Question about Kitchen Appliances - Others
Kettle repairs I have a metallic(chrome)I bought it in 2006 it has a brown handle, its no longer in shelves, the handle broke today so sad
    Sergeant:
    Champion:
  • 266 Answers
Wood glue and a clamp will fix the handle (Elmers) but you need pressure to hold the handle on while iy dries. You can bind something around it.
Posted on Apr 14, 2014
No longer turns itself off when boiling
modern kettle are made to be disposable items. You will need to buy a new one.
Nov 04, 2015 | Kitchen Appliances - Others
Is it okay to use glass whistler tea kettle on ceramic stove top range
I've seen mixed results across the internet on this one. From personal experience, for some reason, my glass teapot left some sort of stain on my ceramic stovetop. It also took longer to heat. I then went out and bought a simple metal one and have been pretty satisfied. If cosmetics are a concern, it's not too difficult a step to pour the water into your teapot after the fact, right?
Jul 23, 2014 | Frigidaire Ffed3025ls 30 Smooth Top...
I boiled the kettle dry and it now has brown spots on it. Can I restore it to its beautiful finish
It must have been badly over heated. Check at the local hardware store for cleaners that can clean over heated metal surfaces.
Jerry G.
Jun 10, 2012 | Alessi 9093 Kettle with Bird Whistle
I have a michael graves tea kettle it is beige enamel with a black handle with red caps in each end of handle supported by two chrome pieces going up the handle it has a lid with a knob made of wire...
Hi Julie - This is likely a Target Michael Graves product . Generally , parts for the Target Graves products are not sold . I am not familair with the size of the whistler you need . The only Michael Graves replacement kettle whistle available is the Alessi version .
Jul 10, 2011 | Kitchen Appliances - Others
The 5th door of my 2006 Sequoia was very difficult to open. Today the handle broke and I can no longer open the door.
as it broke, you need to replace the handle only! then use Anti rust spray to the lock from time to time... it'll be ok! the lock is exposed to accumalation of dust, dirt and lubricants as it is in the bottom of the door, so you need to take more care about it. handle will cost you $60 to $72
if you have some skills you can do it your self, or take it to a technician
May 25, 2010 | 2006 Toyota Sequoia
Kettle not switching off after boiling so carrys on boiling untill you turn it off
To state the obvious, the steam sensor has failed. Unless you are quite adventurous, and confident dealing with electrics, there's nothing for it but to get a new kettle (unless the kettle is still within warranty, in which case you should be entitled to a replacement of course).
Oct 11, 2009 | Morphy Richards 43025 Electric Kettle
Stokke Xplory Front Wheel
Contact Stokke. They had a recall and they are replacing the front wheels.
Aug 20, 2008 | Stokke Xplory Standard Stroller
Problem with my electric jug kettle
The element may be rusting! Normaly rust is safe, but annoying. you should find out the type of metals to know if it is actualy safe.
Personaly, I would go and get a good quality product from a well known manufacture. This way it will be safe and dependable.
Jerry G.
Apr 24, 2008 | Kitchen Appliances - Others
Switch problem
That is correct, the flat plastic rod that pulls when you depress the on/off button is attached to a switch lever under the bottom of the handle. The rod in mine broke off right where it connects to that switch lever. You can either try and find the new or used part, Braun may have new, I have not tried their 800 number, can't hurt? I fix everything from scratch though and rebuild when I can especially if parts are scarce or obsolete. So I used some marine putty to affix the rod end back to the lever. Marine putty is a stick with two putties you roll together for a rock hard compound, awesome stuff. You can get at Wally World or hardware, auto parts, boat supply stores. I also drilled very small holes in the broken rod on each side and the lever on each side and threaded some thin stainless steel wire through, just looped it around without twisting it togethor before putting the putty over it for a permanent, wire reinforced, fix.The handle is not screwed on exception of one little torx screw at very bottom of handle on base. The handle just snaps together. The base or bottom and 3 screws do not need to be removed either for this rod and lever fix. Remove the top 'cover' piece of the handle first, then remove the two brass pins under it at top next to the on/off button second. So, the handle 'snaps' off with a lock blade knife or equivalent, get under the handle pieces with knife edge and twist the blade, it will pop off as you go, be prepared to break a few little hook pieces off underneath, they break but it seems to snap back on ok anyway. Crazy glue alone won't hold these plastic pieces together btw, try another way, wire and putty, maybe a plastic welding kit etc.. Mine works great again, once I got the lever reattached to the rod..
Apr 16, 2007 | Braun WK200 Cordless Electric Kettle
Kitchen Appliances - Others Logo
91 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
