Question about Frigidaire Dishwashers
1250rec1 ticking from door, no lights on panel
I have a model 1250rec1 the last time it was ran it did everything ok until the end of the cycle. Now I hear a ticking sound from the door, I tried to run another cycle but the front panel seems to be dead but the ticking continues.
  • 51 Answers
I traced it down to the timer switch or function selector being faulty. Are these other posters really that dumb or are they trying to mislead someone for their amusement ?
Posted on Apr 17, 2014
  • 338 Answers
SOURCE: I have a Sears Kenmore
call sears service and tell them you need service there is a service flash and will be no charge
Posted on Dec 23, 2008
SOURCE: Panel light flashes and ticks but will not run cycle
seems your flow switch is faulty
Posted on Jun 09, 2008
Cyril J
  • 45 Answers
SOURCE: My Kenwood dishwasher KDW24FI/B has
lol is it a stereo or a kenmore, dishwashers dont use salt, but water softeners do
Posted on May 16, 2008
SOURCE: Kitchenaid dishwasher - door will not latch
The latch needs to be replaced. Kitchen Aid has made two updates to this latch. I.E. 2-revised latches. I just replacd the latch assembly and the dishwasher works fine now. Do a search for kitchen aid repair parts online and hav them shipped to your home. The repair takes five minutes. Un-screw all torx bit screws on door and the latch is under neath. One electrical dip switch held on by another screw and a two prong tab to undo the old latch. This seriously took me five minutes to repair and the parts were $40.00 online shipped.
Hope his helps.
Posted on Jan 16, 2009
ltfrc
  • 227 Answers
SOURCE: Problems Keeping the cycle going
On the back of the selector switch there is a timer motor or clock motor assembly. The gears wear out or the motor has lost its ability to go through the cycles. Replace it and you should be fine.
Posted on Jan 17, 2009
I have a SHU5305us/u12 and my front door lettering got erase. anyone have a picture or a manual that tells me what each button means.
Cycle Interruption
As a safety feature the dishwasher will automatically turn itself off whenever the door is opened. However, if the door is opened quickly while in a wash or rinse cycle some water may splash out of the dishwasher. For this reason it is recommended that the machine always be switched off before opening the door.
To Interrupt a Cycle
1. Press the on/off button to stop operation.
2. Wait at least 10 seconds (or until the water noises stop) before opening the door.
To Resume a Cycle
1. SHU/SHI models, close the door and press the on/off button.
2. SHV models, push the on/off button and close the door.
Changing a Cycle
For Bosch dishwasher models SHI 6800 and 4320, SHU 5300, 5310 and 6800 press the program button of the desired cycle TWICE. For all other Bosch dishwasher models, press the program button of the desired cycle ONCE. The chosen cycle button (or the light above it) becomes illuminated, showing that it has been selected.
* SHU 3030 and SHU 3130 models do not have program lights.
Cancelling a Cycle
Each control panel shows which buttons to simultaneously push to cancel a cycle. Refer to your dishwasher to find the cancel drain buttons on your particular model.
1. Press the indicated buttons at the same time and hold for approximately 3 seconds.
2. When the drain pump noises stop and the LED display or clean light indicate that the end of the cycle has been reached, the dish
washer is reset.
3. Press the on/off button to turn the dishwasher off.
4. The dishwasher is now ready to run a selected cycle. Add more detergent if necessary.
Dado
Oct 05, 2015 | Bosch Dishwashers
Why Does Fault Alarm Beep at End of Cycle?
Check any user friendly ports, filters, screens. It appears that the washer is trying to tell you something. See your manual for troubleshooting. BLEEP BLOOP
Mar 10, 2014 | Haier HDP18PA Stainless Steel...
Engine tick with timing seems off but no check engine light.
If you ran it low find out where the oil is going leaks seal's put a large piece of card board under your vehicle tonite and check in the morning.do not move until you check.As far as the tick that sounds like a bad valve lifter or damage to your engine.
Jan 12, 2018 | 2003 Pontiac Grand Am
Model KUDS30FXSS1 Kitchenaid dishwasher control panel stopped working at the end of a cycle.
I had a similar problem: unresponsive buttons, then the 1 hour wash button led was on but the other buttons weren't working at all.
I power off for more than 30 seconds and after that everything return to normal.
Thank you for the hint!
Nov 03, 2012 | KitchenAid Dishwashers
I have a Whirlpool Duet Sport (model #WFW8400TW03) that shuts down when I press start. There are no error codes and the last cycle ran with no issues. The door is shut and seems secure. I can find nothing...
I had the same problem. My control lock was on without the status light on. To unlock the controls I Selected and held END OF CYCLE SIGNAL button for at least 3 seconds. The lock/unlock control status light never indicated the locked position, yet my washer now works. NOTE: Select and hold END OF CYCLE SIGNAL button for 3 seconds to toggle between lock and unlock.
May 18, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Whirlpool dishwasher stops at rinse cycle and won't go
Aureley, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Aureley), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 18, 2017 | Whirlpool 24 in. GU980SCG Built-in...
Jan 16, 2009 | Dishwashers
Amana dishwasher, model adb2200aws, ser #, 26650464e. history: quit running, no lights, nothing. replaced the door switch, ran for three days, replaced the switches on both sides of door switch, ran...
the person or persons that crimped on your spade push on) terminal ends, either cut thru most of the wire when stripping it for the terminal connector, leaving only very few wires, and /c they cannot carry the current, they simply vaporize leaving a terminal securely attached to plastic insulation - but no wire to carry the current.or he/she/it failed to properly prepare the wire end to expose enough wire, and crimped onto the insulation, leaving the wire hanging.
Pull the plug
Grab each of the power-related wire ends in turn and with your fingers, try to pull the crimped-on end off. Do not pull hard, although IF it was correctly stripped and crimped at the factory, you would not be able to. I am sure you will find one that feels very limp.. thats the culprit. Nip over to Home Depot or ACE and buy a Wire Termination kit ($10-20.00) which will contain all sizes andtypes you may need + a Cut/Strip and crimp tool.
It was either a MON or FRI job. Too hungover from the weekend... or too jumpy to go home.
Oct 12, 2008 | Amana Dishwashers
Oven wont come on
the oven door lock assembly has locked its self in to clean you can find the door lock assembly at the top of the oven where the door shuts sometimes if you push on the locking hook this will solve the problem
Dec 17, 2007 | Whirlpool RBS245PD Electric Single Oven
Asko 1585 Dishwasher
do they flash lik all on one side then the other? Start a cycle, then open the door. Do the lights flash the same way when you open the door as when it stops? if soyou may have a door that needs to be adjusted so it closes better. when the cycle ends, is there any standing water in the bottom? if so you may have a poorly routed drain hose or a partial clog in it. Last, pull the bottom panels off and look inside the bottom of the dishwasher and see if there is standing water down there . If ther is you have aleak somewhere or a bad drain pump. You r only other choice is a bad pressure switch. If youve already adjusted the water fil to the proper level ( just up to the grey plastic housing that the lower wash arm sits on) tehre really aernt any more options. Hope this helps!
Aug 29, 2007 | Asko 24 in. 1585 Built-in Dishwasher
Dishwashers Logo
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
