Question about 2007 Saturn Ion 4 dr ABS Plastic Ground Effects Body Kit 135-200 Razzi
Front blinkers and hazards will quit after driving a while. When I turn off and restart the car both will work fine again. But another 15min - 1 hr of driving it happens all over again. Any ideas?
Bulbs work fine, when I restart the car both blinkers and hazards work. Not long after, the indicator flashes fast for both L and R signals and I know it's gone out again. Rear blinkers and hazards do not seem to be affected. Only the front ones are failing.
    New Friend:
  • 24 Answers
When my blinkers blink fast that means you have a bulb out. Turn your blinkers on get out & look at your lights, 90% of the time it's a blown bulb.
Posted on Apr 14, 2014
Signal lights only work intermittenly
The blinker relay is getting worn out. It's right behind the hazard lights switch. Pull off the black trim around the radio, hazard, ets, and the relay is write there. Next time the blinkers stop working hit the hazard button or hit the trim just above the hazard lights button. Mines been doing it off and on and I just hit the trim above the hazard button and they start blinking again. Never have time or remember to get a new relay.
Sep 07, 2014 | 2001 Pontiac Grand Am SE
2001 4 Runner blinker problem
The hazards use a separate relay. listen for signal relay clicking to locate the correct relay. Consult your owners manual for fuse and relay layout.
May 26, 2017 | Toyota 4Runner Cars & Trucks
I have a 95 camaro the blinkers just quit working. The hazard lights work, but the blinkers don't work even if the blinker switch is turned on no lights blikeor come on
There is more than one flasher. One is for hazards and the other flasher is for directional signals. They are located under dash just left and right of the steering column. Don't go tearing up the steering column, then you are asking for trouble. Try the least expensive and labor intensive fix first.
Sep 25, 2017 | 1995 Chevrolet Camaro
My blinkers work sometimes and then stop working for a while, then will start working again for no reason, its very random. I dont know what i should do to get this fixed.
The turn signal flasher is bad. It is built into the hazard switch. Replace the hazard switch. The next time the turn signals quit turn the hazard switch on and off a few times and see if they start working.
Oct 12, 2010 | 2004 Oldsmobile Alero
Blinker doesnt quits work every once in a while. they
its a wiring problem...mine does it too. I found pressing the hazard lights button a couple times makes the signals work again
Jan 21, 2010 | 2002 Pontiac Grand Am
1996 Buick Regal. Blinker Issues
I know it sounds strange but I would first check the bulbs and then check the hazard switch. The hazard switch is also the flasher unit. It fails and there are alot of stsange sinarios.
I hope this helps,
Roy
Dec 01, 2009 | 1996 Buick Regal Olympic Gold
Blinkers work at start, then stop. Then work as car is restarted
change the blinker relay Or what i call flasher unit
Jun 03, 2009 | 2001 Audi A4
Turn signal quits
check to see if the flasher is weak, a quick way to test it is to swap it with the flasher for the 4 ways ( hazard lites ) and try it.
Oct 26, 2008 | 2004 Chevrolet Malibu
2007 Saturn Ion 4 dr ABS Plastic Ground Effects Body Kit 135-200 Razzi Logo
65 people viewed this question
Top Razzi Vehicle Parts & Accessories Experts
mike t.
Johnathan Lence
Johnathan Lence
Are you a Razzi Vehicle Part and Accessory Expert? Answer questions, earn points and help others
