Question about MPC Computers Computers & Internet
Tear down The tiny screws on the bottom are stripped. Cannot open laptop to upgrade RAM. Can I break the bottom cover?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 196 Answers
Yes you can. You might use Sugru to re-attach the cover. http://www.sugru.com
Posted on Apr 22, 2014
Add ram to asus f501a
The F501A has one RAM slot- located on the underside of the motherboard. It's a tricky thing to reach, but doable if you have patience. Turn the laptop bottom-up. Remove the battery. Remove the 11 screws from the back cover. The two nearest the hinge are longer than the other 9. They're tiny so put them into a cup as you work. Turn laptop over & grab the top cover in the area of either hinge & gently lift. Use a plastic credit card or plastic flat tool to slide around the edge as you gently pull upwards. There are little clips holding the cover down & they are freed as you push/slide the tool. Once the top cover is free, carefully lift towards you & un-clip the two ribbon cables which are holding it to the motherboard.
Now, in order to reach the underside RAM slot, you must un-clip the cable near the top right (the VGA screen), disconnect the fan, & remove any screws you see that are holding the motherboard down. Then, while supporting the fan, carefully lift the motherboard from the left side, up & towards the right (standing it up on it's right edge)- you may even want to tip the laptop onto it's side as you go.
From here, you'll now have access to the RAM slot. Only reassemble the fan & a couple of screws, then the VGA cable & keyboard cables & test that the RAM is recognized in the BIOS. You can press the tiny power button by reaching under the spot where it normally rests (so you don't have to reattach the entire keyboard/cover right away). Once you see the RAM is detected, then you can fully reassemble.
If you'd like a reminder- just take photos as you go.
Lastly, the maximum RAM is 8GB.
Jan 20, 2013 | ASUS F5 Computers & Internet
HOW TO UPGRADE RAM ON VAIO VPCM121AX LAPTOP
Memory Upgrade for Sony VAIO VPCM121AX Netbook Laptop, the Sony VAIO VPCM121AX Netbook Laptop takes the PC2-6400 DDR2 SDRAM SODIMM 200pin memory Memory Type, and comes installed with 1GB (Removable) of Memory.
You can upgrade your Sony VAIO VPCM121AX Netbook Laptop to up to a maximum of 2GB Memory, the system has 1 Socket to install Memory, already with 1GB (Removable) standard Memory installed.
For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
if you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
first you will need to select the manufacturer from a drop down list then select your product line
from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system
Power off the computer, and unplug it from the power source. Close the computer and turn it over.
Slide off the battery cover and remove the battery.
Locate the memory bay and remove the screws in the cover.
Remove your old RAM board(s) by pushing the metal clips and holding it down and outwards until the RAM board pops up. Then pull it out at a 30-degree angle. (If you only need to add more RAM to your existing RAM and you have enough available empty RAM slots, you will not need to remove the RAM.)
5
Insert the new RAM board into an empty slot at a 30-degree angle until you hear it click. Then push it flat down into the slot.
6
Replace the cover and screw it back in.
Upgrade the Sony VAIO Hard Drive
7
Locate the hard drive bay and remove the screws from the cover. Then slide the cover off.
8
Pull the hard drive out of the bay.
9
Remove the screw securing the hard drive with the magnetic screwdriver.
10
Pull the hard drive out of the bay by the black tab connected to it.
11
Re-insert your new hard drive into the bay and replace the cover.
hope it helps
Jul 15, 2012 | HP Pavilion dv7 Keyboard (483275-001)
How do I upgrade my ram on my Gateway All in one zx4250?
I too purchased a Gateway ZX4250 and a 4 GB RAM upgrade kit. It took me awhile to figure out how to open the case. Here is what I found.
1) Remove the two rubber pads at the bottom of the case (don't worry they pop right back on).
2) Open the small back cover.
3) Remove the one screw.
*****CAREFUL****
4) This part is a little difficult but just be careful not to use too much force. Take two small flat head screwdrivers and slowly separate the plastic silver front panel from the plastic black back panel. Start at the bottom where the two rubber pads were removed. Work your way around the case, you can see how the clips are connecting the two panels as you work your way around the all-in-one. It shouldn't be too hard just be careful on how much force you use.
5) Once the panels are separated you can now access the hard drive, optical drive and some other components.
6) Disconnect the Hard drive sata cable from the motherboard.
7) Disconnect the other cable right next to the sata cable on the motherboard (I'm not sure as to the purpose of this cable.
8) Remove the screws from the metal plate covering the motherboard. Take careful note that a grounding cable is connected to one screw.
9) Install your RAM.
10) Reverse the procedure to put everything back together.
This whole procedure to upgrade my RAM took about 15 minutes. I hope this helps some of you that are trying to upgrade your RAM. If you have any questions PM me.
Jan 03, 2012 | Gateway ZX493131e Notebook
How to open and upgrade RAM memory of gateway netbook model LT2704u?
This netbook is really the Acer Aspire One D255. You have to pop off the keyboard, then remove 4 screws that hold the back panel in place, which will allow you to remove that back panel in order to get to the memory.
Here's a video - blurry but it tells the story: http://www.youtube.com/watch?v=6KYNTvF0-5M
A better video on removing he keyboard: http://www.youtube.com/watch?v=FoTwln2SyQ4
Mar 01, 2011 | Gateway Computers & Internet
I would like to disasemble my laptops hinges but dont know how
What is the Model Series number?
There is a slight difference between the ZV6000, and ZX5000/ZV5000 series, for this procedure.
I want to give you the link to the Service Manual, (Free)
It won't describe, or illustrate the entire procedure of removing the Hinges, but will help for me to guide you.
The basic procedure is to remove all electrical sources first.
AC adapter (Charger), and Battery. Work on a table.
Follow Anti-Static Precautions before you begin.
Have a multi-compartment container, for the various screws you will remove, and label each compartment for where the screws came from.
(You can use a clean egg carton in a pinch)
Open the laptop, remove the Strip Cover,
(Below the LCD screen, and above the Keyboard. There are screws to remove from the bottom, so that the Strip Cover can be removed)
The Strip Cover will be popped up, and out, and there is a procedure for this.
(Start at one end, work your way along, basically)
The Keyboard is removed next. There is a procedure so you don't break the tiny keyboard connection cable.
There is a Thermal Cover to remove.
Next are the Wireless Antenna cables, and Display cable.
There may also be a Display Ground cable.
Screw covers for the hinges are removed from the back. The hinge screws are removed next.
The above is a General, Basic, set of procedures.
Advise do not follow it.
It's just to give you a basic idea of what is entailed.
If your problem Does Not relate to the HP Pavilion ZV6000, ZX5000, or ZV5000 series of laptops, state what laptop manufacturer, and model series it is.
(State in a Comment)
Jul 02, 2010 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
HOW DO I REMOVE THE HARD DRIVE FOR REPLACEMENT ON ASPIRRE 9504WSM
1) Remove the AC adapter, (Charger), if plugged in. Remove the Battery. There must be No electrical sources to the Notebook PC.
(Laptop)
2) Turn the laptop over, going from Right to Left. Bottom of laptop is now facing you.
3) On the left side there is a rectangular panel. The rectangle faces up, and down in length.
4) In the Middle, to the right of this panel is another rectangular panel. This panel faces horizontally in length.
This is the Harddrive Compartment Panel.
There are two Philips head screws on the right side of the panel. One on top, one on bottom. Loosen these screws to remove the panel.
(You will see a finger tab on the right of the panel, used for lifting the panel up, and out)
5) You will see a cloth strip attached to the back end of the harddrive.
Slip the cloth strip out. Grab the cloth strip with your fingers, pull back.
6) When the harddrive has cleared it's pins of the interface connector, lift the back end of the harddrive up, and slide the harddrive out.
CAUTION!!
Use care as you do not want to bend those tiny pins.
Refrain from touching the pins. If the harddrive is determined to be bad, it's okay.
When installing the new one though, refrain from touching it's pins.
Dec 29, 2009 | Acer Aspire 9500 Notebook
Accessing memory (RAM) to upgrade
First of all, remove the battery
Insert a thin object under the securing strip and lift it up.
Be careful, it may be very tight.
Remove the securing strip.
Carefully work with finger to disengage plastic latches securing the securing strip.
Remove three screws and a metal brace securing the keyboard.
Lift off the keyboard and place it on the palmrest
Now you can access the memory modules.
Jun 12, 2008 | Toshiba Satellite A25-S207 Notebook
Medion MD41349
You need to remove all the screws from the back also, then remove the cover to the rear on the bottom and remove the wireless card (make note as to connection colours) and there is 2 (I think) screws under there, then one also under the battery, then the whole top opens up.
Make sure you have removed all screws from the bottom case, including the four under the rubber feet at the rear.
This was the most awful laptop I have ever worked on!
May 11, 2008 | Medion MD-40954 Notebook
Computers & Internet Logo
Top MPC Computers Computers & Internet Experts
Lee Durbin
Lee Durbin
Josh Levin
Josh Levin
orangeupstag
Level 1 Expert
Are you a MPC Computers Computer and Internet Expert? Answer questions, earn points and help others
