Question about Mag Innovision Computers & Internet
No sound on computer- MAG Innovision Model 468
Troubleshooting says no speakers attached. Worked fine before I moved, upgraded to Windows 7. Video works fine.
  • 30 Answers
Solution 1 It might have defaulted your sound button to mute Got to control panel Sound and see if sound has been muted
Solution 2 unplug jack out of plug at rear of computer test it in other jack holes what might have happened is that the default setting for speaker and mic might have swapped round best way is play some music and move jack plug around see if you get any sound
Solution 3 Sometimes the sound software needs re setting bring it up and re sett speekers and mike setting by the colours you have you jack in remember front and rear you will be mainly dealing with rear jack interface green pink blue white etc
hope this helps
Posted on Apr 14, 2014
  • hitabandi970 Apr 20, 2014
    Son set up after move, so never mess with "spaghetti junction" on back, but moved one plug from orange to green, and it worked! Thank you!
  • 556 Answers
SOURCE: MY MONITOR SPEAKERS
as you say that old speaker is working from the same tower means your computer is ok.
the problem is in speaker only.
plz chk that while shifting some wire must have broken or loose or speaker not connected properly.
ultimately chk connection.
Posted on Oct 17, 2007
mukund_ce
  • 186 Answers
SOURCE: i need driver monitor mag innovision for install
Chek Ur OS and download drivers from here :
http://list.driverguide.com/list/company621/
Posted on May 16, 2009
romsky79
  • 822 Answers
SOURCE: Monitor only power's on NO sound and No Picture
check your cable to speaker of your monitor and to the audio output of your pc.
Posted on May 20, 2009
SOURCE: MAG Innovision LT1919WDb flat screen goes black
When a monitor works for a few seconds or more and goes black it is a problem with the power inverter board over heating because of a bad capacitor or capacitors that are not the right size. There is no problem with the VGA controller since it shows video for a few seconds. I have fixed a lot of Mag LCD monitors with changing just two small capacitors for $0.50 a piece and some of my time to solder them in. Less time as i have gotten better. You can buy the capacitors on Mouser Electronics Online. Just make sure they are the right size and dimensions. I have one of these monitors on my table now and have not determined the exact capacitor that is the issue. I have change five out and it is still doing the same. Four more to go. None of the capacitors looked bad, thus the prcess takes longer. Good Luck
Posted on Sep 22, 2009
SOURCE: My mag Innovision flat lcd monitor is blank after 3 seconds..
you shouldnt have to break the clips. my boyfriend got to that point and found that he could slide the plastic off without breaking them
Posted on Aug 31, 2013
I have a MAG Innovision Model 468 LCD Monitor and a Compaq computer, how can I get the monitor speakers to work?
There should be a wire to connect between the speaker output of your soundcard (usually the green connector) to the monitor's speaker input. It should be a "mini" plug, 3.5mm diameter. Make sure your speakers are not muted in the audio/sound controls on the computer.
Aug 24, 2011 | Computers & Internet
Does a MAG monitor model 900P have in built speakers?
Yes the Mag 900P has built in speakers. The audio lead for them is attached to the blue VGA connector and has a green tipped plug like a set of desktop speakers.
Oct 10, 2010 | Mag Innovision LT776s 17" LCD Monitor
I just upgraded to windows 7 and i have a mag innovision monitor and i am not getting any sounds
its because some of your device is not compatible with the windows 7...try to find the installer of you sound device....
Nov 20, 2009 | Computers & Internet
On my Mag Innovision model 700 P lcd monitor, the integrated right side speaker does not produce any sound. In XP control panel I do have both left & right speaker set to max.
On the plug to the computer sound card, is the plug completely inserted? The end of the jack is for Left channel and the right channel is only fed if the plug is fully inserted.
Nov 08, 2009 | Mag Innovision InnoVision DX 700T Monitor
May 20, 2009 | Mag Innovision LT982s 19" Flat Panel LCD...
I have a mag inndvision moniter i need diver
windows 98 will not have any drivers for video , monitors
don't need drivers
upgrade windows
Aug 01, 2017 | Mag Innovision M572TVs LCD Television
Speakers
make sure windows volume control is up.
its the speaker next to the time and date ,on tool bar ,bottom left normally.
play a song or video or such.
then check the cable in back of monitor it has a plug/connector that looks like a headphone jack /plug
follow it to the back of computer its color coded.
be certain the speakers have power if needed they will plug into monitor dc jack if the speakers are removable.
and check the vol control on the speakers.
May 11, 2008 | Mag Innovision InnoVision LT 765S 17" Flat...
Mag Innovision product # LT765s model #780
monitor is looking for the video signals--move mouse and try power on
Jan 07, 2008 | Mag Innovision LT776s 17" LCD Monitor
Computers & Internet Logo
52 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Rommel Balcita
Tony
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
