Question about Coffee Makers & Espresso Machines
Alessi RS07 bottemplate - Coffee Makers & Espresso Machines
I have an Alessi 9098 stainless steel pepper mill given as a wedding gift. It fell from a table and the blue fin broke. Is it possible to buy the blue fin? If so, how would I go about it?
Yes! you can get the part here:
http://www.connox.com/categories/spare-parts/replacements-alessi/spare-parts-alessi-pepper-grinder.html
Its 6 euro
Feb 06, 2013 | Alessi 9098 Pepper Mill
I need to know what parts are missing to my 9090 espresso pot . It has the top and bottom sections, the pressure valve and the funnel basket but no washer. is there anything else I need to make it...
The 9090/6 designates the 6-cup (30cl) model. In metric it is designated as 20.5cm (~8") high by 12.5cm (~5") in diameter. The washer holds a metal strainer disk (which you may be missing) to the underside of the top piece. You can buy washers--and maybe strainer disks--from Alessi stores. Check the Store tab on www dot alessi dot com.
Nov 02, 2009 | Alessi 9090/6
Alessi whistling kettle -- one whistle doesnt work.
you need to replace it with a new one it will be corroded. heat kettle then drive out pitch pipe with a screw driver from below, insert new one from above.
Sep 24, 2009 | Alessi Richard Sapper 9090/1
I need a replacement glass carafe for the alessi 9094/8 coffee press. Wher can I find one and how much should it cost? Thank you.
You can get a new carafe for the alessi 9094/8 and other 8 cup alessi coffee presses from Speranza Design Gallery www.speranzaonline.com . Search for 8003299015146 or go to this link: https://www.speranzaonline.com/store/prodView.asp?idproduct=2074 The cost is $24 plus shipping. It is genuine Alessi and it fits perfectly! I was very happy with my transaction with them -- easy web transaction, good communication, quick shipment, excellent packing of the fragile item. Comes in original Alessi box. It is listed as Alessi French Coffee Press Replacement Glass 8 cup .
Mar 02, 2009 | Alessi 9094/8 Coffee Maker
Need gasket for Alessi 6 cup stove top espresso coffee maker
I have a Elevation Espresso Coffee Maker it worked fine until today when it stopped heating the water. Any help would be great.
Regards
frank
Jan 21, 2009 | Alessi "Coban" Espresso Machine
Alessi coban rs04 espresso maker
Hi All,
I had the same problem. There is ONE authorised dealer for Alessi in Italy. They are Arthur Eugster Italia srl, in Asti (Piemonte). I don't have the contact number, but my friend in Italy got a complete set of seals from them, FREE OF CHARGE (don't ask me how he got it) and sent to me in Australia. Good luck
Fulvio
Jul 25, 2008 | Alessi "Coban" Espresso Machine
Coffee Makers & Espresso Machines Logo
57 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
