Question about PANDIGITAL PANSCN01
Plastic sheath Where can I buy an anti-curl plastic sheath?
    New Friend:
  • 113 Answers
Try Best Buy, Staples or Office Depot.
Posted on Apr 15, 2014
What is the part called it the clutch cable is inserted to on a 2000 suzuki katana 600
The cable (long, bright, shiny, braided/twisted wire) is inserted into a sheath before the two end pieces are crimped onto the cable. The sheath or housing is the black plastic tube that houses the cable.
Jun 13, 2014 | Motorcycles
What are party blowouts? The teacher at my sons school said we should buy some for his birthday party and I am not sure what she meant.
Party blowouts are also sometimes called nosie makers. They are little plastic tubes with curled up paper 'tails' attached to the end of them. When you blow into the tube, it sends the paper flying out and usually comes with a very loud noise. They have loud but fun!
Feb 25, 2013 | Event Planning & Celebration
Replace the motor shaft cover on cuisinart dlc 7
I have a DLC7pro from around 1982 that I just replaced the sheath on.
To remove the sheath I use a small pipe cutter and took the sheath off in approximately ½ inch sections. Once the circular cut was complete I used a plier to pull off the section. - This method worked GREAT! Be sure you get ALL of the white plastic off and be sure to remove the ½ inch brass "ring" which is part of the old sheath. Also, make sure no plastic "crumbs" are in the base of the shaft where the new sheath will sit. You will see that the metal shaft has a flat side. With a sharpie marker, mark the metal shaft near the base to indicate where the center of the flat side is.
When you look at the replacement sheath, you will notice flat sides on the outside of the sheath. If you look inside the sheath, you will see two "nubs", these nubs form a flat inner side of the sheath . Unfortunately these nubs do NOT line up with the flat outside sections. Use a sharpie marker to mark the center point of the two inner nubs. The inner flat side HAS to match up perfectly with the flat side of the shaft. The marker helps you do that.
Line the inner flat side of the sheath up with the flat side of the metal shaft and push the sheath on your hand as far as it will go. It should go about an inch from the base.
Put the base on a mat on the floor ( you don't want to damage your floor) . Next you will need a hammer, piece of 2x4 wood and BRUTE STRENGHT! - Please note that once you hammer this, even just one strike and the sheath will NOT come off. Put the 2" side of the wood against the top of the sheath. Using more force than you think you should need - strike the wood to hammer the sheath all the way down. It should take 3 - 5 very hard strikes. If the base of the sheath rubs on the bottom of your workbowl - they will fuse together, so be sure the sheath is seated as far down as you can get it. Again, it takes a LOT
Dec 06, 2010 | Cuisinart DLC-10S Pro Classic Food...
Paper jam
You are receiving this error message because there is a paper jam or the top (photo) tray is not securely in position and the printer cannot initialize. This error message can appear for an ESP 7, ESP 9, ESP 7250, or ESP 9250 all-in-one printer.
To resolve a paper jam, we have an easy Step-by-Step Solutions and Repair tool. Within the tool, select All-in-one printer, then Paper jam.
When you clear the paper jam:
  1. Make sure you open the paper output tray and inspect the top tray for photo paper that could be jammed inside or that remains in the nip at the entrance.
  2. Pull out the bottom paper tray and clear any paper jams.
  3. Remove the duplexer from the back of the printer and clear any paper jam.
NOTE: Curled photo paper could induce a paper jam. To prevent curling:
  • Store un-printed paper in a tightly closed plastic bag or in its original packaging.
  • Store sealed packages of paper flat, and not on
  • When you are ready to print, take only the paper intend to use immediately.
To remove curl in photo paper:
  1. Place the paper in a plastic bag or in its original packaging.
  2. Gently bend the paper in the opposite direction of the curl, then insert it into a tube-a paper towel tube works well.
    NOTE: The tube should be larger than 1.5 in. (4 cm) in diameter.
  3. After a few minutes, remove the paper from the tube.
  4. Remove the paper from the plastic bag or packaging.
  5. Verify that the curl has been removed from the paper. Repeat the steps above if necessary.
If the top paper tray is not securely in position and the printer cannot initialize (you may hear a grinding noise, and the top paper tray will not open), contact Kodak.
Nov 02, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
The curl motor is not working properly
In the printer properties panel, select the print on the backside option. This disables the anti-curl function.
Jul 20, 2009 | Alps MD 5000 Thermal Printer
Anti-curl motor error
Yes.
On the Document/Quality tab, select "Print On Backside" in the Media Type box.
Apr 14, 2008 | Alps MD 5000 Thermal Printer
Print Problem error after 1/3 to 1/2 prints
This is not for changing carts, it's for the anti-curl function. You need to attach your printer to a computer, load the driver, try a test print from the computer, and check to see if the printer is reporting an Anti-curl motor error
Oct 14, 2007 | Alps MD 5000 Thermal Printer
PANDIGITAL PANSCN01 Logo
Top PANDIGITAL Office Equipment & Supplies Experts
Mike
LP
Are you a PANDIGITAL Office Equipment and Supply Expert? Answer questions, earn points and help others
