Question about GE 24 in. Profile PDW7800 Built-in Dishwasher
PDW7800 lower spray arm making clunking sound
The lower spray arm making noise - a thunking or clunking sound. Removed and replaced the arm to make sure it was sitting correctly, it seems to be, but noise remains. Any ideas or solutions?
    Problem Solver:
  • 8 Answers
1. The spray arm has an aluminum piece on the bottom side of the spray arm. It kinda separates away from the plastic arm and as the spray arm turns, it hits the inner door liner. You can see the scrape marks it makes on the door liner. You can bend the aluminum edge upwards with needle nose pliers or try to make it tight to the plastic spray arm by pushing on he tabs.
2. If you have removed the spray arm make sure the thin silver washer is still inside the hole were the spray arm inserts use a flashlight and look inside that section. If missing, it can also make a noise.
Posted on Apr 25, 2014
  • Darlene Barber
    Darlene Barber Apr 25, 2014
    Thanks, that's what it was. I tried bending the metal blade up, but it wouldn't stay.
  • Darlene Barber
    I ended up ordering a new arm and popping it in. Very easy to do! No more thunking sound!
5 Suggested Answers
  • 93 Answers
SOURCE: noise when spraying
The wash arm(spray arm) is not a tight fitting item,as for the noise the when spraying have a look at the spray arms the are a few holes on each side and top and bottom of each arm,you will need to remove the arms of possible they normally have a quik release system where you push two small fingers together and the arm releases,then inspect these holes and you will probebly find that some are blocked this cuases a uneven flow of water and thus makes the arm rotate un even and make a noise if you find there is food of sorts in these holes remove and put the arms back and that should take care of the increased noise.
Posted on Feb 05, 2009
  • 81 Answers
SOURCE: Dishwasher - excessive noise from lower spray arm.
Remove the spray arm (just pull it out) and clean the "seat" with soap and a nylon bruch and se if the problem continues.
Posted on Apr 24, 2009
  • 81 Answers
SOURCE: removed lower spray arm:ge gld5500 dishwasher. Can reinstall.
Yes!
  • 547 Answers
SOURCE: Makes a loud buzzing noise when running
My dishwasher (very basic GE model) did this once. The buzzing only happened when it was washing the dishes, not during drain or fill parts of the cycle.
In my case, the issue turned out to be a bit of plastic (part of a drinking straw) that was stuck in the pump assembly. Whenever the pump was on, this bit of plastic was getting dragged over a metal filter plate, and sounded a lot like a kid with a card clipped in the spokes of a bike.
Good news was that I didn't need to buy any parts, simply disassemble the pump housing and pull out the plastic.
Bad news is that it took me a few hours to get the dishwasher out, apart, back together and re-installed.
Good luck with yours!
Posted on Jul 31, 2009
Clunking and creeking neon
It sounds as though you have a c/v joint going out on your Neon. If you intend to repair it yourself, the replacement part is around $40-$50.
Feb 02, 2014 | Cars & Trucks
Lower spray arm seems to be off centre and makes thumping noise when running.
The one side of the spray arm is probably clogged with food particles. Remove it and clear out the jets in the trailing edge of the arm. The arm is only being driven by the spray from one side and that is what makes it off balance. Check the top spray arm as well, it may be partially blocked as well.
To prevent this happening in future, make sure that there are no solid particles of food etc. on your dishes before putting them in the machine.
Mar 24, 2011 | Dishwashers
I have a 2005 Trailblazer. I have had the stalilizer bar replaced, new ball joints, greesed the fittings on the ball joints. New calipers, rotos and branke pade. HOWEVER, I still have a clunking sound...
They are really bad for the lower control arm bushings causing a clunk noise. You can't see movement by checking on a hoist, but lubing them will help only temporarily. I did a lot of them under warranty, but being 2005 I'm sure yours has expired. I' would highly recommend changing them to eliminate the clunk noise.
Feb 01, 2011 | 2002 Chevrolet TrailBlazer
Amana ARB8057CSR Bottom Freezer Refrigerator, Intermittent Quick Loud Noises Appliance history: Purch. 12/03. Replaced PTC relay 12/08. Water filter last replaced 3/10 (2-person household). Problem:...
No-one posted a solution. I contacted the original solution poster who was very helpful.I hope this helps someone else better understand their refrigerator problem and get on the right track. Staffgage.
Tweezb wrote:
"you are right that cleaning under your refrig wont get rid of a "compressor knocking" sound. what it might do is to lower the amount of heat from the condenser coils and thus cause less pressure and stress on the compressor making it run easier and less likely to bang or knock when shutting off.
if your coils were very plugged with lint and you have cleaned them, that will help but it wont "fix" the problem.
inside the compressor is a motor and a pump, the motor is supported by 3 springs and they can stretch or break causing the motor to hit one side of the black outer can and cause the noise.
that may be too technical, but its not something that can be repaired without replacing the compressor, at a cost of 700-800 bucks. most would not pay this as its not worth putting that amount of money into an older refrig."
"think that you are hearing either a freon related sound or even just the sounds of the unit going thru defrost.
how often do you hear the noise? just maybe once a day or is it everytime the unit shuts off?
either way i would rule out the ice maker and water system as when the "shut off arm" is up then it is off and wont make any noise, or ice.
keep the i/m arm up and then listen for the next day or two and try to narrow down when it makes the noise and frequency you hear it and then get back to me.
it may not even be a problem, just normal operating sounds that cant be changed."
Oct 20, 2010 | Refrigerators
Washer makes a grinding noise while running in the wash cycle. I've confirmed the rotors in the unit are not hitting anything inside the tube. The noise seems to be coming from the drive mechanism...
You will likely have to remove the pump motor from underneath to solve your problem. Try removing the lower spray arm assembly down to the deck and check the pump impeller for noises. Make sure to note the position and placement of all parts removed. Hope this helps!
Jun 28, 2010 | GE 24 in. Profile PDW7800 Built-in...
Kenmore dishwasher model # 665.15522000 leaking badly
Hi, Make sure the jets in the spray arm ore not plugged at all. Check the black bellows on top the lower spray arm and see if it has a split in it. Let me know if these help or if I can assist you further.
Vic
May 21, 2009 | Dishwashers
Need to clean out the upper spray arm and so would like to remove it (like I did the lower one) and clean it out. Help!
We have a PDW7800J01WW that I removed all the arms on recently.
There is a single hex-head screw that acts as the pivot at the center of the top most arm. Just remove this screw to remove the spray arm.
Be very gentle reinstalling it though as it is easy to over torque it and strip the plastic hub it screws into.
May 09, 2009 | GE 24 in. Profile PDW7800 Built-in...
Mar 14, 2009 | GE 24 in. Profile PDW7800 Built-in...
GE 24 in. Profile PDW7800 Built-in Dishwasher Logo
283 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
