Question about KitchenAid KERS807SSS Electric Kitchen Range
I have KitcheAid KERS 807, electric stove/oven range. Left lower part of ceramic stove top that has single/dual heater sizes is malfunctioning. Single one is still working but from recent dual does not.I do the same as before on my dial/button but there is no heat generating in the outer perimeter any more.I would appreciate help/advise/direction regarding my predicament.Thanks,Dan
    New Friend:
  • 33 Answers
Either the knob has gone out or the burner element. I would test the knob first to see if there is current when turned to the large zone. If the knob is working, next would be to test the burner to see if the outer ring has burned out. I would guess more likely the control has gone out. Burners have less failure (typically).
Posted on Apr 16, 2014
2 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: My KERS 807 SSS Stove works fine but not oven
sonds like a bad hightemo thermostat, loacted on the back wall behind the rear panel, common issie for ovens ,espessially after going through a self-cleaning,part number 9759242, part is about $50 turn off power before attempting to change, LIVE WIRES!!!!
Posted on Nov 30, 2008
Stove top is working but neither the broiler nor bake is working. Cannot bale anything but the stove top cookers are fine. What could be the problem
Stoves are wired for 220 volt, but the range top will operate on 110 volt so your Breaker should be a single 220 volt breaker but can be achieved using two 110 volt breakers if one of the breakers blow the range top may still operate but the oven will not. So my suggestion is to Check your breakers to see if you are operating on two 110 volt breakers and one is possibly tripped.
Thumbs Up if Helpful, Feedback is Appreciated!!!
Jun 18, 2011 | Frigidaire FEB27S5A Electric Single Oven
What is the single fuse in top panel of electric oven/range for?
Hello there and welcome to fixya
Normally the single fuse that you have found is for the electronics like the clock and the various other basic funtions o the stove ect ect if this fuse has blown out it will limit the stove or the cook top to be able to do such things like setting the timer or turning on the ovens light and it may also effect the troubleshooting program that is built into the stove ok like error codes and simple things like this
Hope this is very helpful for you '
Best regards Mike
May 16, 2011 | Frigidaire GLEB27S7A Electric Single Oven
KitchenAid electric range KERS807SSS02 -in the middle of cleaning cycle, NO power outage but panel went black and door remains locked even after cooling. Circuit breaker not the problem. Top elements work.
We have a Kitcheaid gas stove and have had 3 new thermostats installed. After the 3 time it finally did it's first full cleaning cycle.
So three service calls later, (first was after the warranty) and three thermosats and over $500 and the stove has done it's first full cleaning.
Lots of examples of this same problem but it seems no recall on the stoves.
Jan 08, 2010 | KitchenAid KDRP407HSS Dual Fuel (Electric...
All stove top elements and oven wont work
Go to your home circuit/fuse panel and reset the fuse or circuit breaker for the range.
Dec 30, 2009 | Frigidaire FEB27S5A Electric Single Oven
How to remove scraches from ceran top
Clean the stove top thoroughly. I use oven cleaner to clean my stovetop. It works wonders. Be very careful not to get the cleaner on any part that is not ceramic finish.
Then, lightly spray Appliance Paint on the scratched area. You can purchase this paint at any hardware or Home Improvement store. It comes in several of the standard appliance colors.
If you need to use more than one coat, wait several hours between coats. Better to use several light coats than one heavy coat. A single heavy coat will tend to chip.
Oct 08, 2009 | Maytag MER5775Q Electric Kitchen Range
Nov 30, 2008 | KitchenAid KERS807SSS Electric Kitchen...
Whirlpool 465 large capacity electric ceramic top oven failure
How much time I need to set to do the oven self cleaning ?
I have electric Whirpool oven 465 automatic
Oct 18, 2008 | Maytag MES5870A Electric Kitchen Range
KitchenAid KERS807SSS Electric Kitchen Range Logo
141 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
