Question about Korg Pa800 Synthesizer
How do you fix the memory problem in a Pa800 - Korg Pa800 Synthesizer
My synth wont load when I power it on. can anyone help?
I suggest a hard reboot / initialize. Istructions are in your manual or on the Korg website
Jun 09, 2015 | Korg Pa800 Synthesizer
Korg pa800 256mb styles set
I wouldn't recommend doing that, because your OS system could freeze occasionally
Jan 29, 2014 | Korg PA800 61 key Arranger Keyboard Kit
Hello, I have a big problem with my korg pa800 , yesterday I was on gig, and suddenly the whole keyboard in the middle of playing got the distortion on every sampled or fabric tone!!! I have tried...
It will require repair. I suspect by you description that the D-A convertor has failed. This is a chip that is far beyond a DIY project to change. Do further testing to make sure the power supply voltages are correct and that headphone output sounds the same problem.
Here is your service manual: http://elektrotanya.com/korg_pa800_sm.pdf/download.html
Scroll down to "get manual" and click to download the manual. IGNORE other download links.
Aug 07, 2011 | Korg Pa800 Synthesizer
Hallo, I have a Korg pa800 and whenevery I want to load DrumKit or a Sound from another set, I get a warning message (Load Sound Fails: not enought memory fro PCM samples). What should I do to load...
you may have to dump somethings from the memory, the memory is finite and if there is no more room there is no more room. as far as I know there is no expansion memory for this keyboard
Mar 17, 2011 | Korg Pa800 Synthesizer
I damage my pa800 ~ACV. Can I change this part or to fix it by my self. P.S. Sorry about my language
Buy for a new ACV with exact detail, the volts and the amps for that equipment you are using.......
Oct 02, 2010 | Korg Pa800 Synthesizer
MY korkg PA800 doesnt load the opperating system and it wont let me reformat it, all i get on startup is a clear screen and nothing else happens
I don't know if your keyboard has a lithium battery for memory backup but that used to be a symptom of battery failure in other synths. Here is a link to a forum that discusses all the various problems:http://www.korgforums.com/forum/phpBB2/viewtopic.php?t=38399 Lots of reading buts lots of links and help.
Jul 08, 2010 | Korg Pa800 Synthesizer
WHAT KIND OF PCM RAM MEMORY IS USED IN KORG PA800 KEYBOARD.
Here is a site IF you are having problem with the PCM RAM. It sounds like you might even get a free replacemnet part.
http://www.korgpa.com/pa_root/en/products/pa800_faq.html
Nov 19, 2009 | Korg Pa800 Synthesizer
Korg PA800. Ram Upgrade
The pa800 has a fixed amount of Ram at 64mbs and it is not physically possible to upgrade the Ram. The pa2x has a removable128mbs Module and that can be upgraded via a 256mb Module from Korg.
Keith [mrniceneasy - KorgForums]
Nov 13, 2009 | Korg Pa800 Synthesizer
I have noise on ram samples
Korg Pa800 Synthesizer i have noise on ram samples Answer i turned on my pa800 and when i play ram samples there was some noise like cracking and distortion,... (More) i turned on my pa800 and when i play ram samples there was some noise like cracking and distortion, that happened 2 or 3 times, now its normal, but i think it may hapen again??? where is the problem, somebody says it is on motherboard? or its just ram overheating? since i install 2.01 os i noticed that its kinda warm in right display corner, can u help me???
Sep 23, 2009 | Korg Pa800 Synthesizer
PA800 Instruments making noise
you have memory problem it cost $150 to fix it
Aug 06, 2009 | Korg Pa800 Synthesizer
Korg Pa800 Synthesizer Logo
78 people viewed this question
Top Korg Music Experts
Michial Gueffroy
Are you a Korg Music Expert? Answer questions, earn points and help others
