Question about Maytag Centennial MTW5800TW Top Load Washer
How to replace lid switch video
My washer just quit working all at once. There where NO WARNINGS all was fine sounded just fine acted just fine !!! so I have checked the electrical plug and the power is there with no issue at all. Im trying to find a way to check the lid switch to see if it is bad. Although I do not think it can be checked besides by the time I get to it due to its location I'm thinking I'm there might as well replace it if its not to expensive or difficult. That's why I'm looking for a video.
  • 34 Answers
There are videos on you tube. The lids are usually held down with a couple of clips sometimes screws. If it has a switch that is activated with a plunger on the lid test it with a screwdriver if it doesn't have a hole us a magnet to test.
Posted on Apr 14, 2014
SOURCE: washer lid switch
removing top of console then front
Posted on Feb 04, 2007
dididsaythat
  • 291 Answers
SOURCE: defective lid switch I think
Sounds like your lid switch is ok .. u need to replace or adjust the plunger for the switch... below is a pic of the plunger.. sometimes u can get a little adjustment on the clip that pushs the plunger thats attached to the lid.. pic below
sounds like this is the part that has wore and shorten some...
also check the lid cam maybe able to wedge something behind to get more length out of the plunger heres a pic
Posted on Oct 27, 2007
SOURCE: My Washer will work at all. It acts dead
a small run of these actually had an out of balance switch and fuse assembly that cut power to the machine if it went way out of balance ,check and see if yours has one and replace the fuse at first but you may have to replace the entire assembly
Posted on Feb 08, 2009
smartr10U
  • 1305 Answers
SOURCE: Washer is "dead." Was stopped after fill up, and now no power.
Try pushing firmly on the center of the lid.... with the lid closed... it could be that the lid switch isn't making proper contact to turn the machine on.
If this is the case, you can open the lid, and while holding the lid open with one hand, put firm pressure on the rear lip of the lid right in the center..where it makes contact with switch...
This was a common occurence at my laundromats because people would sit/stand on the machines..
Hope this gets ya up and runnin'
Posted on Jun 20, 2009
SOURCE: Maytag washing machine model MAV5000AWW quit
water in tub will not spin, wash, or fill with water
Posted on Apr 01, 2010
Estate by whirlpool model SM8280867. Filled, then stopped. What's wrong?
Charla, By what you have stated, it sounds like a lid switch failure. I recommend checking the screws for the lid hinge first.The lid has to be closed for the motor to run in the washer. If the lid switch is faulty, it will act as if the lid is open. A quick check you can do is to run a cycle with the lid switch jumped. If the washer operates, the lid switch needs to be replaced.
To jump the lid switch you need to unplug the washer and open the console.Once you have the console open, locate the connector for the lid switch. Place an insulated jumper between the gray and white wires. Not the green it is a ground and will cause a short. After inserting the jumper make sure it will not touch anything metal, plug the washer in. Then start the washer in a cycle, and let it go. If the washer completes the cycle, you need to replace the lid switch. Remove the jumper and order the part. The jumper is only of the test do not continue to operate after test.
Whirlpool Appliance Parts
Whirlpool Appliance Parts Whirlpool Appliance Parts from Easy Appliance...
http://www.repairclinic.com/Shop-For-Parts/a11b5/Whirlpool-Washing-Machine-Parts
Mar 05, 2016 | Whirlpool Washing Machines
Lid is not locking properly, washer sensor is overfilling, and the washer wont spin
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Pl click if helped.
Apr 28, 2013 | Whirlpool WTW4950XW Washer
Washer Doesn't Start
once again check your lid switch where the lid hits when you put the lid down
Jan 15, 2013 | Kenmore 98702 Stacked Washer/Dryer
Spin cycle will not work at all. washer drains but will not spin.
Hello & Welcome to FixYa
When the washer fills however, will not spin then you can check if the lid switch is fine. You can jump start the lid switch by connecting both the wires with each other or use the third wire to act as jumper between the two. After this if the problem is solved then replacing lid switch is recommended repair. Please get back to me if you have any other questions.
Kevin
Aug 11, 2011 | Kenmore 24032\24036 Top Load Washer
My kenmore washer model#110.24422300 is not agitating, spinning or draining. Problem started today, it work fine yesterday. Tried selecting different settings to get to agitate or drain, did not work.
When the washer fills but does not agitate or spin then you can check if the lid switch is fine. You can jump start the lid switch by connecting both the wires with each other or use the third wire to act as jumper between the two. After this if the problem is solved then replacing lid switch is recommended repair. Please get back to me if you have any other questions.
Kevin
Aug 07, 2011 | Kenmore 22422 Top Load Washer
I have a Kenmore 60 series heavy duty washer. It will wash and drain in all cycles just fine, but it won't spin. It sounds like it wants to spin but it wont.
Kevin
Jul 22, 2011 | Kenmore 24032\24036 Top Load Washer
My washing not draining water after washing.
It sounds like a lid switch failure. The lid has to be closed for the motor to run on your washer. If the lid switch is faulty, it will act as if the lid is not closed.
You need to replace the lid switch.
Hope this helps.
Shane
Mar 10, 2011 | Washing Machines
Spins when it feels like it
Popcorn, sounds like you are having trouble with the lid switch. The plastic housing in which the screws hold the switch to the cabinet may have cracked, or came loose. If the lid switch is not making correct contact the result is no spin, no drain. The switch actuator on the lid itself may need adjustment. The lid switch is mounted to the cabinet on the back right side under the consol. The lid switch part number is 8054980. But check the actuator first. Catriver..post back.
Oct 04, 2006 | KitchenAid KAWS850L Top Load Washer
Washer won't drain
Mustache, sounds like you have a broken lid switch. No spin, no drain usually a sign of this. Check to see if the actuator is making the lid switch, or the switch itself is bad. Part number for the switch is 8318084. Catriver, post back.
Jul 30, 2006 | Roper RAX4233PQ Top Load Washer
Maytag Centennial MTW5800TW Top Load Washer Logo
42 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
