on spin cycle
2 possible causes 1 cleanout filter and check water is pumping out properly before spinning
2 check the suspension legs at the base of the tub for wear or damage.
Oct 29, 2008 | Speed Queen AWS52NW Top Load Washer
Speed Queen AWS44NW Top Load Washer Logo
26 people viewed this question
Top Speed Queen Washing Machines Experts
Terry Schneider
Dan Webster
Dan Webster
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
