Question about KitchenAid KBRS22KG
Freezer section will only lower temp to just above freezing level. Refridgerator is working well
2 Suggested Answers
  • 157 Answers
SOURCE: cold air only in freezer.
This sounds like a classic case of defrost system failure, the coil in the freezer is iced up - freezer will run at 32 fridge around 55. turn off unit, get heat gun, manually defrost unit(be careful!). either your timer or defrost heater assembly has failed, if you de ice coil unit will work until you can get a service person to diagnose bad part and replace
Posted on Jun 22, 2011
D50BP keeps freezing up with frost
That model number refers to a dehumifier made by Freidrich. this is the refridgerator section. For a dehumidifier to work right the temp in the room needs to be 65 degrees or better. The machine is designed for use in temps over 65. A freezer or Fridge will do the same thing if used in a cold area. It works by cooling the coils to close to freezing in normal temps, but when it is colder than 60, the evaporator may cool below freezing temp of water and the condensate will then freeze on the coils.
Dec 31, 2017 | Frost Refrigerators
Refridge temp
Lets go over the way a sealed system works. There is a highj side and a low side. The low side is the side that passes through the evaporator coils inside the machine. Most times on the freezer side only, but sub zero has independent sealed systems for each side. Once it goes throug the evaporator its then condensed into a liquid state, the high side. This is also the hot side. Well, lower pressures in the low side would logically mean lower temperatures. So for the refridgerator not to freeze more freon is used on it to keep the low side pressure higher than normal, giving the cooling effect verses freezing. So, and here is the bad part, if you are seeing ice build up in the refridgerator side you have a freon leak some where allowing the pressure to be less than required to keep it above freezing. Call a service technician and depending on how the model, sub zero warranty is parts and labor covered for the first 6, and only parts from the 6-12 year.
May 27, 2012 | Sub-Zero 642
How do i set the temp on this unit
Look behind the louvers (you must remove them) on the upper right, above the freezing section. Should be a black knob with a built-in pointer on it.... higher numbers are for a lower temperature.
Jun 17, 2011 | Traulsen 46 cu. ft. Commercial Freezer...
Freezing items in refridgerator
make sure the air passages are not blocked with food produts the other fix might be to un plug refrig and let it defrost for a day make sure you leave doors open
Dec 31, 2009 | GE GSS25LGM Side by Side Refrigerator
Refrigerator side not cooling
The fresh food section is cooled by the freezer section by forced air supplied by a fan. If you have air flow, check the temp inside the freezer. It should be between 0 and -10. If not look inside your freezer and see if you have ice built up on the back panel. If so you have a defrost problem that is most likely a bad defrost heater, a bad termination thermostat or timer. If ther is no ice then check your fan under the refrig. If you can hear the compressor running it should be turning. If this all checks out then you have a freon system problem like. Low Freon pressure or a restriction.
Aug 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refridgerator problem
Not sure about your model, but most of these style side by side refridgerators use the cold air from the freezer to cool the refridgerator. Sounds like your "flapper" valve is broken. At the top left in the refridgerator there should be plastic shroud. Remove it and your flapper valve should be under it. You will most likely find the flap broken off of it. You may have success using epoxy to glue it or you may have to replace the valve assembly.
Good luck.
Apr 20, 2009 | Frigidaire FRS26H5AS Side by Side...
My norcold frig(RV) freezes food in lower level
in your refridgerator there is an internal thermostat on the cooling fan u can move up or down it should be placed on the last finn to the right looking at the fridge
thanks
cruz
cruz's mobile rv repair
Dec 16, 2008 | Thetford Norcold RV Cooler/Freezer
Food freezing in refrigerator section of frig.
look under your refridgerator and see if there is alot of dust on the coils. Whenever food starts freezing in my fridge I vacuum the coils and the problem goes away.
Sep 01, 2008 | Refrigerators
Whirlpool Freezer doesn't freeze?
insulated or not, garages are generally too cold for new energy efficient frigs to operate. ambient temp needs to be above 60 to work efficiently.
Mar 07, 2008 | Refrigerators
Refrigerators Logo
24 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
