Question about Dryers
GE VD7002KW419 door pops open - Dryers
    Prodigy:
    An expert who has answered 500 questions.
  • 512 Answers
That looks more like a serial #, anyway there is a small plastic square piece on the dryer and a short blade type on the door they fit together when the door is closed and hold it closed it sounds lkijke that is worn out and needs replaced
Posted on Apr 14, 2014
2 Suggested Answers
SOURCE: How to open the dryer and replace the belt
all dryers open from the top so open the dryer door and look inside the top edge you will see two screws . remove the screws and lift the top panel . the front panel has two screws on the top one on the left and one on the right remove them both and lift up the front panel to remove it. the only way you can install the new belt is removeing the front panel because the belt goes around the drum from the front. once you remove the old belt out put the new one in . the belt goes around the drum from the front and then to the motor and idle roller . you can reach the idle roller from the front left corner or from the back of the dyer? i like to install them from the back cause its more easy. in the back of the dyer where the hose goes connected to the blower is the top with four screws remove the hose from the blower tube and remove the four screws. after you remove everything you should be able to see the dryer motor and idle rooler put the belt over the motor first then over the idle rooler .always make sure when you do this the dyer is unpluged and after your done plug it back and turn it on to make sure it runs correctly . if it runs ok put everything back together again.
Posted on Jan 11, 2008
How do I dissemble dryer ge model vd7002kw419
Go to www.repairclinic.com and enter vd7002kw419. With luck, you will be presented with a list of common replacement parts and may be able to view a generic GE video showing disassembly.
Aug 31, 2017 | GE Dryers
Is there a kit to repair French Door from popping open GE model# PFS2251SBSS
Check to see if the door is warped or the hinges are not aligned. Also, does the door open easily or does it take a little effort to break the magnetic seal? If it open easy then the door seal could need replacing.
Jul 25, 2014 | GE Refrigerators
GE refrigerator model #LTC19340ST freezer door not sealing
That is a common problem with over-under units. You can clean or replace the door seal or, tilt the unit back a TINY bit. The door pops open because there is a common airway from the freezer to the fridge. When the fridge door shuts too fast, it pushes a lot of air into the unit. It needs to go somewhere so, it pops the freezer door open. If you shut the freezer hard enough, you will be able to pop the fridge door open.
Jan 20, 2013 | LG LTC19340ST 19.0 cu. ft. Top Freezer...
My dryer's belt broke and I cant find the part
WE12X1001, WE12X1000, WE12M29 are the three different belts used on GE Dryers and if you go to
https://www.geapplianceparts.com/GEApplianceParts/Dispatcher and do a search on these parts you will be able to purchase them directly from GE. You will need to look at your belt and pull the number off if your belt in order to assure you get the right one. If you require further assistance, please do not hesitate to ask.
Jun 14, 2011 | Whirlpool GEQ8858H Dryer
GE French door fridge problem. When you close one door the other door pops open alittle most of the time. Is this normal on french door fridges?
Hello, In a word, Yes. It is totally normal, when you close a door it pushes air into the unit and depending on how it is closed the other door will "pop" open slightly from the "push" of air. Thanks for coming to fixya. macmarkus :)
Jun 20, 2010 | GE Profile 20.7 Cu. Ft. Side-by-Side...
GE profile freezer door pops open
If you close any refrig door " fast " , the other will pop open . These magnetic door gaskets , are designed for lighter holding power now , than they used to be , due to children getting caught inside . I would suggest lowering the front legs slightly , so that when you let go of the door , it will close slowly on its own .
Sep 29, 2009 | GE Profile PFS22 33" Artica French Door...
Freezer door pops open when fridge door is closed.
well u need to check the rubber of ur freezer ;s door .some damaging in the rubber is causing the problem.
May 26, 2009 | Amana ARSE66MB Side by Side Refrigerator
Top freezer door pops slightly open when frig door is closed
try to adjust hinges and check the door gaskets for pinching. Also I have seen that if the fridge is slightly pitched forward and not slightly towards the back gravity sometimes this causes the problem you describe.
Apr 26, 2009 | GE Refrigerators
Dryers Logo
76 people viewed this question
Top Dryers Experts
